KaBlamO
Old Jun 21, 2011 | 10:27 AM
  #41
ADMAN's Avatar
ADMAN
Thought so. We stopped to have lunch on your wing.
Old Jun 21, 2011 | 12:36 PM
  #42
reserved's Avatar
reserved
Originally Posted by thekinn
I thought that NissanSport did the HR swap in a track car. Sorry I don't have details - but maybe this will shake someone's memory that does have the details.
I remember that too. My recollection is that it turned out to be exceedingly difficult. In fact, I'm not certain the project had a successful outcome.
Old Jun 21, 2011 | 12:54 PM
  #43
terrasmak's Avatar
Probably a lot easier in a race car with a stand alone ECU
Old Jun 21, 2011 | 01:53 PM
  #44
Cux350z's Avatar
Cux350z
hatersgonnahate
Just buy my engine for cheap and swap it over
Old Jul 7, 2011 | 03:57 PM
  #45
laze1's Avatar
laze1
So I ended up buying a 80K mile 2004 350Z "automatic" engine for "cheap" shipped from Danny 832-467-4400 @ Nissan Unlimited in Houston. He is looking to build some business with Racers on the Forum...so ping him for parts and let him know I refered you...Engine confirmed to arrive Friday, right on time...all good so far!
I found them here on My350Z.com, with all positive ratings...so we will see. I will post up if this turns out to be a good source for used parts.
This deal includes all engine accessories accept AC compressor, has full upper/lower intake, fuel system (injectors/lines/wiring) a set of HR headers , Power Steering and Alternator, and 60 day warranty.
nissanunlimited.com
They also have a FleeBay store...
Old Jul 7, 2011 | 05:57 PM
  #46
Fixxxercask's Avatar
Fixxxercask
Good to hear!
You going to be able to get the engine in before the next race?
Old Jul 8, 2011 | 03:38 AM
  #47
laze1's Avatar
laze1
I should be good, the next race is Aug 6 & 7...
http://nasa-se.com/2011Aug06.php
However I have missed 2 now, so my PTB Class championship plans are farked
Old Jul 8, 2011 | 06:27 AM
  #48
Voboy's Avatar
Voboy
I've seen the motors for sale in the 1500-2000 range, but you will need the trans, ecu, etc as well. You would also need the "bump" hood.
you actually dont need the hood bump. amuse superlegga doesn't
http://www.modified.com/features/mod.../photo_07.html
Old Jul 8, 2011 | 03:32 PM
  #49
laze1's Avatar
laze1
Update: Engine showed up today, just as advertised. Will begin preparing the new engine for installation...mainly moving the cooling system mods over.
next race Aug 6 & 7th Road Atlanta
Old Jul 8, 2011 | 04:16 PM
  #50
mhoward1's Avatar
mhoward1
great I am planning to be there as well. I hope you can make it
Old Jul 8, 2011 | 04:54 PM
  #51
laze1's Avatar
laze1
I PLAN to be there racing...
Old Jul 14, 2011 | 10:35 AM
  #52
ADMAN's Avatar
ADMAN
Good luck on the build...
Old Jul 14, 2011 | 11:31 AM
  #53
laze1's Avatar
laze1
thnx
Old Jul 14, 2011 | 12:34 PM
  #54
laze1's Avatar
laze1
Update;
while moving the clutch & PP over to the new engine I found a cracked plate in the Carbonetics 2-piece Carbon Fiber Clutch assymbly....S H I A T E !
But found a replacement plate for ~$230...so I am back on schedule...and a whole lot better than $2400 for a complete new assembly
...and missing another race
Old Jul 21, 2011 | 10:53 AM
  #55
Fixxxercask
Hows everything coming along?
Old Jul 22, 2011 | 03:59 AM
  #56
laze1's Avatar
laze1
Engine & Tranny go in this weekend, one week late..tried to install this stuff last weekend...Why?
Purchased new OEM 350z throw-out bearing...found out that I needed another type of bearing for the Carbonetics Clutch.... ordered it and have it in hand now. Turns out that Carbonectics uses a non-350Z Nissan OEM type bearing, not sure what it is supposed to fit, will check that out and post the info.
Wanted to replace tube headers with OEM HR Headers to lower my NASA points to stay in PTB, and found that the HR headers Header-to-Cat flange is different than the DE headers, so I went ahead and purchased some Z1 Motorsports Test pipes...
So last weekend I performed some long overdue home projects to make the Sponsor happy, and relocated the battery into the trunk using a Summit racing sealed battery relo kit...
Next Event Aug 6 & 7 at Road Atlanta, so I have 2 weekends to finish up...that should be enough My car Co-Owner/Driver will run TTB, I will run PTB.
[IMG][/IMG]
Old Jul 22, 2011 | 04:01 AM
  #57
laze1's Avatar
laze1
I am looking for a good long block core....how much?
Old Jul 22, 2011 | 07:23 AM
  #58
Zazz93's Avatar
Zazz93
Looking for a core... is your's too damaged?
Old Jul 22, 2011 | 01:23 PM
  #59
laze1's Avatar
laze1
I have pieces/parts of pistons and rings in my Intake manifold
and the oil pan is full of the same thing
But I have not pulled the engine about yet, just focused on getting the new one in and making races
Old Jul 25, 2011 | 04:51 AM
  #60
ThreeFiveZero Z's Avatar
ThreeFiveZero Z
Do you need a set of OEM DE headers? I have them collecting dust in the garage.
Sounds like yours blew as bad as mine did 2.5 years ago
