Got back from Streets of Willow and need advice
Old Mar 29, 2008 | 10:31 PM
  #41
sosojeffcc's Avatar
sosojeffcc
i agree with not worrying too much about heel-toeing. if you get it, great, but I find that it just messes with trying to be smooth.
What helped me the first couple of times out there was just trying to be as smooth as possible with the inputs, and concentrating on the line.
Old Mar 30, 2008 | 05:38 AM
  #42
mhoward1's Avatar
mhoward1
yes, heel and toe is a secondary skill that can be worked on after you have good braking and steering inputs. Before I worked on them I would work on good smooth straightline braking, correct turn in points and a consistent line. I would also work on shuffle steering before H&T.
Old Mar 30, 2008 | 10:40 PM
  #43
shinkuu's Avatar
shinkuu
Originally Posted by dampy
shinkuu, are you going to be at buttonwillow in april?
yes i am registered for friday and sunday and will be responsible for posting up all timing. btw do u have any more pics of me =0)
Old Mar 31, 2008 | 08:22 AM
  #44
dampy's Avatar
dampy
i do! i'm at work right now, but will upload them when i get home.
Old Mar 31, 2008 | 12:06 PM
  #45
IP Gthreefive's Avatar
IP Gthreefive
buttonwillow FTW~!
Old Apr 1, 2008 | 08:48 PM
  #46
dampy's Avatar
dampy
i pm'd you your pictures.
the db sure stands out!
Old Apr 2, 2008 | 03:23 PM
  #47
shinkuu's Avatar
shinkuu
thanks pix are awesome, i'll add it to my album.
Old Apr 7, 2008 | 02:48 PM
  #48
OPTIMO's Avatar
OPTIMO
I'm curious as to what instructor is telling you shuffle steering is a good idea on a circuit.
Old Apr 8, 2008 | 07:05 AM
  #49
mhoward1's Avatar
mhoward1
I would like to hear how others were taught or learned how to handle large steering inputs. Unless you have a vehicle with very quick steering, you will end up crossed on a tighter turn unless you are shuffle steering. That will greatly limit the amount of further input or completely lock you into a position with no recourse. We may just be having a difference of terminology.
Old Apr 8, 2008 | 06:53 PM
  #50
918 Z's Avatar
918 Z
for large steering inputs i would go hand over hand....smoother. i just dont remember how often that would have to be done on a track.
Old Apr 8, 2008 | 07:53 PM
  #51
n1cK!'s Avatar
n1cK!
Infiltrator!
...when all your looking at is a big wall, or another car i keed, i keed.
Old Apr 8, 2008 | 07:58 PM
  #52
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
There is one hairpin turn at our local course in Colorado, Pueblo Motor Sports park, turn 7. It is a very sharp hairpin tunr, and you have to both shift down to 2nd gear, and provide some pretty large sterring inputs. I usually go hand over hand for it.
Old Apr 9, 2008 | 04:11 AM
  #53
mhoward1's Avatar
mhoward1
Hand over hand means at some point your arms are crossing over each other and your hand positions are way less than ideal. I understand that it works for many but I prefer to shuffle steer and keep my arms on the correct sides of the wheel and have plenty of room for steering input. With this I can get a 1/4 turn before the transition to the other hand to get another 1/4 turn and so on. This shouldn't be any less smooth than hand over hand, and my hands never cross the center plain of the wheel. The only difference is where the hand to hand transition occurs. This also leaves a whole lot of input available instantly if needed. The other good side of it is if something does go wrong, my arms are not crossed if an airbag deploys.
Old Apr 9, 2008 | 12:51 PM
  #54
918 Z's Avatar
918 Z
very good point on airbag deployment. i guess i can propose this question on time attack forums and see what the response is.
Old Apr 9, 2008 | 01:49 PM
  #55
mhoward1's Avatar
mhoward1
Most of the Trans Am and Rolex GP/GT guys I run with use the Shuffle method, but there are still a few hand over hand hold outs as well. The T1/T2 ranks are truley mixed.
A lot of the Time attack guys are self taught so it will be interesting to see what their opinions are.
Old Apr 10, 2008 | 01:17 PM
  #56
918 Z's Avatar
918 Z
do you have some video of the shuffle method? i would lilke to see wxactly what your talking about. maybe i will try that out and see how i like it
edit: after reading again i think i understand. youre just changing from like 9 and 3 to 12 and 7?
Old Apr 10, 2008 | 01:50 PM
  #57
mhoward1's Avatar
mhoward1
Close, but not quite.
Example: making a right hand turn.
The left hand move the wheel by going from 9 to 12, the right hand meets the lefthand and continues the movement from 1 to 3 while the left hand returns to the 9 postition.
http://www.youtube.com/watch?v=q82MzANNgBg
http://www.youtube.com/watch?v=sMAOFNnzFr4
http://www.youtube.com/watch?v=NzBfr-xYdpg (at 55 seconds)
You don't need to do it much, only when the steering is over 1/2 turn or more, and most competiton cars don't need it at all since their steering ratios are so tight.
Old May 10, 2008 | 01:45 PM
  #58
LaoSiFu's Avatar
LaoSiFu
Well I am off to Street of Willow tomorrow. Hopefully everything I have learned from you guys have helped me. I am NOT exactly looking for shave off 10 secs but just improvement. Wish me luck guys!!!
and this time, I shall defeat my arch-nemesis dampy
~Robert
Old May 12, 2008 | 09:06 AM
  #59
LaoSiFu's Avatar
LaoSiFu
Just in case if you guys want to read up on my recent event, here is the link
https://my350z.com/forum/showthread....36#post5720536
~Robert
EnjukuRacing
Sep 30, 2015 06:55 AM
codek
Sep 28, 2015 03:03 AM
