completely removing airbag system?
Old May 27, 2009 | 07:55 PM
dmoffitt's Avatar
dmoffitt
Default completely removing airbag system?
I'd like to completely remove anything and everything related to the airbags - car is caged w/ fixed back, 5pt, hans, yadda yadda. anyway, we've had some touchy issues after the swap with NATS and so forth so I'm leary of pissing off the body control module or anything like that, stupid modern CAN bus cars, heh.
So... can I remove the bags, sensors, partial harnesses, computer etc for it without affecting the car's ability to start and if I do that, how do I get the idiot light to go away? Or should I just remove the bags and wire in resistor(s) as needed to "trick" the system?
Thanks in advance!
Old May 27, 2009 | 08:22 PM
diablox1's Avatar
diablox1
yes, and remove the "idiot light" bulb from behind the cluster.
Old May 27, 2009 | 08:48 PM
dmoffitt's Avatar
dmoffitt
it's a bulb? I always figured it was a surface-mount LED or something not to be messed with ...... last thing I want is to **** off some computer in the car by having it fail a continuity test on the "bulb" (or LED or whatever) and also have to buy a new cluster LOL
Old May 27, 2009 | 09:16 PM
PDX_Racer's Avatar
PDX_Racer
Electrical tape does wonders.
Just put some over the dash where the light is. Voila!
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
