Best Wheel size 18 or 19?
Old Jun 25, 2010 | 06:36 AM
Rickg87's Avatar
Rickg87
Default Best Wheel size 18 or 19?
Deciding to go with 18 or 19" Enkei wheels for best big brake kit options on
03 350Z. Will be a track only car. I drive in upper run groups.
Any advise on pro's and con's appreciated. Currently have 17" Enkei RPF1
9/22 and 10/38. Only 3 track days on them. Looking to sell and up size.
Currently using stock brakes. The only decent Brake kit that will fit is Rotora
13". So, Before I go for them thought why not have 14" rotors.
Any thoughts?
Thanks
Old Jun 25, 2010 | 07:34 AM
betamotorsports's Avatar
betamotorsports
18s
Old Jun 25, 2010 | 07:50 AM
Ataru074's Avatar
Ataru074
Any thoughts?
Thanks
I think also the smaller stoptech (that I suggest WAY more than rotora) will fit the 17".
18" have the most selection of R compounds for the Z...
on the other end I don't have any issue with the stock brembo about fade resistance and stopping power IF you provide enough cooling to it.
Old Jun 25, 2010 | 07:57 AM
zaperroni's Avatar
zaperroni
18's for performance
19's for looks
Old Jun 25, 2010 | 07:59 AM
03threefiftyz's Avatar
03threefiftyz
I have 18's with 332mm Stoptech kit......17's would fit w/o issue as well. As Ataru said....the factory brembo's are excellent with proper cooling and pads.
Old Jun 25, 2010 | 09:01 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
18's... I love the 19 looks but love the 18s' ride.
Old Jun 25, 2010 | 09:16 AM
ADMAN's Avatar
ADMAN
18. But, I run 17 on track with BBK. Width is more important, though.
Old Jun 25, 2010 | 10:07 AM
terrasmak's Avatar
I wouldn't consider Rotora a decent kit, and there are many better kits that will fit. 18's are the way to go, right now i run a 17 front and 18 rear for the track, and have a 355mm rotors 6 piston caliper.
Old Jun 25, 2010 | 10:40 AM
OMERTAITALIA's Avatar
OMERTAITALIA
i have 19 inch miesters and my stoptech 14in kit has 3mm cleareance, stoptechs all clear stock 18's and 17's also
Old Jun 25, 2010 | 12:30 PM
Flo-ridaZ33
I forgot to include I'm also running a CZP Akebono bbk as well.
Old Jun 25, 2010 | 12:44 PM
scotts300's Avatar
scotts300
Hard to find 19" tires for your track-only car. Tire manufacturers optimize their designs on 18" tires - I'd stick with 18s. I am running four 18x10 +38 RPF1s myself, and they are fantastic.
Old Jun 27, 2010 | 07:20 AM
idrive_MD's Avatar
idrive_MD
Go with 18s and a stop-tech brake kit. The market is still a couple or more years out from putting out comp-spec 19" tires on a larger scale.
Old Jun 27, 2010 | 02:35 PM
sektor 11's Avatar
sektor 11
19" tires would get expensive for a track car. Not fun.
Old Jun 27, 2010 | 04:26 PM
AznSky's Avatar
AznSky
so it seems like 18's are the new 17's now huh?
Was gonna go 17's for my track setup but as most of you are saying, besides the OEM brembo's it looks like you'll need 18's for a BBK.
Anybody know if 17's will clear the akebono kit?
Old Jun 27, 2010 | 04:30 PM
BoomerZ33's Avatar
BoomerZ33
that would be cutting it close due to the slim space in a 17. so i doubt it. 18's are your best bet
Old Jun 27, 2010 | 04:43 PM
12AutoX's Avatar
12AutoX
17's. Cheaper tires, better availability, less rotating mass, and so on. Better to find a BBK that fits 17's than go with 18's. Brake rotors also add rotational mass, so keep that in mind. My Wilwood six pistons and 330 mm rotors fit fine with 17's.
Old Jun 27, 2010 | 08:45 PM
scotts300's Avatar
scotts300
The 332mm (ST40) StopTech kit fits under most 17s as well.
Obadabot
Jun 18, 2023 11:31 PM
