Throw Away Your Ichiba Studs
Old Dec 18, 2010 | 01:27 PM
GWord256's Avatar
GWord256
Default Throw Away Your Ichiba Studs
Caution:
I had one stud break while torquing the bolts. Two broke on track. 4 more were found cracked after I replaced them all.
They all broke where the rotor hat meets the hub. Thats with 8 track days and an autocross here and there. Just sharing my lessons learned.
I bought ARP and I consider the matter closed.
-G
Old Dec 18, 2010 | 02:12 PM
rich2342's Avatar
rich2342
Luckily you weren't on the track at the time..
This is why spacers scare me.
Old Dec 18, 2010 | 02:42 PM
03threefiftyz's Avatar
03threefiftyz
ARP's here......
Old Dec 18, 2010 | 06:20 PM
terrasmak's Avatar
A mix of ARP and circuit sport on my car now. I ran Ichiba studs for over 2 years without problem
Old Dec 18, 2010 | 07:37 PM
Photos of broken studs appreciated.
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
arp ftw
Old Dec 18, 2010 | 07:52 PM
350z-Jason's Avatar
350z-Jason
Sounds like user error (or machine shop, whoever installed them) to me... just saying.
Never read any other issues with their studs. I have stock studs, so no bias here.
Old Dec 18, 2010 | 10:48 PM
Zazz93's Avatar
Zazz93
What do you normally torque them to?
Old Dec 19, 2010 | 05:12 AM
roger22's Avatar
roger22
Thats why they call them Ichiballs
Old Dec 19, 2010 | 05:59 AM
JasonZ-YA's Avatar
JasonZ-YA
your jumping to conclusions.....if you know what your doing, youll be fine. most don't....I discuss proper install techniques in the Spacers FYI sticky thread.
it does sound like user error, that many to fail is kinda nuts, and especially how you describe...
G,
1. How exactly were they installed? pressed in from the head side of the lug? or thread pulled on with a nut and washers??
2. Do you have hub centric rings on the cars lip that match the inner diameter to whatever wheel you have? to ensure center?
3. if you don't have item 2 - then when installing the wheel are you supporting the weight of the wheel and centering up the wheel with two opposite studs....by hand first then doing the rest, ensuring the wheel is centered???
4. Any shops impact them on lately?
- A product like this with many many others that have great experience with them don't deserve a "throw them away" thread.....maybe a "figure out what happened" thread.........give us details???
- One drive around a course, down the street, etc not doing item 3 or having the right item 2 will cause failures like you describe....ive seen it..
-J
Old Dec 19, 2010 | 08:36 AM
rich2342's Avatar
rich2342
<TABLE border=0 cellSpacing=0 cellPadding=6 width="100%"><TBODY><TR><TD style="BORDER-BOTTOM: 1px inset; BORDER-LEFT: 1px inset; BORDER-TOP: 1px inset; BORDER-RIGHT: 1px inset" class=alt2>Originally Posted by rich2342
</TD></TR></TBODY></TABLE>your jumping to conclusions.....if you know what your doing, youll be fine. most don't....I discuss proper install techniques in the Spacers FYI sticky thread.
Either way, the spacer came off whether it was installed improperly or defect. I prefer to cut out the middle man and don't run the risk is my personal take, but to each his own.
Old Dec 19, 2010 | 09:16 AM
JasonZ-YA's Avatar
JasonZ-YA
^ i hear ya....
also, op never mentions spacers, he just has longer studs...
-J
Old Dec 20, 2010 | 10:59 AM
ADMAN's Avatar
ADMAN
Nismo here...
Old Dec 20, 2010 | 11:14 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
mine have been on since 2007 - torqued lugs on them countless times, always removed with an impact gun fwiw
could be a fluke, could be an install issue, awfully hard to say. No bolt, or stud though is infallible...even ARP, NISMO, etc - they all can break
Old Dec 20, 2010 | 12:56 PM
terrasmak's Avatar
Also big question to the OP, do you have an aftermarket BBK on your car? Yes it matters, my wilwood rotors had a more precise hole size than stock rotors. The shoulder on ther Ichiba studs are slightly longer than stock and my rotor didn't sit perfectly and i broke a couple of studs till i figured it out.
Old Dec 20, 2010 | 01:05 PM
03threefiftyz
Fairly certain he has stoptech's.
Old Dec 21, 2010 | 12:32 PM
dnguyent's Avatar
dnguyent
That failure rate is way too high. Barring input on the OP, I suspect over-torquing the nuts, then taking it to the track where excessive temperatures caused the stud to go past it's strain capacity. DO NOT over-torque the nuts, especially if tracking the car!
Old Dec 22, 2010 | 04:12 PM
GWord256's Avatar
GWord256
Although I considered the matter closed (i.e. didn't subscribe to my own thread I see there have been enough comments on here to warrent some reply.
So here it goes.
Yes, I was on the track when two broke. Happened at turn 10 at TWS. Oddly the bolts made it to the hot pit then fell out when i turned into the paddock.
Sorry tossed them all at time of install. Just imangine a stud broken flush with the brake rotor.
PST installed, I have full confidence in their abilities. My stock studs lasted me over 20 HPDE events plus scores of autocrossing.
1) Uhh... Don't know didn't watch
2) 5mm spacer leaves just a touch of the hub poking out.
3) I put all the bolts on when the car is up and typically give them a little jolt with the wrench before dropping the car and tightening. Though I can't guarentee I do that all the time.
4) If an impact wrench has been used recently it was to replace one broken hub I had a few months back.
Yes, spacers, 5mm, all corners.
Stoptech 6&4Pot
Torque wrench is set for 80lbs. Though I admit I don't untorque and retorque for every track day just check the torque in the morning.
Old Dec 22, 2010 | 06:31 PM
terrasmak's Avatar
Look at the shoulders of of the studs when they are pressed thru the hub, they stick out slightly into the hub surface. Mine would not let my Wilwood rotors sit flush with the hub, and i had to slightly clearance the holes on the rotor. I had a problem when i first installed my BBk with Ichiba studs, now i run different studs.
Old Dec 23, 2010 | 04:52 AM
JasonZ-YA's Avatar
JasonZ-YA
Terra,
thats good info to know! what a crappy situation...hard to diagnose i would guess too until you see it...
-J
