Track Junkies w/ VQs - Is an oil cooler a must have?
Old Oct 12, 2009 | 05:02 PM
  #101
Zazz93's Avatar
Zazz93
Originally Posted by Ataru074
I pretty much self assembled the setup that GTM sells using a setrab 19 row cooler and the same mocal thermostatic adapter.
I have a VQ35HR
What are the dimensions of the cooler? (roughly)
Old Oct 12, 2009 | 05:46 PM
  #102
Zazz93's Avatar
Zazz93
Also, Anyone know if there is a oil temp gauge for one of the Z33 models.
Old Oct 13, 2009 | 03:45 AM
  #103
Ataru074's Avatar
Ataru074
Originally Posted by guitman32
He asked if the temp ranges listed were for a warmed up engine. What you're saying confirms what I said - if you're getting 15 psi at idle, you're definitely warmed up and not on cold oil.
yes, but it really takes a while to warm up in "regular driving condition".
Old Oct 13, 2009 | 03:49 AM
  #104
Ataru074's Avatar
Ataru074
roughly? reputable companies provide all the info you need.
http://www.setrabusa.com/pdf/ProLine-Dims-Apps.pdf
the 19 row I have is the p/n 50-619-7612.
Old Oct 14, 2009 | 12:01 AM
  #105
Zazz93's Avatar
Zazz93
Thanks!
Old Jun 12, 2012 | 05:51 PM
  #106
thekinn's Avatar
thekinn
Bumping an old thread.. but I (finally) got my oil temp gauge installed via AAM oil pan spacer.. and (finally) got back out the track. It's a local 1.5 mile course on a warm 80degree cloudy day. I saw oil temps above 280F in my '06 revup.
Now I know why oil analysis saw my 10w30 oil being sheered down to a 20W. Just an example of what temps your oil is seeing on a track day.
so yeah.. I'm starting to shop.
Old Jun 12, 2012 | 11:57 PM
  #107
thespottedcow's Avatar
thespottedcow
Mine was hitting 280-300+ consistently after a few laps regardless of the temps outside, my oil cooler is on its way
Old Jun 13, 2012 | 12:17 AM
  #108
terrasmak's Avatar
Wow thats hot, guess i need to get my gauge installed, its been sitting at home for the past 4 years.
Old Jun 13, 2012 | 06:58 AM
  #109
betamotorsports's Avatar
betamotorsports
A lot depends on where you're reading the oil temps. If 280F is the oil temp as its getting back into the pan then that's not a bad number. If 280F is the temp of the oil coming out of the pan and into the engine then you need to cool it down.
Also, regarding the oil analysis showing the base viscosity at 20W for a 10W-30 oil; isn't the base oil viscosity the lower number (10) and the additive package is what increases the viscosity to 30 when the polymer chains unwind due to heat?
Old Jun 13, 2012 | 12:26 PM
  #110
thekinn's Avatar
thekinn
I think I misspoke with my comment above 'sheering down to 20W' - Blackstone noted a lower viscosity number (than normal) on the oil that I had analyzed. Sorry for the confusion there.
My 280F+ reading was from the sensor sitting in the oil pan (spacer). (Defi gauge and sensor).
Old Jun 13, 2012 | 05:42 PM
  #111
thespottedcow
I know the best place to have the sensor is in the pan, but I just have mine in a sandwich plate, not sure how accurate that spot is, but when I installed it, I figured it was better than nothing
Old Jun 14, 2012 | 07:32 AM
  #112
betamotorsports
If possible, the best place to check oil temp is coming out of the cooler back into the engine. That will help determine if the cooler has enough capacity.
Old Jun 27, 2012 | 01:37 PM
  #113
SE5spd's Avatar
SE5spd
My sensor on my oil temp gauge is where the oil filter sits and my temps
Get to about 260f or so. Is my sensor in an accurate place?
Old Jun 28, 2012 | 01:53 AM
  #114
mw9's Avatar
mw9
I will have to try that
Old Jun 28, 2012 | 08:16 AM
  #115
betamotorsports
As I posted in another thread, when monitoring oil (or any temp) is:
1. The change in temp - does it rise and stabilize or continue to rise?
2. The rate of change - steady of spikey?
3. The actual temp.
Notice the actual temp is the least important.
If the temp rises and stabilizes then there's enough BTU capacity in the cooling system. It might stabilize at a temp that you consider too high, but the system is working.
If the temp continues to rise then there is not enough BTU capacity and the system needs to be changed.
If the system rises at a steady linear pace then its well damped and the heat exchange is occurring. If the system spikes then there is air in the system and/or the heat exchanger is shrouded and not working properly.
If the actual temp is too high (or too low) then increase/decrease air or fluid flow through the heat exchanger or increase/decrease the heat exchanger capacity.
Data logging is the best way to evaluate this. If you can't do that, then check and log the oil temp at least once per lap in the exactly same place on track. Its better if you check in two place on track every lap.
apex locator
Jul 23, 2021 02:27 AM
JjL
East Canada
Jun 12, 2019 03:04 AM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
May 12, 2016 07:42 PM
