Stock 17's with 255's all around??
I need to know if this set up is possible for now until I can get some track dedicated rims. Im going to get the Toyo RA-1's
Has any body ever used this setup or does someone have a set of the rear 17 by 8's for sale ???
Thanks
Blaine
Thanks
Blaine
I suggest you turn off all your VDC/TCS if you go with high grip tires, they will kick on for no reason with those tires. My car cut out on me in the middle of a high speed corner because the TCS thought I was spinning wheels, I thought I was gonna die when the car cut power.
I run Kumho Ecsta MX tires with 245/45/17 Front 255/45/17 Rear on factory Enthusiast wheels and have been very happy. Good grip on street and track, low price, no ABS/TCS problems. I used a tire calcuator and found it would not significantly alter my speedometer either.
Originally Posted by BlackoutZ
Only drag is that the RA-1s dont come in 245's. Are there any other recomendations for a long lasting road race tire??
Originally Posted by davidv
Standard 17":
Alum Alloy
F-17x7.5
23.259lbs
R-17x8
24.140lbs
I recommend a maximum of
Front 245 mm
Rear 255 mm
Alum Alloy
F-17x7.5
23.259lbs
R-17x8
24.140lbs
Front 245 mm
Rear 255 mm
255 may be a bit wide for the front 17's. that tire width stock is 225 i think. i run 245/45/17 on all four corners on the track. i turn off my vdc but no abs problems or anything else related. with a 255 on the front i would worry about it rolling.
Perhaps you missed my post.
I just finished a set of 255 on the stock front 17's. I just mounted some GIANT 275 710's. On the 17x7.5" fronts and 17x8" rears. As long as the PSI is kept over about 35, there shouldn't be any issues.
