Need Tire Trailer!!!
Old Mar 29, 2007 | 09:25 PM
BlackoutZ's Avatar
BlackoutZ
Default Need Tire Trailer!!!
Any of yall selling or know any brands of trailers that dont have to be custom fabricated to fit tires. I went to Northern Tools and found a 4*6 trailer but it will have to be modified to carry tires. I live in San Antonio Texas.
Thanks in advance
Blaine
Old Mar 30, 2007 | 04:30 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Thanks in advance
Blaine
Blaine, most of all the autox guys had to custom build all of their trailers. You might want to ask the SASCA guys for advice at the link below.
But I thought you were going to tow your car to Floria on a trailer? Just put the tires in the back of the truck. You need a hitch too if your gonna do what your planning.
http://sasportscar.com/forum/portal_content.asp
Old Mar 30, 2007 | 05:25 AM
mhoward1's Avatar
mhoward1
There's a great thread in the Autocross/roadrace section on these and what works well on 350Z's.
Old Mar 30, 2007 | 07:00 AM
John's Avatar
John
https://my350z.com/forum/autocross-road/256274-who-makes-small-track-tire-trailers.html
Old Mar 30, 2007 | 07:16 AM
Kolia's Avatar
Kolia
Old Mar 30, 2007 | 09:02 AM
BlackoutZ's Avatar
BlackoutZ
Thanks alot guys. I would like to get a hitch that is hidden when its not there and not have to cut a hole in the bumper. I dont know if this is possible but what do yall think.
Russell- Ive decited to start going to track events around texas so I need a tire trailer. Cant wait!!!! Ordering the RA-1s real soon!!!!
Old Mar 30, 2007 | 09:29 AM
John's Avatar
John
Definitely search - there's a lengthy thread in this sub-forum of a hitch that roark designed. Search for "hitch"...
Old Mar 30, 2007 | 09:31 AM
first350's Avatar
first350
search for SN "drivesolo" ... his trailer hitch is the most hidden I've seen. I've also seen a few vettes that have the hitch come through the license plate area...the license plate has a hinge on the top and allows the hitch to come through the bumper - when it's not there, the license plate looks normal (no hole)
-Peter
Old Mar 30, 2007 | 10:09 AM
BlackoutZ's Avatar
BlackoutZ
Thanks alot for the information!!! I will do some searching!!
Old Mar 30, 2007 | 11:17 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
That why I was mentioning Blaine, you really need to tow your car to events in case it breaks down you can tow it back. You got a Dodge ram, just get a trailer! :P
Old Mar 30, 2007 | 11:37 AM
MoodDude's Avatar
MoodDude
I second trailer the car to the track, if you have a truck that can tow 5,000# already, spend your money on a car trailer! I started trailering begging in Sept last year, and already I have really needed twice. Once because I wore out a set of new brake pads (7 hours at Sebring will do that), and the other time since the engine gave up.
Plus, with the truck you can haul so much more to the track that will save you time and money. Especially if you haul your fuel with you instead of buying it at the track.
If you don't have a truck, than a tire trailer is a great option. It is really easy. The cheasest and easiest way is to buy a couple pieces of pipe long enought so that when two tires are stacked ontop of one another the pipe is a couple of inches longer, tread it onto a flange, bolt/nail the flange on to the bed of the trailer so that the pipe is vertical, put your center of you wheel around the pipe. Then just use some bungy cords so the wheels don't jump off the pipe when driving.
I did mine a little different and built a steal rack to cradel the wheels in the upright possition. This cost more, but gives you more space on the trailer.
Old Mar 31, 2007 | 10:04 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
A guy is selling one on our SPOKES list for autox Blaine. See your PM.
Old Mar 31, 2007 | 10:12 AM
JasonZ-YA's Avatar
JasonZ-YA
i 2nd the motion on a car trailer! call this place. i just talked to them yesterday and havnt had a chance to check out their trailer yet. They say they have a car specific trailer with two 3500 lb axles for $2050 bucks brand new!
im planning to go check it out monday or tuesday morning...
right now i use a utility trailer for my car hauling needs! which works fine but it would be nice to have a car trailer for ease!
i maybe selling my utility trailer if your really interested. pm me.
Afordable Trailers - SA local company!
210-699-6000
Old Mar 31, 2007 | 10:22 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Jason, the trailer you are talking about, do you think a 06+ Frontier with the 4.0VQ can pull it with a Z on the back safely long distances? It supposely can pull 6500 lb.
Old Mar 31, 2007 | 10:47 AM
MoodDude's Avatar
MoodDude
I believe the Frontier hauling capacity is 5000#, but don't quote me on it. You car weights about 3400# and open trailers range from 800# to 1500# so you will be towing around a maximum of 4900#. Now if you just don't put any fuel in the car while towing you are looking at a total of 4750# max.
Just make sure the tailer you get has electric brakes, your load is properly distributed on the trailer, and you drive defensively, and the Frontier will safely get you and your car to the race track. With electric brakes on the trailer, the truck will stop in as short or short distance than just the truck alone, if you don't have electric brakes - hang on.
Old Apr 1, 2007 | 12:27 AM
mhoward1's Avatar
mhoward1
Personally, and from several places I have read, I wouldn't tow more than 70% of you capacity over a distance. Max loads are calculated on short straight line instances. The do not take in account heat build up, inclines, etc.
Old Apr 1, 2007 | 04:54 AM
Kolia's Avatar
Kolia
They 70% (or 40% or 60% depending who you talk to) is more for comfort than safety. The truck should be able to tow 100% all day long. There is already a good safety margin built into the truck rating.
I wouldn't worry about the Frontier. You'll have to take more care than with a full size pickup, driving slower etc. But it'll do it.
Old Apr 1, 2007 | 07:01 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
The 05+ Frontier bodystyles have a 6500lb towing capacity. It is not 5k.
Old Apr 1, 2007 | 09:05 AM
MoodDude's Avatar
MoodDude
That is even better, the Frontier should have no problem pulling an open car trailer and car. Just check the wheel base of the truck vs the trailer. If the trailer is longer you will need a load distribution hitch.
Old Apr 2, 2007 | 05:19 AM
mhoward1's Avatar
mhoward1
There are some other reasons for the 70-80% rule. Towing capacity is based on a vehicles GCWR rating, minus is curb weight of a base model, a 170 lbs driver and all fluids at sea level.
So let's look at the Frontier.
The GCWR is 11,133.
The Base model Curb Wieght is 4,200. The rest is fluid and driver. So now you have your 6,500 towing capacity.
Now add 200-500 lbs of options. Add your tools and gear. Add a passenger or two. Then calculate a 2% loss of power for every 1000 ft above sea level. Calculate a 5%-10% loss of Capacity for every 10 Degrees of elevation angle. It doesn't take much to be at 100% of capacity. That's why most towing accessory places recommend a 20% buffer of capacity.
