BSP legal diff shenanigans
Old Mar 23, 2011 | 12:00 PM
scardeal's Avatar
scardeal
Default BSP legal diff shenanigans
I'm in the midst of prepping my new open diff pumpkin (3.5 FD, soon to have Quaife power), and I figured that, while it was out and staring me in the face, I'd replace the bushings with awesomesauce BSP legal diff bushings.
Um... I can't find any. I see lots of poly bushings for the suspension, but only solid aluminum ones for the diff. I understand that polyurethane is not the
ideal material, but I can't seem to find any besides OEM or solid. I looked for polyurethane, delrin and hard rubber, but no dice.
Anyone know where I can get a set of non-metallic stiff bushings for the rear diff?
Side question:
It's illegal to put an anti-friction coating/shotpeening (eg Swain) on the ring and pinion in BSP, right? However, if possible, it would be legal to do so to the LSD, correct?
Old Mar 23, 2011 | 12:41 PM
christoc's Avatar
christoc
subscribing to thread as I need to know what you find
Old Mar 24, 2011 | 04:54 AM
Z1NONLY's Avatar
Z1NONLY
You found an OEM diff bushing??
Old Mar 24, 2011 | 05:33 AM
scardeal's Avatar
scardeal
I didn't really look; I just sort of assumed that part...
Old Mar 24, 2011 | 05:37 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you don't, because none exist for the full set
the most problematic one is the rear mount bushing, in the subframe. There are no urethane ones made for that location
Whiteline has these for the mounting ears, which fit over the stock bushings
http://z1auto.com/prodmore.asp?model...ng&prodid=4547
these are offered for the subframe (where subframe mounts to chassis)
http://z1auto.com/prodmore.asp?model...ng&prodid=4160
Old Mar 24, 2011 | 05:53 AM
scardeal's Avatar
scardeal
Hey, that's much better than nothing!
Old Mar 24, 2011 | 07:21 AM
terrasmak's Avatar
Whiteline should have the rear diff bushings out within the next few months. I talked to them at SEMA, Paladin supplied them with a bushing shortly after, its in work. I also talked to them last month at the Willow Spring Time Attack.
Old Mar 24, 2011 | 07:35 AM
scardeal's Avatar
scardeal
That'd be even better... It may be several months before I have the stash to buy the Quaife anyway
Old Mar 24, 2011 | 07:47 AM
betamotorsports's Avatar
betamotorsports
For autocross and track, I recommend the OSG over the Quaiffe. I've run both and the OSG is better for competion use. And I can machine the rear subframe and diff mount bushings out of any kind of Nylon 6/6. I've done sets for E36 and E46 BMWs and a number of other cars.
Old Mar 24, 2011 | 08:07 AM
Zazz93's Avatar
Zazz93
I was wondering if anyone was gonna point that out before he bought the Quaife. Provided he isn't looking for a quiet solution over a higher performance one, I would think the OS.Giken might be another consideration.
Old Mar 24, 2011 | 09:03 AM
scardeal's Avatar
scardeal
What are the benefits of the OS Giken over the Quaife?
Old Mar 24, 2011 | 11:43 AM
betamotorsports
Search in the forum. Its been discussed a number of times.
Old Mar 24, 2011 | 12:10 PM
Zazz93's Avatar
Zazz93
Both are good, OS Giken will likely be a little louder (clunk in low speed actions) but not that bad. Quaife, quiet but have performance issues under certain circumstances. It depends more on the app and your preference to NVH.
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
3vilbunny
Sep 13, 2015 12:31 PM
OperatorAF
Sep 13, 2015 11:36 AM
