Question for those who autocross 350Z
Old Feb 5, 2009 | 06:20 AM
zcar_dad's Avatar
zcar_dad
Default Question for those who autocross 350Z
Got front and rear adjustible camber arms for Christmas. My 2007 Z is not lowered. Any suggestions on how much negative camber and toe in to set for autocrossing? Thanks
Old Feb 5, 2009 | 06:43 AM
plumpzz's Avatar
plumpzz
Try stock first and mod from there? It all depends on your total suspension setup I believe.
Old Feb 5, 2009 | 06:48 AM
AznSky's Avatar
AznSky
I'm kind of interested too to see what ppl run as I'll probably be getting suspension sometime this year.
Old Feb 5, 2009 | 07:11 AM
terrasmak's Avatar
1.5 to 2 front and 2 rear. I would wait to install for when you get your suspension
Old Feb 5, 2009 | 12:05 PM
zcar_dad's Avatar
zcar_dad
I have Hotchkiss sway bars with adjustible end links and Stillan chassis braces. Don't want to do coilovers just yet.
Old Feb 5, 2009 | 01:57 PM
julian's Avatar
julian
put more negative in the front than the rear. -2.5 front, -1.5 rear. 0 toe in front. 0 or slight toe in in rear
Old Jun 12, 2009 | 07:44 PM
Peak350's Avatar
Peak350
You probably like a looser car (I do as well).
I have ~2.7 front, 2.0 rear, and am very happy with how it drives. With 2.2 front it doesn't feel like enough, with 3.2 it feels like too much.
Old Jun 15, 2009 | 08:59 AM
ldstang50's Avatar
ldstang50
What it ultimately comes down in tires. A grippier tire will cause more body thus meaning you need more negative camber. Size tire is also something to consider as with roll stiffness. Hotchkiss bars will help with roll, but you still have stock springs/shocks. If you auto-x, the control arms (I believe) will put you in SSM
Old Jun 15, 2009 | 09:45 AM
guitarist's Avatar
guitarist
I'm pretty sure the 2009 rules allow control arms in BSP. But without a very expensive build up (like Peter Umino's old car) you're not going to be competitive in BSP either.
As for the OP's original question: I'd start at 2.0 negative camber in the front and 1.5 in the back and go from there based on tire temps, tire wear, and handling attributes. Test'n'tune, test'n'tune until the budget is gone or the setup is right.
Old Jun 15, 2009 | 06:47 PM
Z1NONLY's Avatar
Z1NONLY
My car ended up with -1.6 front and -2.2 rear, 1/8" toe out front and 1/8" toe in rear. (after my RSR Ti2000 springs)
I "run what I brung" at the track, but my car spends most of its time in the garage, so I wouldn't call it a DD.
That being said the weekend fun drives / occasional road trips / lots of autoX results in close-to-even tire wear.
The rear could use just a little less -camber though.
That's just a tire wear perspective though. I think another 1/2 degree of neg camber up front might make her a little faster, but I have yet to test that theory. (Too cheap/ lazy for A-arms.)
Old Jun 15, 2009 | 07:21 PM
Peak350's Avatar
Peak350
You can run control arms in BSP, and I think there is a street tire class pending for the Z (was talking about it yesterday with a local S2000 guy who runs regionals/nationals) so that could be fun.
Camber arms are allowed, however, only uppers, and you can't go with the SPL arms (legally, locally the guys I'm running said they don't care, they'll beat me regardless, but I still asked) because of the bushing material rules. You can't go to a different ratio of bushing material to metal than factory, which means for good arms, cusco more or less.
Edit, and to follow up, I still have understeer with -2.7 degrees of camber front, I set my front shocks stiffer to keep roll down, and stiffened the rear a ton and it helped, but I still think (looking at tire wear and handling characteristics, had no pyrometer) I might move to 3.2 for the next event.
Car could use sway bars though.
Old Jun 17, 2009 | 08:21 AM
ldstang50's Avatar
ldstang50
Thats good to know. I might do that for next season.
The z is excluded from the street tire class. The only z that is close to eligible is the vert. But the engine size is too large. Yet again, the z gets screwed.
http://scca.com/newsarticle.aspx?hub=3&news=3629
Old Jun 17, 2009 | 03:00 PM
scotts300's Avatar
scotts300
I can't believe you have all that camber nonsense with stock sway bars!
Old Jun 17, 2009 | 04:34 PM
Peak350's Avatar
Peak350
The transitional stability and roll was pretty well controlled. Shocks-springs-alignment- then sways. It's the way I was taught to set up a car.
Old Jun 17, 2009 | 09:18 PM
PDX_Racer's Avatar
PDX_Racer
Don't be too certain about that restriction. There are other cars on the list of "allowed" cars that are faster in stock form than the Z.
Old Jun 18, 2009 | 06:36 AM
guitarist's Avatar
guitarist
It seems pretty clear that they've ruled out the Z:
- Engine displacements up to 2.8-liters
Unless you're saying they will change the rules to let it in at some point in future. But that seems unlikely given the cars already in the class.
Old Jun 18, 2009 | 08:09 AM
Peak350's Avatar
Peak350
They should look into it. Local clubs have very popular street tire classes. A club I've been running with has a street mod street tire class that gets 1/3 of the days entries.
Old Jun 18, 2009 | 02:54 PM
guitman32's Avatar
guitman32
Yea it sounds like you need a rear bar to dial out that understeer. I would try dialing down the front shock stiffness also. And all this before paying for another alignment definitely (unless you set your camber yourself )
Old Jun 18, 2009 | 03:38 PM
Peak350's Avatar
Peak350
SPL arms use shims. The toe doesn't really get messed with (much) when you adjust, and the shims are measured.
My alignment was done at 3.2, I was thinking that was near 2.5 before I went in.
Old Jun 18, 2009 | 08:14 PM
PDX_Racer's Avatar
PDX_Racer
Why not? The S2000 is classed far faster than the Miata,
