KaBlamO
Old Jul 25, 2011 | 09:33 AM
  #61
laze1's Avatar
laze1
Very NIZE Pics!!!!! Looks like my old DD 2006 Grand Touring that I blew during a DE event...
I didn't ventilate the racers cars Block anywhere...but pretty sure it has a cracked head and piston at a minimum....the water entering the engine when the head cracked locked it up before the Rods/Pistons could escape
And yes, i would love to get your old DE headers...what do want for them? not much i hope
I did get my HR headers on and the proper Test pipes on the car...so that problem is behind me, but happy to have a some stock DE headers in stock.
Note: I will be selling my tube headers and test pipes after I get all this stuff squared away.
Old Jul 25, 2011 | 12:36 PM
  #62
RandomHer0's Avatar
RandomHer0
I got a set too if you need them.
Old Aug 2, 2011 | 11:38 AM
  #63
laze1's Avatar
laze1
So, I installed the engine 2 weekends ago, and it would not start
After some trouble-shooting, I realized that I HAD NOT ALIGNED THE FLYWELL CORRECTLY!
So i had to yank the engine out, align the flywheel, and NOW IT WORKS!!!
Boy I am an idiot...
Old Aug 2, 2011 | 11:43 AM
  #64
03threefiftyz's Avatar
03threefiftyz
Time to go racin'....
Old Aug 2, 2011 | 11:48 AM
  #65
laze1's Avatar
laze1
Going to Dyno it Wednesday, then racing Sat/Sun!
http://nasa-se.com/2011Aug06.php
Old Aug 2, 2011 | 11:50 AM
  #66
Fixxxercask's Avatar
Fixxxercask
I have been guilty of that too when I replaced my clutch and flywheel. I didn't align it on that pin so that the crank position sensor wouldn't read it right. Just turned over and over. I know the feeling. At least you figured it out and she is ready to go now. Let us know dyno numbers.
Old Aug 2, 2011 | 08:49 PM
  #67
03threefiftyz
Looks like I may be in the hunt for a motor too .....mine is way down on power (proven on the dyno tonight)....
Such is life I suppose...
Old Aug 3, 2011 | 03:39 AM
  #68
laze1's Avatar
laze1
getting my 80K mile stock motor Dyno'd today, and will post results afterwards.
Old Aug 3, 2011 | 04:08 AM
  #69
mhoward1's Avatar
mhoward1
good luck. I hope you have a strong freak motor.
Old Aug 3, 2011 | 05:01 AM
  #70
laze1's Avatar
laze1
The deceased "built motor" pulled 260 WHP @ ~ 6200 RPM /236 Tq @ 4800 RPM on a DynoJet just before it was killed Power falls off dramatically after 6500 RPM
Today, I expect this one (2005 350Z Auto w/80k miles) to pull 215-225 WHP on the same Dyno on a 100 deg day.
Mods: plenum iso-spacer, stock cams, un-modified intakes, HR headers, test pipes, 3" pipe with no mufflers/resonators
The deceased engine was built by GTM 5-6 years ago and had all the nice forged internals, trick valve job, unknown compression, stock cams, tube headers, un-modified intakes, plenum iso-spacer, 3" pipe with no mufflers/resonators.
Old Aug 3, 2011 | 09:14 AM
  #71
Zazz93's Avatar
Zazz93
I'm thinking 245'ish, if the motor has compression numbers in the 160+ range. Also considering a "normal" DynoJet calibration. Good luck!
Old Aug 3, 2011 | 11:56 AM
  #72
laze1's Avatar
laze1
After 3 hours of tuning (and cool down periods in 100 deg temps) and $300 later @ Z1 MotorSports in Carrolton GA. , the new/used engine pulled 250WHP @ ~6300 RPM w/ 236 Tq.
And the old worn out "built" engine turned 260WHP...not bad at all.
Note: I also had him reset the fuel cut-off RPM to 6600...the other engine would rev to 7500 all day long...not gonna try that with a pure stock engine/valve train
Good call there Zazz93
Old Aug 3, 2011 | 12:07 PM
  #73
03threefiftyz
This was on a dynojet?
Old Aug 3, 2011 | 12:11 PM
  #74
laze1's Avatar
laze1
Yepper, DynoJet in 100 deg temps here in Atlanta...same shop/same tuner as last run with the built engine...
Old Aug 3, 2011 | 12:31 PM
  #75
Fixxxercask
260WHP is right at where mine is at and it also falls off right around 6500. Neato!
Old Aug 3, 2011 | 03:44 PM
  #76
laze1's Avatar
laze1
crappy phone vid from today
https://www.facebook.com/video/video...=1848470255500
Old Aug 10, 2011 | 04:07 PM
  #77
03threefiftyz
So how did the motor do this weekend?
What was the torque on the new motor...also, was it STD or SAE correction?
Old Aug 11, 2011 | 04:00 AM
  #78
laze1's Avatar
laze1
Well,
The bad: clutch slippage on Sunday, aftermarket fan burnt a power wire/fuse, exhaust leak at the Y-pipe to tailpipe connection, ABS appears to have died and flat-spotted a RF tire, hot as hell all weekend, I felt like shiate all weekend with cold/sinusitis/upset stomach problems
and my team partner/co-owner forgot to put the hood pins in after checking the oil level, then went on track and hood flew up Sunday morning in his TT session I bent the hood back down and ran the sprint race very PISSED!
The good: I started and finished both sprint races I got 1st place in both races/but didn't have any competitors in PTB, my main competitor didn't run due to a blown engine and I am now tied with him in points.
Overall the engine ran perfect, didn't use any oil and pulled very well. However I am still having an issue with the throttle...it is like an on/off switch about 1/2 way down...I will swap out the accelerator pedal assy 1st, then the throttle body...I have had this issue since I got the car. Open to suggestions
Engine info:
max HP - 250.36
max TQ - 236.70
CF: SAE Smoothing : 5
Temp ~ 95 Deg
Old Aug 11, 2011 | 04:24 AM
  #79
mhoward1's Avatar
mhoward1
are you going to RR?
Old Aug 11, 2011 | 04:27 AM
  #80
laze1's Avatar
laze1
yep!
