Road Racing question
Old Aug 10, 2009 | 05:22 PM
mhoward1's Avatar
mhoward1
Originally Posted by Stack
Sounds like you'll do just fine at the time attack events
now now....
Old Aug 10, 2009 | 06:01 PM
Stack's Avatar
Stack
Originally Posted by mhoward1
now now....
What?
Old Aug 11, 2009 | 04:59 AM
Ataru074's Avatar
Ataru074
Originally Posted by Tsukuba-Z33
ya feel me?????
http://www.youtube.com/watch?v=pxqt-1oZ_pQ
my engine is stock.. just and exhaust and a reflash...
and the blue Z there is boosted, the 996 turbo is obviously boosted... but me, the spec miata, the lemons datsun 240 aren't.
what I feel is that you'll be another one to laugh at.
p.s. I was running kumho xs.. so no hoosier magic.
Old Aug 11, 2009 | 05:24 AM
Stack's Avatar
Stack
Very heads-up move there @ 2:33 driving off line behind that car that clearly blew something (Z32?)... but I gotta give you a hard time for something...
REALLY not a good idea to remove the airbag when you're wearing on open face helmet... looks like it's time for a new helmet and a H&N restraint device of some sort my friend
Old Aug 11, 2009 | 06:29 AM
Ataru074's Avatar
Ataru074
I already got it (the closed face) and a hans.. but I'm waiting to install the roll bar before going with the hans.. the 6 point harness is already "too much" w/o the roll bar
yeah.. on the Z32 that blew up I went off the line to avoid to build up oil on the tires on the straight.... (another lesson learned in the hard way long time ago)
Old Aug 11, 2009 | 07:00 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Time Attack ... uugh ... must ... resist ... urge to ...
I am interested to hear your opinion of Time Attack.
To the OP, running a turbo kit will NOT automatically put you in Modified class. You can run a 350Z with a twin turbo system, and still compete in Street Class. If you set the car up right, and learn to drive really well, you will be super competitive. I would love to see someone do this actually, becuase the Evo's and STi's always seem to clean up in Street Class.
With regards to powerband, in a perfect world of course we'd all like tons of power and trq from idle to redline. But like everything, there is a tradeoff. What is "better" can be hard to establish. Depends a lot on the track, but since the 350Z has very good midrange torq from the factory, I would prefer a little more top end, even at the expense of some midrange or bottom end trq. If you drive the car correctly, you will have all the trq and power you need from about 3500rpm to redline.
Old Aug 11, 2009 | 07:47 AM
scotts300's Avatar
scotts300
I see you posted that on 6/21/09. What date was the track day? That looks like the SPL Z32 that was smoking in front of you. . .
BTW, you or that DB Z33 at 4:10 is clearly in the wrong run group. Same goes for the MB at 7:35.
Old Aug 11, 2009 | 08:05 AM
Ataru074's Avatar
Ataru074
that was for the texas Z party.
yes, was Kuah with the SPL Z32.
the DB TT Z33 was driven in the advanced group by an instructor
the MB was an instructor at MSR testing the car I guess.
Old Aug 11, 2009 | 08:42 AM
kuah@splparts.com's Avatar
kuah@splparts.com
Vendor - Former Vendor
Had an oil line spring a leak, sorry The engine is fine though, admittedly at the time I thought the problem was a lot more serious, since I was "breaking in" the engine at 22psi of boost...
Old Aug 11, 2009 | 08:50 AM
scotts300's Avatar
scotts300
Kuah tells me he blew an oil line. Doh!
BTW - great lap: http://www.youtube.com/watch?v=hAKVX...eature=related
I've used that same telemetry system before, however, was there a way that you knew you had recorded your best lap (I saw the arm pump)?
Old Aug 11, 2009 | 09:41 AM
Ataru074's Avatar
Ataru074
was ONLY 2 sessions that I was lapping in the 1.50.x where x was 0, 1, 2 or 3.... when it did show 1.49.6 I was too happy.
then I started to slow down in the 1.50.x again just to have fun and mess with the other guys
actually also because my clutch was slipping, one of the steering wheel CV joint start having some play (the lower one just before the power steering rack), my brake pads where close to the end and after 5 sessions I was "a little" worn out with 100+ degrees outside in the afternoon.
one of the biggest issue was the heat soak with that temperature...
I had my best lap of the session after one or two full laps than I was just getting slower.
edit: nismo 350z in 1.49.6 http://www.vimeo.com/5257086
lotus exige in 1.49.4 http://www.vimeo.com/5990059
I'll try to edit them together to check the difference.
btw...
