Track days Toyo RA1 tire pressure /size recommendation
I ran on brand new RA1 275/40/17 all way around yesterdat for my track day, but I felt the car was underpower with this set up comparing to last year when I had 245 all around, I am thinking they might be too wide for track days. Are they too wide for track use?
Being unshaved and brand new, they were slippery too... At the last session, I set cold pressure to 32 (In the begining when I set it to 36 cold, the pressure went up to 46-7 after the heat), is that a correct pressure?
Fab
Fab
Fab
Fab
Wider tires can be slower if you don't drive them right - so overdoing your steering input will scrub off speed much faster with your larger contact patch. Where you able to put a good heat cycle into the tires before you used them? If not, then your tires will likely heat cycle out prematurely.
Your cold pressures will vary, but I usually started around 29-31 depending on the ambient temp (if it was 30 degrees, then I'd start around 31-32). You ideal hot tire temp should be 39-41psi on the RA1s...
Originally Posted by John
275s aren't too wide, that just means you're not moving fast enough.
I think you are right, I am not moving fast enuf, I still take corners at the same speed as when I had narrower tires. I guess I am not taking corners fast enough. By driving them right, do you mean by this?
Originally Posted by commasense
I sure hope not, because that's my exact setup for this year! I'll let you know after my first track day this Thursday. How long have you been tracking the car, and how many track days have you done?
Yes, start around 32 and get to around 40-41 hot.
Thanks for your info John and sorry to hear your mishap...
28 Front -29 Rear psi morning cold is it's going to be 70-80F. Less if warmer. It goes down to ~40psi by the time I get to the pits.
I run 255/40R17 front and 275/40R17 rear.
-Peter
275's all around are perfect for an NA Z. i personnaly run around 28-29 psi cold and it usually gets upto 35-38 psi hot. also you shouldnt be fooled into thinking your slower cause of these tires. with the 275's you have a higher tire break away point. so just because the tires are not making any noise or close to the break away point doesnt mean your not going faster. a lap time comparrison would be best, and i am willing to bet even though you feel slower. your lap times are the same if not faster then before. i have also ran 275 hoosiers all around and they tend to be a bit wider then most tires the car actually felt more responsive and nimble, i guess that can be attributed to the sidewall of the hoosiers, but in any case do you have your laptimes from before and after the new tire setup?
Hammad
Hammad
Everybody has is own opinion and a preference on tire size. Which one is the absolute best will depend on driving style, car setup and track layout. Frankly, it's pretty much irrelevant since we're only doing HPDE with no lap timing...
And if we were racing, we'd be limited by the class rules.
275 all around or staggered 255/275?
I try to keep my electronics happier by not messing too much with tire size. Plus, on a relatively stock Z, I'm not sure the added front loading made possible with the wider front tire would be much more fun. More suspension travel with the car's bump steer and caster will make the car pretty lively on corner exit. I don't know.
I'm assuming anybody running R-comp has at least a damper upgrade?
Oh, and driving on rails is boring to the max. I'd rather take 20 seconds more per lap playing on the limit, semi-drifting every corner. I'm only running r-comp so the tires can last a full 25 minutes session without going greasy on me. Nothing to do with lap time.
Whatever floats your boat...
Hammad
Hammad
What front camber are you running? With 275's all around you should consider running 2.5 to 3.0 negative in the front. That extra rubber will really bite. What temp to set cold depends on the track and the ambient air temp, but I like 31.5 on the Toyo/Nitto, and adjust up or down depending on the other factors.
Frankly, moving up to that rubber and matching your best times, is a good sign. You will get used to them and start pushing the times down.
Everyone has given you good advice above, but I want to add one thing. Full tread toyos are downright scary for the first 2 days. The slipperyness you describe in your first post may very well be due to tread squirm.
Give em a couple more days and they will be just fine.
Thanks so much for all the advice guys! What a group of cool people to be around with.
I have -2.7' F and -2.2' rear. Should I run these tires on the street or highway for the next month or so before my next track event hopefully to wear them down a bit?
On my other post, I have asked a question about trailbraking in the Z. How's everybody's experience in this? I prefer to be able to brake a bit later and trail the brakes into the corner but I never purposely did that on the Z from what I've been hearing ( I guess I will find out if I just try it, but I want to see what you guys think).
