The Tire DB - Posts about Track and AutoX tire brands
Old Jul 8, 2008 | 08:40 AM
  #281
scotts300's Avatar
scotts300
Originally Posted by AznSky
Sorry to go a bit off topic, but what is everybody running as far as wheels (xx by xx +xx) and tire sizes (xx/xx/xx)? I'm looking at 17's, but may consider 18's in order to clear a BBK in the future. Just about to start tracking
I bought Enkei RPF-1s in 17x9.5 +38. These are a big aggressive for the Z33, but will fit with a tiny spacer. I bought this offset b/c they fit my Z32 and Z33 with the spacer. If I bought them specifically for the Z33, they would not fit the Z32. I have a full set of 275 Hoosiers, but if I can sell them, I'll probably get 295s.
Old Jul 9, 2008 | 05:31 PM
  #282
orangeflash's Avatar
orangeflash
Old Jul 10, 2008 | 07:21 AM
  #283
scotts300's Avatar
scotts300
Back OT about the 17x10 +25 FNs. I'm >< close to getting a set for the 350. The seller also has 295 and 315 A6 tires available, but looking at the pics Axelerate posted, it doesn't look like there is room for any increase in tire size given the offset. Can any of you guys with this set-up chime in with your thoughts for fitting more tire? I'm thinking a 295 may fit the rear, but would rub in the front.
Old Jul 10, 2008 | 08:12 AM
  #284
terrasmak's Avatar
Should fit no problem , they are 35 series right, still shorter that stock tire height.
Old Jul 10, 2008 | 10:27 AM
  #285
scotts300's Avatar
scotts300
They are 35 series, so yes - both are shorter than the stock 26.4" tire. My concern is if the extra width will hit the suspension upright on the inside or stick out past the fender on the outside.
Old Jul 10, 2008 | 06:04 PM
  #286
Axelerate's Avatar
Axelerate
It will fit the rear no problem, you might wanna run a 5mm spacer on the front to keep the tire from rubbing on the knuckle.
Old Jul 12, 2008 | 05:17 PM
  #287
2fast4ya's Avatar
2fast4ya
hey orangeflash, nice to see your pics posted up, looks good
i see the difference between yours and mine, looks like the model name
of the wheel on your spokes is engraved in the wheel compared to a
white decal on mine, also looks like your center cap is a little bit
different
Old Jul 13, 2008 | 02:11 PM
  #288
orangeflash
different
thanx man, I didnt even notice the different centercaps. I ended just settling on the 255's for the fronts becuase it was gonna take forever to get some 265's.
Old Jul 15, 2008 | 08:19 PM
  #289
TheBlack350z's Avatar
TheBlack350z
I'm interested in running this setup on the street but would fear of rubbing from the 275 front tire and feel that it would be wiser to use maybe the 17x9 with a 255/40 tire but the only problem is the 17x9 comes in a +15 offset or +35. Do you guys think the +15 offset rim would fit alright. I'm going to be using a coilover type suspension so I guess my next question would be what kinda camber should I run on the street to keep the tire wear down to a minimum on the front and rear. Strangely enough I see that the original poster is in Virginia Beach with me. Thnx
Old Jul 16, 2008 | 07:35 AM
  #290
scotts300's Avatar
scotts300
Originally Posted by Axelerate
In the pics I was lazy and left my 10mm spacer in the back. They rubbed slightly, which doesnt matter much because I was not planning on running it at the track.
I missed this the first time around. If you had a 10mm spacer with the 275 tire and it rubbed slightly, wouldn't that imply that a 295 tire (20mm wider) would also rub? The inside would be exactly where your set-up is withOUT the spacer (I assume that works), but the outside would be where your 275 set-up is WITH the spacer (which you said rubs slightly). Does that make sense?
Old Jul 16, 2008 | 07:38 AM
  #291
scotts300's Avatar
scotts300
He said the 17x10 +25 front does not rub with a 275. As an alternative, you could get the 17x9 with a smaller tire, but I'd rather have the ability to rotate.
Old Jul 16, 2008 | 12:44 PM
  #292
TheBlack350z
I know he can fit 275 on his fronts but he also may be running more camber in the front for them not to be rubbing the fender. I intend for this car to be mostly driven on the street so I may want to run less camber to keep wear down.
Old Jul 16, 2008 | 03:10 PM
  #293
Axelerate's Avatar
Axelerate
Not neccesarily since the tire will only be 10mm wider on the outside edge and it also depends on how low your car is. Since all tires are sized and shapped different it's hard to say. Some might be more square shaped, while others will be rounded off.
Mine only rubbed once under full compresion while on a "skid pad".
  #294
Axelerate's Avatar
Axelerate
How low is your car???
Old Jul 16, 2008 | 05:33 PM
  #295
TheBlack350z
It will be right around an inch drop nothing to crazy. Still toying around with the stock suspension and modding it ever so slightly as I learn how to drive the vehicle. I have the coilovers and hotchki swaybars currently just not installed yet. I still need to order my spl rear camber and front control arms.
Old Jul 16, 2008 | 05:42 PM
  #296
mw9's Avatar
mw9
thanks for the info, looking for a setup for autocross like that
Old Jul 17, 2008 | 08:03 AM
  #297
scotts300's Avatar
scotts300
This is what happens with stock shocks and springs:
Old Jul 17, 2008 | 04:06 PM
  #298
Kolia's Avatar
Kolia
You need camber in order to get anything really good cornering.
Front Upper A-arms are the key.
I'd even say change those before sways, damper and springs.
Old Jul 17, 2008 | 04:14 PM
  #299
laze1's Avatar
laze1
S W A Y B A R S !!
Old Jul 17, 2008 | 04:32 PM
  #300
stunnashadeson's Avatar
stunnashadeson
hey scotts300, what wheels do you have on your car? i haven't seen those before? are they real 3 piece?
