Suggestions for Track Wheels (Pannonia Ring)
Old Nov 15, 2008 | 09:52 AM
  #41
bighungrydewees's Avatar
bighungrydewees
@bighungrydewees: yummy ... look's great, but i think the rear wheels are to widely ... hmmm ... what offset of the 8x10 do you drive?!
My rear offset is +25mm, with a 285 width tire.
i think beau's setup has the idea behind, that he can interchange his wheels from rear to front and so on ... because i will take 275/35 in front and 275/40 rear (so that i have no problems with the vdc) the benefit of the same width is zero ...
This isn't a bad idea. (Same front and back that is). Plus if you wanted to have a slightly staggered look you could buy 5 to 10mm spacers for the rear and replace rear studs.
Old Nov 15, 2008 | 10:58 AM
  #42
TCO's Avatar
TCO
hmmm ... so there is no benefit, if i run 10x18 instead of 9x18 in the rear with the same tirewidth (275/40)?
Old Nov 15, 2008 | 11:14 AM
  #43
bighungrydewees
Not really... like I said earlier, if you want to stick with 275's all around just use the same wheel width all around.
Keep in mind when your shopping for wheels that you may run across a few 9.5" wide wheels. I think that's a great width for 275's.
http://www.workwheelsusa.com/media/w...Kai%20Spec.pdf
The Work wheel is just a suggestion since it comes in the right offsets.
Old Nov 15, 2008 | 11:45 AM
  #44
TCO's Avatar
TCO
well ... slowly i understand ... after reading this thread pages ( https://my350z.com/forum/autocross-r...e-sizes-3.html ) and your comments
so the recommended rim-width for an 275 tire is 9.5 ... but in front that rim-dimension is nearly a little bit to much, isn't it?!
in that way i think about the following combo:
F: 9.0x18et30 with 275/35/18
R: 9.5x18et?? with 275/40/18
Old Nov 15, 2008 | 12:25 PM
  #45
Beau's Avatar
Beau
I've heard of people running a 9.5" wide wheel with +30 offset. That would be VERY close to hitting the suspension though, but apparently it works.
http://www.1010tires.com/WheelOffsetCalculator.asp
I'm PRETTY sure a 9.5 +25 offset would NOT stick out past the fender even with factory camber. The calculator I referenced says it would stick out 11mm farther than my current setup. I'll do a quick measurement next time I go outside.
I don't think there would be any benefit to running a wider wheel in the back. It would just make the tire look stretched while the front looks normal.
Old Nov 15, 2008 | 12:52 PM
  #46
Beau's Avatar
Beau
Ok, just checked. Eyeballing where the top edge of the wheel sits in relation to the fenders, it's close. I'd estimate about 5mm clearance before the top edge of the wheel is sticking out beyond the fender. Probably all comes down to how strict the rules are in Austria. With a little added camber it would be fine most likely.
Old Nov 15, 2008 | 01:26 PM
  #47
TCO's Avatar
TCO
beau ... i have to say ... many thanks to you!!!! ... for that reason, i am right ... my setup above will be the right one to clear all rules in austria ... unfortunately the authorities here are very strict ...
Old Nov 15, 2008 | 01:36 PM
  #48
Beau's Avatar
Beau
No problem. My tires/wheels are definitely inside the wheel wells so you should be fine even with strict authorities. Much more than this and it may be pushing it. Better safe than sorry if you are spending that much money.
Old Nov 15, 2008 | 01:50 PM
  #49
JETPILOT's Avatar
JETPILOT
Originally Posted by bighungrydewees
I really hate to correct Jetpilot because he's damn near always right and I've personally learned alot from his suggestions and comments. But I believe the Advan's are made by Mackin/Rays.http://www.mackinindustries.com/md/y...aoriginal.html
Mackin Industries is an importer not a manufacturer. They import ADVAN and Ray's.
If you look at the inside of your wheel you will see stamped into the casting "MAT". MAT is Enkei' proprietary patented rim making processs used exclusively by Enkei.
There was also an article written by OG in his blog about visiting the Enkei manufacturing plant and talked about how several different wheel lines were manufactured there.
http://og-made.com/archives/706
Old Nov 15, 2008 | 02:00 PM
  #50
TCO's Avatar
TCO
you're absolutly right ... and once again ... many thanks to all guys that helped me to find the right choice for track wheels ... thank you very much
greetz thomas
Old Nov 15, 2008 | 07:36 PM
  #51
bighungrydewees
Oh. Nice!
It's weird to say it, but I think I'm glad I tried to correct you or else I may not have learned that. Sorry bout the misunderstanding, but thanks for setting me strait.
Old Nov 15, 2008 | 07:48 PM
  #52
JETPILOT's Avatar
JETPILOT
No problem mate!
