San Diego National Tour
If you're interested in seeing results from the San Diego National Tour, follow twitter.com/project350z
I'll try to tweet during the heat tomorrow, I'll tweet my times, as well as Grant's if I can get his times too.
You can also see results at http://sololive.scca.com (we run 3rd heat)
on
No excuses from me. I am a slow learner and have never been able to get car moving to it's potential in 3 runs. I'm sure Adam could have put both our cars into 52 range easily first couple of runs as any top ax driver probably would. But that's why I'm here I'm learning how to drive the thing. If I could have strung elements of each run I probably would have been in high 54 territory but I had driver error every run some where on the course.
on
I am playing with suspension settings today as this is my first time on new suspension with A6s. Rear end didn't seem to want to hook up so I'm going softer shock setting in the in rear.
on
are you still running the stock nissan diff, or did you get something from the aftermarket in beforehand?
on
on
Well we started to improve suspension by backing off on compression to almost full soft. The car hooked up much better however today we discovered two major issues with the 370 z. Ice mode with ABS was causing major issues for me as I'm a very late braker. I overshot couple corners as abs was having major problems. .. How do I fix this issue? Secondly the fuel cut at redline is terrible. When engine would cut it would take time for it to come back on line. Anyway to disable fuel cutoff on a 370z Nismo? I'd rather have spark cutoff!
I'm going to raise to car just a little to get better weight transfer. Learned a ton about the 370z today. It will be much faster in the future!
I have driven there and it's very tempting but I have too many long travel weekends planned. But after hearing how fun it is I will plan for it next year. I'd love more time to work on fast ax setup too. SD truly helped me understand what I need to do with the car.
Videos from our runs. Poor quality but you can see all my driving issues. Lol!
[youtube]http://www.youtube.com/watch?v=_WRtYTYJK3I[/youtube]
[youtube]http://www.youtube.com/watch?v=jJnCsh7WQ4c[/youtube]
