pics of my autopower roll bar and track wheels.
Old Jun 25, 2007 | 08:28 PM
Axelerate's Avatar
Axelerate
Default pics of my autopower roll bar and track wheels.
I've had the bar for a couple of weeks and I finally got around to taking pics while I was getting ready for a track event.
The bar is a Autopower race roll bar with removeable harness and cross bar. The main hoop is welded in. I got it because it doesnt limit the passenger seat room as much, plus I can take out the cross bar completly to regain all of the leg room.
here are my track wheels. 17x9 el cheapo MB motorings with 275 Hankook Z212 R's.
2 degrees negative, I'm not running adjustable arms as of now.
Boring street wheels. Car is a little higher in this pic since I just took it off the jack.
Old Jun 25, 2007 | 08:32 PM
tresfifdeeZ's Avatar
tresfifdeeZ
nice!
Old Jun 25, 2007 | 08:34 PM
z33boi's Avatar
z33boi
i likey
Old Jun 25, 2007 | 09:07 PM
Tekwon-V's Avatar
Tekwon-V
that looks uber sweet. i am thinking about getting the same one.... can you use the OE seat belt still w/o a problem?
Old Jun 25, 2007 | 09:08 PM
Guy the Larry's Avatar
Guy the Larry
looks awesome...
Old Jun 25, 2007 | 09:18 PM
Axelerate's Avatar
Axelerate
Yep, no drawbacks to the bar at all actually.
Old Jun 25, 2007 | 09:24 PM
terrasmak's Avatar
Very , very nice.
Old Jun 26, 2007 | 03:29 AM
Stack's Avatar
Stack
Bar looks great Jim!
Now... until you get some proper race seats in there, take those sub straps and run them from behind the seat, through the joint, so you're sitting on them when seated.
Old Jun 26, 2007 | 03:50 AM
Billhyco's Avatar
Billhyco
have any pics of where the rear bars are mounted. also pics of where it goes thru the rear strut mount plastic??? thanks!
Old Jun 26, 2007 | 05:03 AM
Axelerate's Avatar
Axelerate
Wrong Z. He lives about 5 minutes from me!
No, but I can take some.
Old Jun 26, 2007 | 05:11 AM
Julian@MRC's Avatar
Julian@MRC
I have yet to see a bolt in roll bar that appears to be safe..This one looks as if in the event of a roll over, or side impact, you will bounce your head off the bar, causing injury. The seat needs to be way up for this roll bar to not come in contact with your helmet from what I can see..
Old Jun 26, 2007 | 06:08 AM
Axelerate's Avatar
Axelerate
No the bar is behind the seat, there is no way my head could hit it with helmet on or not, even the seat all the way back.
Old Jun 26, 2007 | 06:40 AM
THE TECH's Avatar
THE TECH
Nice job.
Old Jun 26, 2007 | 07:27 AM
betamotorsports's Avatar
betamotorsports
Depending on the track or the sanctioning body running the event, you'll probably have to put some SFI padding on the bar in areas where its possible for your helmeted head to contact it. And seat backs move 3 to 6" rearward in a hard impact or roll over. Push on the seat as hard as you can and then figure it will move back another 6". That will give you an idea of how much it moves.
Old Jun 26, 2007 | 08:58 AM
merlot350Z's Avatar
merlot350Z
John is right, pad the bars that are anywhere near you. Use the high density padding, not that spongy junk. You would be very suprised how far the human body will stretch in a really hard hit. Pad everywhere around you head, shoulders, and legs. You can install the padding with tie-wraps. The high density stuff come with adhesive inside, but you dont have to permantly glue the stuff in if you tie the wraps tight enough.
Old Jun 26, 2007 | 09:00 AM
Axelerate's Avatar
Axelerate
My drivers seat is not as far back as the passenger seat, and while on track I move the seat back forward. I have the clearance, and I have roll bar padding already, I just havent put it on yet.
Old Jun 26, 2007 | 09:09 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
im not usually a big fan of the autopower bars but this one looks very nice.
-Don
Old Jun 27, 2007 | 09:11 AM
Tekwon-V's Avatar
Tekwon-V
while on the roll bar subject... what are our options? who makes a kit for the 350z?
i really do like op's setup... but always want to look into every option before commiting to it
Old Jun 27, 2007 | 09:18 AM
Flee0588's Avatar
Flee0588
Looking good.
Old Jun 27, 2007 | 03:27 PM
Axelerate's Avatar
Axelerate
Kirk and autopower make "kits."
The Kirk is a bolt in roll bar, but it limits the passenger room a great deal.
The autopower has to be welded in, but it gives you more passenger room, plus you can bolt out the harness and the cross bar to give you more room.
If you want anything else you can always go custom for a little more $$$.
