Another Lexan Window Option
Old Dec 25, 2010 | 09:36 AM
Fixxxercask's Avatar
Fixxxercask
Default Another Lexan Window Option
My car has slowly become a dedicated track car. I climbed the HPDE ladder and will be running TTB next season with NASA. I am in the process of doing all my winter stuff and this is one of them. I had the windows cut at a place in Illinois called Pro Glass. I took them my OEM windows to use as a template. I wanted to be able to install the windows in case I need to drive somewhere on the street or more importantly to prevent rain from getting inside over night at the track or while its on the trailer. I used some existing holes in the door skin to secure lexan simply using a bolt and wing nut on both sides. I also used two other bolts to put pressure on it to pull it more towards the inside of the car so that the glass seals better when the door shuts. It is not nearly as tight as the OEM glass of course, but it should keep 99% of rain out if it rains. Both windows can be installed and removed within 5 minues, so I can pop them right out at the track. Let me know what you guys think.
Attached Thumbnails Another Lexan Window Option-100_0207.jpg   Another Lexan Window Option-100_0208.jpg   Another Lexan Window Option-100_0209.jpg   Another Lexan Window Option-100_0210.jpg   Another Lexan Window Option-100_0211.jpg
Old Dec 25, 2010 | 09:37 AM
Fixxxercask
Moar.....
Attached Thumbnails Another Lexan Window Option-100_0213.jpg   Another Lexan Window Option-100_0214.jpg   Another Lexan Window Option-100_0215.jpg
Old Dec 25, 2010 | 12:13 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Nice. But if I park my T2 racecar outside at the track overnight, I usually just put the car cover over it and call it good. Otherwise, it stays in the trailer year-round. It's not street licensed, so that's not a factor.
Old Dec 25, 2010 | 12:42 PM
Fixxxercask
True about the cover. I still have an open trailer though.
Old Dec 25, 2010 | 08:01 PM
bbs350z's Avatar
bbs350z
how much did this cost you? my track car has no windows in it. also, are you doing lexan rear glass?
Old Dec 26, 2010 | 06:58 AM
Fixxxercask
The guy made both windows for $325. Then a couple bucks at Lowes for some hardware.
I am going to do Lexan rear too as soon as I get a CF rear hatch.
Old Dec 27, 2010 | 04:48 AM
ThreeFiveZero Z's Avatar
ThreeFiveZero Z
I think you got ripped off...I paid a place local here $140 to cut mine, and mine are a size thicker. Looks good though, have fun in TTB next year! Are you heading to Nationals?
Old Dec 27, 2010 | 04:52 AM
Fixxxercask
WOW. $140 thats a great price. I thought 325 was decent actually since they are kind of custom made. Oh well. He did really good work. The windows were perfect.
Yes. I will be at Nationals. I think we had a back and forth in one of your posts actually about being at Nationals.
See you there.
Old Dec 27, 2010 | 02:46 PM
GWord256's Avatar
GWord256
Would you be willing to drive the car without door panels but the glass still in or is that a bad situation just waiting to happen? I'm thinking about doing just that but haven't had the nerve to take the door panels off the G yet.
I see your door handle is still attached is that a custom thing or does the handle come seperate from the door? I would hope the G is the same way if so.
Old Dec 27, 2010 | 03:59 PM
GT-Rob's Avatar
GT-Rob
The glass is held in place by motor, so you would need to keep all of that. The lexan lets you bolt it right to the door, avoiding all of that, so when you pull the glass, there is nothing by the door left.
Pull your door panel off and you will see.
Old Dec 27, 2010 | 07:12 PM
ThreeFiveZero Z
Under the door panel is another panel that seals the door and would keep any flying glass from entering the cabin. Though the whole point of removing the door skins is to gut the doors for to save the weight. The stock windows are heavy! The door handles of the Z just have cables that go to the locking mechanism. I have my handle mounted on the door with a few screws.
Old Dec 27, 2010 | 08:58 PM
Fixxxercask
Yea the door handles are just mounted back to the door skin. One of the existing holes actually is re-used the others were part of the other inside piece that ThreeFiveZero was talking about. I weighed the stock glass when I took it out and each window was ~10lbs, plus several more for the window motor and the tract.
Old Dec 28, 2010 | 03:40 AM
ThreeFiveZero Z
^ Did you almost break a finger or two trying to get the tracks out like I did?
Old Dec 28, 2010 | 04:13 AM
Fixxxercask
No, I didn't thankfully, but I did scrape the hell out of them.
Old Dec 28, 2010 | 02:19 PM
GWord256's Avatar
GWord256
Well the G does still see limited road use, pretty much going to/from autoX. But it also serves as a backup incase my truck breaks down so I do need to keep the windows in there for now. But all the other junk in the door can go.
I just don't want my leg banging off the glass around corners.
Old Dec 28, 2010 | 04:40 PM
ThreeFiveZero Z
In my opinion, gutting the doors in your G isnt a good idea. Do you plan on making the car a full race car? How long do you plan on keeping the car? Without the door panels, you are gonna have to mount up the power switches somewhere, the door handle, etc. Plus, if you are just doing HPDE, the weight savings are irrelevant. Just my .02..
Old Dec 28, 2010 | 07:59 PM
bbs350z's Avatar
bbs350z
+1 the door panels weigh literally nothing. youd save more weight removing the rondom weight on the trans
Old Dec 29, 2010 | 04:40 AM
GWord256's Avatar
GWord256
Random weight on the trans? Can you elaborate?
Old Jan 17, 2011 | 02:30 PM
ThreeFiveZero Z
Shameless plug, mine are for sale =)
https://my350z.com/forum/competition...ml#post8900214
Old Jan 17, 2011 | 11:56 PM
bbs350z's Avatar
bbs350z
underside of the trans, near the shifter is a random weight. used to i believe help with vibrations. weaighs a few lbs. theres also one in the trunk under the plastic
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
Tochigi_236
Sep 27, 2015 03:40 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
