CG-Lock
Old Aug 15, 2007 | 08:51 AM
Lucino's Avatar
Lucino
Default CG-Lock
Waiting to receive my CG-Lock for track use.
I want to get some feedback from anyone that owns one.
I heard it might rip and scratch the seat belt after a while?
For those who don't know check it out here.
http://www.cg-lock.com/
Old Aug 15, 2007 | 09:00 AM
DavesZ#3's Avatar
DavesZ#3
I've been using one for about a year now and haven't seen a problem with it scratching anything. I'm careful to not let it bang into the door panels when taking the seat belt off though.
I like it - easy to adjust, holds as tight as you want, easy to loosen.
Old Aug 15, 2007 | 09:34 AM
z-u-later's Avatar
z-u-later
^+1
I've had mine for almost a year now & am using it for the street also. My butt is more comfortable driving when its secured on the seat.
Old Aug 15, 2007 | 09:35 AM
shinkuu's Avatar
shinkuu
my friend was too cheap to buy a cg lock so he got one of those baby seat clips. worked just as good but takes time to get it on. you can also twist the end of your seat belt for less slack.
Old Aug 15, 2007 | 12:23 PM
Billhyco's Avatar
Billhyco
i use the twist method. i get the belt as tight as I can, grab both straps and slide the seat all the way back. i then twist the hell out of it and slide the seat up further then the orignal setting. never loosens and didn't have to buy anything there is also a ratcheting method for the pass but i don't know how that works.
Old Aug 15, 2007 | 02:22 PM
joeygill's Avatar
joeygill
I've used them for about 1 yr, doing HPDE and auto-x. They do what they are supposed to, and it helps a good bit. Of course, they are nowhere nearly as effective as having proper harnesses.
I can see how it could put extra wear on the belts etc, but mainly if you're not careful with it (like DavesZ mentioned). With proper use, the extra wear should be very minimal.
Also, I have a spare set lying around unused if anyone wants to buy them.
Old Aug 16, 2007 | 05:14 AM
mberthia's Avatar
mberthia
I got mine recently and used it for two track days.
Prior to that I would 1)release the seat back to lower it 2) pull quickly on the shoulder belt to make it engage 3) return the seat back to driving position. With this method, both the lap portion and the shoulder portion of the belt was tight. The one problem I had was in releasing the buckle coming back into the pits. Under tension the buckle is hard to release.
With the CG lock, it only tightens the lap belt not the shoulder belt but there is no problem with releasing the buckle. I also hit the CG lock with my elbow while driving/shifting. Either method is a compromise.
Old Aug 16, 2007 | 05:27 AM
Lawy'dU's Avatar
Lawy'dU
I bought one years ago for auto-X and have never had any problems.
Old Aug 16, 2007 | 09:36 PM
Tekwon-V's Avatar
Tekwon-V
i use it everyday and i've used it on a track day once. it's ok... not the best thing in the world but it does what it's supposed to do.
it does put extra wear/tear on the belt but it's not too noticeable. i had it for a year.
Old Aug 17, 2007 | 03:40 AM
DavesZ#3's Avatar
DavesZ#3
Because it works by putting friction on the belt, in theory it could cause wear over time. That's why I wouldn't use it daily and keep it for Autox and track use.
Old Aug 17, 2007 | 02:39 PM
Lucino's Avatar
Lucino
noted.
thanks.
Old Sep 1, 2007 | 06:36 AM
Lawn Dart's Avatar
Lawn Dart
Love it.
Old Sep 14, 2007 | 01:20 PM
RKnight's Avatar
RKnight
Works well. If you were unlucky enough to have an accident and your arm hit the metal edge of it, I'm sure you would get a nasty cut.
Old Sep 14, 2007 | 08:01 PM
z-u-later's Avatar
z-u-later
There are worse things that can happen to you in an accident.
Old Sep 15, 2007 | 03:20 PM
DmanG281's Avatar
DmanG281
I used to just twist my belt until it was tight. I imagine this is the 40 dollar way to do that?
Old Sep 15, 2007 | 03:52 PM
LaoSiFu's Avatar
LaoSiFu
you guys mind educating me on what is a CG Lock. I have a mental picture of what you guys had describe.
~Robert
Old Sep 15, 2007 | 04:54 PM
PedalFaster's Avatar
PedalFaster
After a year of use, the section of belt that my CG-Lock clamped onto was subtly but definitely frayed.
Old Sep 15, 2007 | 04:55 PM
PedalFaster
Old Sep 15, 2007 | 11:07 PM
dampy's Avatar
dampy
laosifu - i think david has one. you can check it out next week.
Old Sep 16, 2007 | 12:48 AM
LaoSiFu's Avatar
LaoSiFu
better yet, I will take his
~Robert
