exhaust for road racing
Old May 13, 2008 | 06:43 PM
s2k2nismo's Avatar
s2k2nismo
Default exhaust for road racing
i time attack my car alot....would you suggest a single exhaust or dual.....i would think the single would save weight
Old May 14, 2008 | 07:22 AM
betamotorsports's Avatar
betamotorsports
Less weight is better. What exhaust type, size, and routing depends on the modifications to your engine and what the rules are.
On a normally aspirated engine, properly designed and tuned single exhausts tend to produce a bigger area under the curve (both torque and horsepower). Even high horsepower V8 engines can benefit from a big single exhaust. In the high horsepower era of TransAm, the cars ran 180 degree headers that merged into a 5 or 6" single exhaust that basically filled up the passenger side of the car and exitted out the passenger door. These elaborate exhuast systems added 40 to 60 more horsepower compared to the dual exhausts run previously.
Unfortunately, we can't fit something like that on the 350Z. But I still think a 3 or 3.5" single exhaust with a good merge collector and a Borla XR1 Raceline muffler will help the 350Z a bit more then any of the aftermarket dual exhausts out there. Hopefully I'll build one for my car later this year and test it.
Old May 14, 2008 | 07:31 AM
betamotorsports
BTW... the stock muffler on the 350Z helps generate a little rear downforce so keeping the same position/configuration with a replacement muffler is a good idea.
Motormouth's Avatar
Motormouth
what about db level restrictions?
Old May 14, 2008 | 09:42 AM
stuntman's Avatar
stuntman
The 'downforce' from the aerodynamics of the stock muffler are minimal if anything. At most, it just cleans up the air under and exiting the car -primarily for drag/mpg purposes than adding downward force/grip to your car. You will not notice a difference at all if you change the design/shape of your muffler.
0.02
Old May 15, 2008 | 12:14 PM
mcarlomagno's Avatar
mcarlomagno
dB level restrictions depend upon the club/league and track administration, i believe.
Old May 18, 2008 | 07:51 AM
Marc Mc's Avatar
Marc Mc
dB restrictions are track related here in Ca with Laguna being the toughest. I have seen guys fail with new exhaust that they were assured would pass.
Old May 18, 2008 | 06:00 PM
ke0ki2k's Avatar
ke0ki2k
friend of mine races an 01' Trans-Am series Camaro at the Mitty at Road Atlanta every year. ive seen the exhaust routing when he was working on it and it is WILD lookin lol. incredibly loud car. I'm doin Solo II and Time attack events and I'm plannin on swapping over to a single 3 in. after I get a spare set of track wheels/R-comps.
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
