Solo2 from last weekend, with video
SCCA Buccaneer Region Round 3
This is mine, 03 G35 coupe on street tires, running STU class. I took 1st in class and 11th overall out of 55 drivers
<object width="480" height="295"><param name="movie" value="http://www.youtube.com/v/M6DjizbqV40&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/M6DjizbqV40&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="295"></embed></object>
these are videos from some other folks, this one is a IS300, STX class
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/EZxqVtPwk-E&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/EZxqVtPwk-E&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/fDfJfg9H8wA&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/fDfJfg9H8wA&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
This one is Mini Cooper-S, G-stock class (Hoosier A6)
C5 Z06 in ASP class, running 295,315 size Toyo RA1
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/i8l1O32vvtQ&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/i8l1O32vvtQ&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/oAaCyG-id9Y&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/oAaCyG-id9Y&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Enjoy!
This is my 4th time autocrossing the G35 coupe, last year I drove my 96 Nissan 240sx in all of the events. On this G, I'm used to the stock tire size and running Dunlop Direzza Z1 Star spec, but this time I decided to borrow my brother's rear wheel, and rolling on Kuhmo Ecsta MX.
I love the Z1 star spec, possibly the best street tire out there, I even like it more than Bridgestone RE01R. Anyway, I gave the Kumho MX a try and compete in STU class instead (275 width rear). Since its a mismatch stagger setup, the wider rear tires make the car slower in the transition thru the slaloms when compare to the old 245 width tire setup; the car understeer more in the tight stuff but it holds a better line through some sweepers and lane change gates.
One thing I noticed is even with the 275 width rear, it didn't improve my exit as much as I expected, and the MX required a bit longer warm up time than Z1 star spec and Azenis RT615 that I'm used to. Also, one disadvantage of MX is it has a softer sidewall, I really don't like it that much. The car feel "washy" from side to side weight transfer.
Lastly, the factory VLSD had it, when I used to run 245 width rear tire, the LSD locks just fine, but this time I ran 275 width rear and I noticed the inside tire spun a lot more in the extra tight stuff. I'm sure after even more abuse and heat, the vicious LSD probably would behave like a open diff.
Anyway, I just want to share my thought about these matters
Enjoy!
Justin100
Nov 29, 2015 03:58 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Subarism
East Canada
Sep 23, 2015 06:23 PM
