Better wheel studs?
Old Jan 18, 2010 | 09:30 PM
QuicksilverZ33's Avatar
QuicksilverZ33
Arp's
Old Jan 19, 2010 | 03:21 AM
laze1's Avatar
laze1
you should use a torque wrench for this.
Originally Posted by christoc
I broke a ton of them on my old 350z, almost one a weekend. I ended up going with the NISMO studs on the front, never did put them on the rear. At that time though I changed from using a 4-way bar to just a socket, that severely cut down on the number of studs I broke. In fact I don't think I broke any of the rears after stopping using the 4-way bar.
Old Jan 19, 2010 | 03:39 AM
DavesZ#3's Avatar
DavesZ#3
^^^ Exactly ^^^
Old Jan 19, 2010 | 03:44 AM
mw9's Avatar
mw9
^^it surprises me that people don't use torque a wrench on their lug nuts, kinda scary if you ask me
Old Jan 19, 2010 | 04:03 AM
JasonZ-YA's Avatar
JasonZ-YA
Originally Posted by DavesZ#3
Wow, after 5+ years of autocrossing and track days with regular changes between street wheels and my autocross and track wheels, I have never broken a stud or stripped one or had a problem with lug nuts.
How are you removing them and better yet, putting them on? Impact wrench?
You should be tightening them with a torque wrench, never with an impact wrench. Also, at least once a year you need to put some anti-seize compound on the studs.
Better studs may be a cure but it sure seems you've got to be doing something else wrong to be regularly breaking studs.
I agree.....
Ive done tons of wheel changes for autoX and mostly drift events.
I know friends of mine (aaronlosey) has gone through at times 80-100 tires in the rear alone and has never had an issue with wheel studs.
I think its more the process than it is the studs themselves it seams.
random stud failure sure, but that should be once a blue moon..
-J
Old Jan 19, 2010 | 06:19 AM
christoc's Avatar
christoc
Actually I did, but I used the 4-way bar to spin them on/off quickly. Lesson learned, trust me.
Old Jan 19, 2010 | 10:11 AM
ADMAN's Avatar
ADMAN
Same here. I have Nismo studs and hardened lugs. Never had a problem. I also have different lugs for each set of wheels - DD, Track and AutoX. Perhaps that's the problem? No flex + wrong lugs = snapped studs.
Also, sounds like a lot of people may be overtightening, which can stress the stud and cause it to eventually fail. I can't believe people are not using torque wrenches? Even an impact preset at 80lbs. would over-tighten a lug with each cycle.
Old Jan 19, 2010 | 10:35 AM
halfrice's Avatar
halfrice
if anything i think it could be from lack of anti seize, been changing my wheels often for track as well, and noticed a bit of rust starting and also made installing/removing the lug nuts more difficult, added some anti seize, smooth as when i did my first wheel change.
Old Jan 19, 2010 | 10:51 AM
Zazz93's Avatar
Zazz93
Not saying this about anyone associated with this thread but you'd be surprised to know how many people still jump up and down on those 4-way bars to remove and install the wheels.
Old Jan 19, 2010 | 11:10 AM
halfrice's Avatar
halfrice
guilty, but with stock bar and back when i was 16 years old
Old Jan 19, 2010 | 11:13 AM
scotts300's Avatar
scotts300
Absolutely true. Case-in-point: https://my350z.com/forum/8069653-post4.html
Old Jan 19, 2010 | 01:09 PM
ADMAN's Avatar
ADMAN
I think that ^^^ and wider wheels can put extra strain on the studs.
Old Jan 19, 2010 | 01:20 PM
scotts300's Avatar
scotts300
Spacers plus wider wheels put extra stress on the studs - sure. You are increasing the lever arm, and torque = force x distance of the lever arm. But is it too much? Our racing friends, who are forced to run large spacers to stay within spec, do it with longer studs without issue.
Old Jan 19, 2010 | 01:42 PM
halfrice's Avatar
halfrice
wow i hope that guys not serious
Old Jan 19, 2010 | 01:51 PM
DavesZ#3's Avatar
DavesZ#3
How many finger tighten the lug nuts then give the wheel a few shakes to make sure it's sitting flat on the rotor, centered on the hub and lug nuts?
How many of you guys hand tighten the nuts before using the wrench?
How many follow the star pattern when tightening? (i.e. 1,3,5,2,4)
Old Jan 19, 2010 | 02:05 PM
Zazz93's Avatar
Zazz93
You'd be surprised man...
Old Jan 19, 2010 | 02:21 PM
DavesZ#3's Avatar
DavesZ#3
I know, I've watched guys at the track hold the wheel up on the studs then start driving on lug nuts with an impact wrench. I guess they've been watching too many Nascar events.
Old Jan 19, 2010 | 02:50 PM
  #38
Zazz93's Avatar
Zazz93
On the money!
Old Jan 19, 2010 | 03:17 PM
  #39
scotts300's Avatar
scotts300
With the amount of times I change wheels, I'm happy to say I do these things consistently.
Old Jan 21, 2010 | 08:09 AM
  #40
corz's Avatar
corz
Yea, I'm not shore y I've been brakeing them like that. Cuz I alway put the lugs on by hand and put them to 75 I do use r-comps but I don't think just auto-xing would do that...
