Track Only Z Build Suggestions
Old Feb 1, 2011 | 07:51 AM
  #61
scotts300's Avatar
scotts300
Originally Posted by MixSeed
haha holy ****! thanks bro! ill definitely try to make it. im taking everyones advice and spending the budget on brakes, wheels, tires, and a roll cage first. im definitely gonna hold off on the motor swap at this point because its gonna be impossible to qualify for PTA after reading the rules. what brakes are you running?? from what people have said on here, id be safe using a set of oem brembos with race fluid and track pads rather than an AP racing kit or something comparable. if i can go the brembo way, id like to buy just the calipers and then get some 2-piece rotors you said something earlier about buying a track car, but id much rather build a car even tho it would be less of headache and less expensive. its more fun and ill learn a lot more this way
They are running OEM Brembos.
Old Feb 1, 2011 | 07:56 AM
  #62
mhoward1's Avatar
mhoward1
A few of us will also be at the NASA-SE race at CMP Feb 12/13 if you want to come out and check things out.
Old Feb 1, 2011 | 08:44 AM
  #63
laze1's Avatar
laze1
I run OEM Brembo's with Carbotech pads and cheap Centric blank rotors with no issues...I just go thru lots of pads and rotors...
CENTRIC 12042076 (120.42076) Rotor $ 62.79
CENTRIC 12042079 (120.42079) Rotor $ 54.79
ablaine
Nov 29, 2016 10:13 AM
