BSP Legal Camber, let's talk
Old Mar 23, 2011 | 12:55 PM
  #61
Shamu's Avatar
Shamu
Back to step 4 and 5 update.
Old Mar 23, 2011 | 01:02 PM
  #62
scardeal's Avatar
scardeal
I think most people wouldn't bat an eye with the Kinetix arms, but then again, SCCA Nationals sounds like it's run by a bunch of lawyers.
Old Mar 23, 2011 | 02:02 PM
  #63
DmanG281's Avatar
DmanG281
Originally Posted by Shamu
No one answered the question about a SP legal aftermarket option? So I guess there isnt something? And this extracting of stock bushing is only option for us to get camber we need legally? Man I might have to suck it up and go this route. Although I dont have time to do this. Anyone know of a competent shop who could do this? Oh wait I know of one to talk with. Will let you know what we come up with as I cant stand what I'm seeing here. It must be my snobby Porsche upbringing?
There are options its just that they are substandard in their adjustability and in some instances build quality. The SPL arms are pretty much the best on the openly available retail purchasable option list.
Extracting a stock bushing and replacing it with an offset bushing of much higher duromemter is not misguided. Energy Suspension and PowerFlex, to name a few, have based businesses off of this practice. Its not metal but it has much less deflection than a rubber bushing sandwiched between two metal bushings. The original intent on that design probably lies somewhere between creating a softer ride by mitigating some vibration and making a responsive steering system fully designed around the car being track oriented. Can't have both, need to settle somewhere in the middle.
Old Mar 23, 2011 | 02:47 PM
  #64
Z1NONLY's Avatar
Z1NONLY
Originally Posted by betamotorsports
In the example I cited the Corvette won A Stock that year and was disqualified because of the busing modification. When autocross events are won by 10ths and 100ths of a second these kinds of mods can be significant.
What was the gap between the winner and the protester?
Do you think that bushings, shot up with nails, had a remote chance of causing the gap?
The fact that arguably trivial rules are made in response to protests leads me to believe that there are a lot of drivers that simply protest those they can't out-drive. -and making rules to keep people like that happy just seems like bad policy.
I understand there's money on the line, but I would have a hard time protesting another driver under many, if not most of the rules, unless I thought he had a real advantage and/or the gap was very close.
Old Mar 23, 2011 | 04:40 PM
  #65
Neimad's Avatar
Neimad
What about the Stillen arms?
Old Mar 23, 2011 | 05:06 PM
  #66
Z1NONLY's Avatar
Z1NONLY
Looks like the ball joint is a no-go on the stillen A-arms.
Old Mar 23, 2011 | 07:18 PM
  #67
Shamu's Avatar
Shamu
Thanks again for stimulating my thought process on this rule.
Old Mar 23, 2011 | 07:55 PM
  #68
Neimad's Avatar
Neimad
A ball joint is a spherical bearing is a bushing=NO?
Damn...If the amount of metal in the Stillen ball joint weighs the same or less as O.E. is that ok? The rubber on the O.E. is just grease retention, not the bushing itself.
Old Mar 23, 2011 | 08:20 PM
  #69
JasonZ-YA's Avatar
JasonZ-YA
the kinetics mentioned will suffice....and super easy to adjust trackside...
-J
Old Mar 23, 2011 | 08:44 PM
  #70
christoc's Avatar
christoc
Made a mess tonight, still not any closer to getting the bushings out!
http://www.flickr.com/photos/chammond/5555033482/
Did run to pick up a vise as I didn't have one. I'm hoping that will help me tomorrow evening so I can get some real work done. Hopefully.
Old Mar 23, 2011 | 08:47 PM
  #71
christoc's Avatar
christoc
The rule is that the amount of metal in the bushing to some other material, can't be more than it was OEM
Old Mar 23, 2011 | 10:03 PM
  #72
JDMStanced's Avatar
JDMStanced
i have SPC a arm and run in BSP.
Ima get Kinetix a arms, and later, get it customized to have caster adjustability
Old Mar 24, 2011 | 07:23 AM
  #73
scardeal's Avatar
scardeal
This is speculation on my part, but Kinetix ones *look* like they might be the lightest as well.
Old Mar 24, 2011 | 07:39 AM
  #74
betamotorsports's Avatar
betamotorsports
Chris,
I sent you my bushing puller via FedEx. You'll get it tomorrow.
Old Mar 24, 2011 | 09:16 AM
  #75
Shamu's Avatar
Shamu
Well submitted an appeal to SEB on 15.8 C today asking for revised wording that will allow non solid bushings that might have a little more metal than stock.
In the mean time I'm working on a new solution that I havent seen anywhere.
Old Mar 24, 2011 | 11:24 AM
  #76
Shamu's Avatar
Shamu
....So if somone were to make a control arm bushing from non metal composite material would it meet SP no more metal than stock bushing rule? Certainly wouldnt have more "metal" than a stock bushing.
Old Mar 24, 2011 | 11:37 AM
  #77
Ruff Z's Avatar
Ruff Z
Yes, that is what we have been talking about from the beginning. Have someone machine a poly or hard rubber bushing... Done and Done
Old Mar 24, 2011 | 11:46 AM
  #78
betamotorsports
I made some out of Hydlar Z and have been running them on my 350Z for about 4 years - its a no point mod with NASA TT. I actually made two sets and Chris has been trying to install the second set in his stock UCAs.
Old Mar 24, 2011 | 11:59 AM
  #79
Shamu's Avatar
Shamu
Im talking about working with someone to offer adjustable control arm on aftermarket turnkey. No fabbing, no offset bushings, etc Designed to use this material. I think there is a solution coming our way soon with very high quality arm for 370Z. Any interest in 350?
Old Mar 24, 2011 | 12:07 PM
  #80
Shamu's Avatar
Shamu
Why is Chris pulling stock steel bearing then?
