How do you setup your car for BS?
Old Mar 30, 2007 | 08:13 PM
  #41
Fluid1's Avatar
Fluid1
Originally Posted by tomsn16
Jason Isley beat Carter by 0.100 seconds in 2006.He also won in 2005 by a bunch.He is THE MAN in BS.
It was rhetorical for me Jim, but....
  #42
Fluid1's Avatar
Fluid1
Originally Posted by damnyankee38
I run a Roadster in BS, and was wondering if anybody had tried removing the counterbalance weight from under the front end? Or even the one under the rear?
Hey Ken.
Old Mar 30, 2007 | 08:34 PM
  #43
tmak26b's Avatar
tmak26b
Both of our cars had just under 1 degree on the left front and just over 1 degree on the right and that's probably what most have.Prying on the rubber bushed upper link is futile...unless you bend something which is a no no in stock class.
I must have a bad car, mine only has .7 or .8 degree. I have to hit a few holes now damnit
Old Mar 30, 2007 | 09:29 PM
  #44
PDX_Racer's Avatar
PDX_Racer
Originally Posted by tmak26b
I dont know what mods you have, but I can tell you a stock Z does not do any slolams. I have 245s all around, but hte car still plows like a big and it has absolutely no turn in capability.
Stock class prep: Eibach FSB, Koni Sports (now Koni DA).
I've got the G load traces showing how well the Z slaloms -- when it has grip (there was very little grip at Topeka, and the G load traces show that).
I've spent a lot of time working on the nut connecting the steering wheel and the seat, and the only time that the Z really has problems is when things are painfully slow (Evolution Phase 1 school, for example). Picking up the pace and the car almost flies through the same maneuver.
Old Mar 30, 2007 | 10:52 PM
  #45
tmak26b's Avatar
tmak26b
good compare to other cars that are not as sporty, but the 8 can outrun the Z in the slolam easily. I spent a little time behind the Z today, I think part of the problem is how slow the steering is on this cow!
Old Apr 1, 2007 | 07:54 PM
  #46
tmak26b's Avatar
tmak26b
I autox today with a set of left over V710 from last year. I don't know if it was the tires, or the full tank of gas. The car drove 100x better as it had a little more grip and just much better over all compare to my Azenis Rt-615. These 710s are definitely on their last leg, but it was just enough for me to squeeze .3 sec to get a win out in BS again. The course also favor the Z too as there were less slow tight turns with a couple nice straights.
Thanks for the advice on the full tank, I will use that from now on. I am sticking with 245 because I drive my car on teh street. I don't know how 275 on 7.5 will feel on the track or on the road, so I will give up a little grip for comfort. Lastly, race tires are the best cure for the plow...
Old Apr 2, 2007 | 05:47 AM
  #47
larson's Avatar
larson
Default Set up
What air pressures are you running on the 275 Kumho's? I have used 35F 32R cold in the past
Old Apr 2, 2007 | 08:48 AM
  #48
tmak26b's Avatar
tmak26b
I run 245, i use 30psi
Old Apr 2, 2007 | 10:11 AM
  #49
ULLLOSE's Avatar
ULLLOSE
Originally Posted by DriveI65
Or you could say he is the BS man. Depends on how you read his posts.
I am the king of BS... And that has nothing to do with autox.
Old Apr 8, 2007 | 02:03 PM
  #50
ssamsct's Avatar
ssamsct
Default 275 on 17 inch rims
was the offset stock on 275s on 7.5" and 8" stock width rims? I'm concerned about the fronts lacking stering clearance
Old Apr 8, 2007 | 04:43 PM
  #51
tomsn16's Avatar
tomsn16
275/40/17 tires fit fine on front and rear with oem offsets.We used 1/4'' spacers in front but not required for clearance.
Old Apr 8, 2007 | 06:18 PM
  #52
damnyankee38's Avatar
damnyankee38
Front AND Rear?
Old Apr 8, 2007 | 06:19 PM
  #53
damnyankee38
Originally Posted by Fluid1
Hey Ken.
Hey Tony
Old Apr 8, 2007 | 06:23 PM
  #54
tmak26b's Avatar
tmak26b
Front AND Rear?
Yeah, once a while I have a 1psi variance depending on the track
Old Apr 8, 2007 | 06:36 PM
  #55
PDX_Racer's Avatar
PDX_Racer
When I ran 275/35R18 Hoosiers, I didn't have any spacers on the OEM Track rims. No problem with rubbing (well, except with the inside edge of the front fenders on an extremely bumpy course location!)
user 62082028
Southern California
Jul 28, 2017 11:47 AM
Mattg350z
Oct 2, 2015 06:51 AM
