Motorsport electronics...what would you like to see?
Old Jan 12, 2011 | 08:31 AM
mhoward1's Avatar
mhoward1
Default Motorsport electronics...what would you like to see?
So we are getting ready to expand the types of products we carry and would like to know you would be interested in.
We are looking at new video options, communications, etc.
Anything specific that you have been looking for or would like to find new options on a product type?
Old Jan 12, 2011 | 12:52 PM
Zazz93's Avatar
Zazz93
I don't know alot about suspension data logging but I would imagine something reasonably priced to go along with RC might be useful. I would imagine the motorcycle guys you market to would also be interested.
Old Jan 13, 2011 | 06:15 AM
bldrz's Avatar
bldrz
How about an integrated display to display lap times and data on the nav screen or aftermarket radio/screen. I have been trying to find something but have not had any luck.
Old Jan 13, 2011 | 06:25 AM
mhoward1's Avatar
mhoward1
hmm...that one might be really hard because you would need a way to communicate the data to the head unit, and the head unit would have to understand the data and have a defined display format for it.
Old Jan 13, 2011 | 06:41 AM
bldrz's Avatar
bldrz
Yeah, That what I thought, If some one could just add a RCA hookup to the display unit. It was worth a shot. Do you see a problem if I mount the current one from MH Motorsports in the cubby where the nav currently is? Do you guys plan on changing the current lap timmer? I am looking at getting one from you but if there is going to be an updated one coming i may just wait.
Old Jan 13, 2011 | 06:48 AM
mhoward1's Avatar
mhoward1
No real changes for a while. We just did a 1.41 release a few months ago with the 10hz update. The timer should work just fine anywhere in the car.
BTW, there is a way to get one for free now.....take a look at our Tell-A-Friend deal.
Old Jan 13, 2011 | 08:14 AM
GT-Rob's Avatar
GT-Rob
Additional datalogging would be nice to see at a reasonable pricepoint. I haven't done my research on whats actually out there, but something that keeps a log of temps (oil, water, LSD, etc) I could find useful. Obviously the sensors are the tricky part there, and I can always look down mid lap to see the static values at any time, but I would love to see average temps over a session as that can help with car development.
Additionally maybe speed/wheel sensors on the rear for LSD tuning.
And a laptimer that doesn't go on a phone! :P All I have is a locked work BB
Old Jan 13, 2011 | 09:11 AM
mhoward1's Avatar
mhoward1
You may want to check out our website
www.mh-motorsports.com
We have a stand alone system that can at least record all OBDII and CAN data with your lap data. We were hoping to have the analog data logger ready this month but ran into delays. Not sure when it will be ready.
Here are many of the PIDS we can record:
1 Number of trouble codes and I/M info
2 Freeze DTC
3 Fuel system status
4 Calculated engine load value
5 Engine coolant temperature
6 Short term fuel*% trim—Bank 1
7 Long term fuel*% trim—Bank 1
8 Short term fuel*% trim—Bank 2
9 Long term fuel*% trim—Bank 2
0A Fuel pressure
0B Intake manifold pressure
0C Engine RPM
0D Vehicle speed
0E Timing advance
0F Intake air temperature
10 MAF air flow rate
11 Throttle position
12 Sec.(?) air status
13 Oxygen sensors present
14 Bank 1, Sensor 1:
Oxygen sensor voltage,
Short term fuel trim
15 Bank 1, Sensor 2:
16 Bank 1, Sensor 3:
17 Bank 1, Sensor 4:
18 Bank 2, Sensor 1:
19 Bank 2, Sensor 2:
1A Bank 2, Sensor 3:
1B Bank 2, Sensor 4:
1C OBD standards this vehicle conforms to
1D Oxygen sensors present
1E Auxiliary input status
1F Run time since engine start
20 PIDs supported 21-40
21 Distance traveled with malfunction indicator lamp (MIL) on
22 Fuel Rail Pressure (relative to manifold vacuum)
23 Fuel Rail Pressure (diesel)
24 O2S1_WR_lambda(1):
Equivalence Ratio
Voltage
25 O2S2_WR_lambda(1):
Equivalence Ratio
Voltage
26 O2S3_WR_lambda(1):
Equivalence Ratio
Voltage
27 O2S4_WR_lambda(1):
Equivalence Ratio
Voltage
28 O2S5_WR_lambda(1):
Equivalence Ratio
Voltage
29 O2S6_WR_lambda(1):
Equivalence Ratio
Voltage
2A O2S7_WR_lambda(1):
Equivalence Ratio
Voltage
2B O2S8_WR_lambda(1):
Equivalence Ratio
Voltage
2C Commanded EGR
2D EGR Error
2E Commanded evaporative purge
2F Fuel Level Input
30 # of warm-ups since codes cleared
31 Distance traveled since codes cleared
32 Evap. System Vapor Pressure
33 Barometric pressure
34 O2S1_WR_lambda(1):
Equivalence Ratio
Current
35 O2S2_WR_lambda(1):
Equivalence Ratio
Current
36 O2S3_WR_lambda(1):
Equivalence Ratio
Current
37 O2S4_WR_lambda(1):
Equivalence Ratio
Current
38 O2S5_WR_lambda(1):
Equivalence Ratio
Current
39 O2S6_WR_lambda(1):
Equivalence Ratio
Current
3A O2S7_WR_lambda(1):
Equivalence Ratio
Current
3B O2S8_WR_lambda(1):
Equivalence Ratio
Current
3C Catalyst Temperature
Bank 1, Sensor 1
3D Catalyst Temperature
Bank 2, Sensor 1
3E Catalyst Temperature
Bank 1, Sensor 2
3F Catalyst Temperature
Bank 2, Sensor 2
40 PIDs supported 41-60 (?)
41 Monitor status this drive cycle
42 Control module voltage
43 Absolute load value
44 Command equivalence ratio
45 Relative throttle position
46 Ambient air temperature
47 Absolute throttle position B
48 Absolute throttle position C
49 Accelerator pedal position D
4A Accelerator pedal position E
4B Accelerator pedal position F
4C Commanded throttle actuator
4D Time run with MIL on
4E Time since trouble codes cleared
SharX59
Sep 30, 2015 10:54 AM
