BSP Legal Camber, let's talk
Old Mar 26, 2011 | 05:40 PM
  #101
Ruff Z's Avatar
Ruff Z
Originally Posted by christoc
Bring a set of tires and you've got a deal
I'm hoping these 710s last me through ET. I'm also hoping that the special el toro kumho contingency works out for me
I still have my well used but still fast 285 v710s...!
On a side note, my co-driver and I are pretty sure Tom Berry runs Kumho's...so yeah, sorry. Hopefully he doesnt though. We were actually thinking of bringing my car down to run in CS just to win a set of Kumhos! But the clutch has just started to slip and I dont want to risk it.
Old Mar 26, 2011 | 09:47 PM
  #102
christoc's Avatar
christoc
Looks like Tom ran Hoosiers at Nationals 2010, one can only hope he still is, and everyone else in the class is as well
Old Mar 28, 2011 | 12:31 PM
  #103
christoc's Avatar
christoc
Good news!
I didn't do the alignment myself, ran out of time and didn't have the confidence I would do it right So I went and had it checked, had the Toe adjusted. Here's where I currently am
FL/FR
RL/RR
All in Degrees
Camber
-2.3/-2.5
-2.4/-2
Toe
.05/.07
.12/.09
I'm happy with that for a start. Friday or Saturday I'll adjust the toe manually using toe plates. Might try to even up the camber a bit, but not likely for the next two events (tour/pro).
Old Mar 28, 2011 | 02:02 PM
  #104
Shamu's Avatar
Shamu
Good job Chris! Glad you got this finished in time for San Diego! I'll help you out and run Hoosiers too. But I'm not doing Pro Solo.
Old Mar 28, 2011 | 10:06 PM
  #105
JasonZ-YA's Avatar
JasonZ-YA
Originally Posted by scardeal
This is speculation on my part, but Kinetix ones *look* like they might be the lightest as well.
they are quite light...they are stainless steel and i have installed at least 7 pairs on 350z and each time a forget to weight them..oh well..
-J
Old Mar 28, 2011 | 10:08 PM
  #106
JasonZ-YA's Avatar
JasonZ-YA
One arm done, other one is ready just gotta take a before/after picture of the bushings.
looks good....
interested in seeing more pics......seems horrible to go through so much trouble though...........dammn rules......would the kinetixs not work with your race group??
-J
Old Mar 29, 2011 | 09:28 AM
  #107
christoc's Avatar
christoc
Originally Posted by JasonZ-YA
looks good....
-J
They probably will, but I was running low on time and these will work for now.
Old Apr 5, 2011 | 01:51 PM
  #108
terrasmak's Avatar
Just talked with the guys at AM Performance about control arms. The 370Z arms will be available soon, followed by 350Z arms. Here is the kicker, they are going to offer a Delren bushing option for the NASA and SCCA folks. There arms will be legal for Street Prepared and for NASA have less points than running Heim jointed arms. Contact them for details and when they will be available.
Old Apr 5, 2011 | 01:53 PM
  #109
03threefiftyz's Avatar
03threefiftyz
Are they a sponsor on here? Maybe a group buy for us?
Old Apr 5, 2011 | 02:04 PM
  #110
terrasmak's Avatar
Nope, but you being a mod could easily hook that up. I know they have an account.
Old Apr 5, 2011 | 02:21 PM
  #111
03threefiftyz
I don't have any influence or say on the matter....I am interested to see what they come up with, though.
Old Apr 6, 2011 | 03:17 PM
  #112
Shamu Z's Avatar
Shamu Z
I have seen the 370Z arm in person. Its very nice. They are on the new upper arm in their new race car at Barber this week. My car is back in their shop when they return on the 11th for their brake upgrade and few other goodies.
Take a look at their new race car!
Attached Thumbnails BSP Legal Camber, let's talk-207142_162697310455449_135889666469547_367251_3492143_n.jpg
Old Aug 17, 2011 | 07:56 AM
  #113
07JimmyZ's Avatar
07JimmyZ
just wondering if there was any updates on having some legal UCA's?
Old Aug 17, 2011 | 08:42 AM
  #114
christoc's Avatar
christoc
My stock arms with the modified bushings from John are still holding up strong. Though I need to get his removal tool put back in the mail!
Old Aug 17, 2011 | 08:45 AM
  #115
03threefiftyz
I still contend that the kinetix are legal. They are so cheap I will buy a set in the off season for comparison. If you plan to run national stuff right now....offset bushings are about the only way to go.
Old Aug 17, 2011 | 04:28 PM
  #116
jarrodh77's Avatar
jarrodh77
What is it that could possibly be illegal about the Kinetix? They have polyurethane bushings.
Old Aug 17, 2011 | 05:07 PM
  #117
03threefiftyz
The thickness of the metal sleeve within the bushings...
Old Aug 30, 2011 | 12:45 PM
  #118
07JimmyZ's Avatar
07JimmyZ
Maybe someone can enlighten me, I just had the kinetix UCA's and a aggresive alignment done...I was looking to get -3 deg front and -2 deg rear for a hoosier A6 setup... The tech told me that he couldn't adjust the kinetix past -2.6, which to me doesn't make sense.. Has anyone had this issue? Car feels great BTW but I thought I would be able to get more.
Car specs
Front
Camber -2.6L -2.5R
Toe .04 OUT
Rear
Camber -2.0L -2.0R
Toe .04 IN
Height center of wheel fender to ground
Front 25 1/4"
Rear 26"
Old Aug 30, 2011 | 12:49 PM
  #119
betamotorsports's Avatar
betamotorsports
Don't obsess on a number. Run the car and take tire temps and lap times. Also, remember that:
1. Wider tires generally require less camber.
2. Bigger radius turns require less camber.
3. Braking is improved with less camber.
4. Specific tires require more or less camber (ie: Hoosiers like more, Kumhos like less).
So, again, don't worry if you're .4 degrees less then what someone on a web site posted as ideal. Go out and test.
Old Aug 30, 2011 | 02:33 PM
  #120
Zazz93's Avatar
Zazz93
That could be close to where they max out. I think they are listed as 1.5 -/+ from factory settings and IIRC my car at that height was at -1.5 up front. So -3.000 would be the absolute max, but if you consider these are probably not the most QC'd pieces on the market there may be manufacturing defects that may eat up a little of the adjustability.
