will my front tires fit? (275/45/18)
Old Sep 26, 2011 | 05:30 AM
NISMOtuner's Avatar
NISMOtuner
Default will my front tires fit? (275/45/18)
Well basically, I got a STEAL on 4 hankook C51 tires 275/45/18. Since I was able to get all 4 cheaper than buying 2 normally, I snagged them in hopes that I can use them on all 4 wheels.
So I'm curious if anyone has used that aggressive of a size tire on the front of a 350z before. I have new 9.5'' wheels on the way for them, so I just need to know if they have any issues with turning... Will they scrub... Or do I need a spacer. ny help would be great
Old Sep 26, 2011 | 05:32 AM
NZMOWND's Avatar
NZMOWND
all depends on the offset of the wheel...yes 275 will fit with proper offset
Old Sep 26, 2011 | 05:39 AM
03threefiftyz's Avatar
03threefiftyz
That is a really tall front tire....
Old Sep 26, 2011 | 05:44 AM
350Zdj's Avatar
350Zdj
275/45/18 is too F A T !
275/35/18 front and its fine.
Old Sep 26, 2011 | 05:50 AM
NISMOtuner's Avatar
NISMOtuner
Yeah I would rather them be 35 but at $500 for 4 of them, I couldn't say no... Even if I only used them for the rear. So you think I will have an issue with it being a fatter tire? The car still sits at the stock NISMO height.
Also the wheels come in either +20 or +30. I was thinking of going with +20 unless you think I need to go with +30
Old Sep 26, 2011 | 05:57 AM
03threefiftyz
27.8" tire will have an adverse effect on gearing....
That is 3" taller than the 285/30 I use on the front/rear.
Old Sep 26, 2011 | 06:06 AM
NISMOtuner's Avatar
NISMOtuner
I know my rear tire stock was the 265/35/19... I wasn't sure how different they will be. This is actually my first adventure into testing race tires. Usually I always stick with stock or near stock sizes
Old Sep 26, 2011 | 06:30 AM
jnathan68's Avatar
jnathan68
Even if they fit on front, I imagine you would definetely have problems with rub through turning or suspension movement.
Rears might fit but yes, gearing would be off. You can always check the change in wheel/tire size and what difference it makes in overall diameter here http://www.miata.net/garage/tirecalc.html
It is a great tool that I have used many times
Old Sep 26, 2011 | 06:37 AM
NISMOtuner's Avatar
NISMOtuner
Thanks. I appreciate the link
Old Sep 26, 2011 | 06:45 AM
NISMOtuner's Avatar
NISMOtuner
Ok so according to the chart, my new tires will be 1 inch taller than my stock, which shouldn't be an issue for the rear. But your right that the circumference will end up being 3.7 inches more. I'm hoping this won't mess me up too much....
Just my biggest worry is if I scrub fender when I turn in the front
Old Sep 26, 2011 | 07:42 AM
scotts300's Avatar
scotts300
They don't make a 45 series tire in that compound. It's 275/35/18, which is fine assuming your wheel width and offset is appropriate.
Old Sep 26, 2011 | 08:22 AM
NISMOtuner's Avatar
NISMOtuner
OMG.... Just go ahead and ban me... I screwed up my own size. Your correct, they are 35. I apologize for my momentary mental instability... (FAIL)
Old Sep 26, 2011 | 10:20 AM
terrasmak's Avatar
Will fit just fine on a 9.5 front wheel with an offset between 15 and 30
Old Sep 26, 2011 | 05:24 PM
NISMOtuner's Avatar
NISMOtuner
ok great. i think im gonna make my wheels with +30 front offset. and im considering getting +20 for rear... would there be any reason not to?
Old Sep 26, 2011 | 05:33 PM
thekinn's Avatar
thekinn
I run 18x9.5 +20 wheels with 275x35x18 works fine and looks good (front and rear). If going for the 'look' you might want a small spacer for the rear.. i think it's fine without.
Old Sep 26, 2011 | 07:04 PM
NISMOtuner's Avatar
NISMOtuner
sounds good to me then! thanks!
Old Sep 26, 2011 | 10:34 PM
350Zdj's Avatar
350Zdj
LOL!
That's a releif. I love the 275f/275r setup. It's what i'm currently running and it feels like the Z is much more balanced.
good luck nismo! You may want to roll the rear fenders if you havent yet.
That is if you want to run a total of +10mm offset (using spacers) at the rear. It makes the 275's sit flush.
Old Sep 27, 2011 | 08:48 AM
scardeal's Avatar
scardeal
I run 275/35R18 on 9.5 +25mm, and they work great. I ran 275/40R18 before, and those worked fine as well.
Next time around, I might go for 285s though.
Pleask
Dec 21, 2021 03:17 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Stevo Z
Oct 3, 2015 09:14 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
