Like the subject states I am wondering if anyone here uses Enkei RPF-1's 17x9.5 on the FRONTS? I am interested to know how you cleared the fenders without any rubbing issues?
The perfect fit i run a square 17 by 9.5 +18 with 275 nt01. looks like the will hit fender but i found no rubbing anywere.
Dang! How did you fit 275 in fronts? Do you track your car or just street driving? If you drive at track you "should" see a lot of rubbing. Any others changes to your suspension?
Originally Posted by reserved
Yes. I have 3 degrees of negative camber, but probably don't even need that much.
Do you track your car?
If you see my other thread in this forum - we are discussing about needing too much camber to clear the wheels of any rubbing on the fender. I'll have to re-check everything and try to see if I can bump down the camber up front.
My 03 is track only. I used to drive it to and from the track, but now I have a trailer, so don't even do that anymore. Even though it is lowered (JIC coilovers), I have NEVER had a rubbing issue. Quite honestly, it looks like its not even that close!
+1. I have all kinds of room with a 265 (18x9 +20 RPF1) on the front of my car at -2.7 camber.
Thanks for the pics Scott, i know they will now clear my 14inch wilwood kit. Yes the +18 will be close to the spokes but the caliper is spaced further out in the thinner spoke area.
You're very welcome. It's not often that I can supplement knowledge that you don't already know or have.
The front spacers were about 10mm in total thickness, and you can see the clearance. That's a 15mm in the back, but I don't think all 15mm was necessary. The problem was the front. I've gone all 18" now with RPF1s, so the clearance problems have all but gone away.