Old Aug 11, 2009 | 10:46 AM
scotts300's Avatar
scotts300
So the data logger can display your laps as you finish them after all? I've never seen that feature, but would love to have the instant feedback.
BTW, your line was much better than that Exige. Sorry, OP, for the thread jack.
Old Aug 11, 2009 | 11:05 AM
Ataru074's Avatar
Ataru074
yes it can... you have your choice between lap / split time or speed...
what I do is to setup the track using google earth at home, setup the splits "offline" using the rule of "major straights" and than use the speed in the first couple of sessions just to improve the line and the exit speed where it does matter...
when I start seeing that I'm consistent with that I switch to lap timing and to work out the "connections'
Old Aug 11, 2009 | 08:36 PM
Tsukuba-Z33's Avatar
Tsukuba-Z33
yeah but that boost z33 wasnt an agressive driver. he was braking on turns where you could have EASILY let off the gas, steer, and WOT.
to be honest that blue z33 owner drove like he was TOO worried about curbing his chrome wheels/crackin his body kit. lol
so yeah you laugh at him all you want. he wasnt even a serious competitor.
its almost like somebody sayin just because someone is 6 foot 5 they can automatically play basketball. height dont mean **** if you can use it. BUT if you DO have skills the taller you are the better. ie. HP aint **** if you cant control it. BUT if you CAN CONTROL it the MORE the BETTER. that boost'd Z wasnt **** because he couldnt MAXIMIZE/CONTROL his power. you were better than him because you COULD MAXIMIZE/CONTROL your POWER.
Old Aug 11, 2009 | 09:42 PM
scotts300's Avatar
scotts300
I'd rank horsepower pretty low on the list for a car to be fast around a road course. This is my personal list based on assuming the same car (i.e. 350z):
1. Driver
2. Tires
3. Brake set-up
4. Suspension
5. Horsepower and aero compete for fifth/sixth
Old Aug 12, 2009 | 04:39 AM
Ataru074's Avatar
Ataru074
actually the guy with the blue Z is a very nice guy so is his dad... but not impressive drivers... but your attitude is just the right one.
go ahead and have fun.
Old Aug 12, 2009 | 04:47 AM
mhoward1's Avatar
mhoward1
1. Driver
2. Tires
3. Brake set-up
4. Suspension
Mines a little different
  1. Driver
  2. driver
  3. driver
  4. brake pads and fluids
  5. Driver again
  6. driver
  7. driver
  8. Better street tires
  9. Driver
  10. driver
  11. driver
  12. Suspension tweeks (Sways, etc)
  13. Driver again
  14. driver
  15. driver
  16. driver
  17. driver
  18. Dot-R tires
  19. Driver again
  20. driver
  21. driver
  22. Suspension again
  23. Driver
  24. driver
  25. driver
  26. brakes revisited
  27. Driver
  28. driver
  29. driver
  30. HP maybe
  31. driver
  32. driver
  33. driver
so on and etc
Old Aug 12, 2009 | 05:48 AM
  #38
Sharif@Forged
Forged Performance
^^^LOL^^^ Good stuff.
Old Aug 12, 2009 | 09:42 AM
  #39
scotts300's Avatar
scotts300
  1. Driver
  2. driver
  3. driver
  5. Driver again
  6. driver
  7. driver
  9. Driver
  10. driver
  11. driver
  13. Driver again
  14. driver
  15. driver
  16. driver
  17. driver
  18. Dot-R tires
  19. Driver again
  20. driver
  21. driver
  23. Driver
  24. driver
  25. driver
  27. Driver
  28. driver
  29. driver
  30. HP maybe
  31. driver
  32. driver
  33. driver
so on and etc
So you are saying that HP is important. . . maybe.
Old Aug 12, 2009 | 10:14 PM
  #40
Tsukuba-Z33
HELL yeah power is important, you think that cyber evo makes it aound the tsukuba circuit in approx 54 sec with only 287 HP?????? or the mazda 787b runs great at 24hr endurance races with stock power output from TWO 13b motors????
NO... these cars have TONS of power with great Drivers. LOok at cheston's Z. he does time attack and has 550whp, Furthermore, the guy we all love Sharif from Forged Perfotmance has a high horsepower (500whp +) GTR he races. What about the M-Works 350z that runs at buttonwillow. that car was TONS of power.
So i dont see why there are stone faces. and people replying back like im idiot. YES driver/suspension are key but power also plays A GOOD ROLE in fast lap time. Im just concerned on how to model my POWERBAND when i get my tune in a couple of weeks.
