Race Steering Wheel
Old Oct 2, 2011 | 12:10 PM
RandomHer0's Avatar
RandomHer0
Default Race Steering Wheel
Why did you change your steering wheel out?
I'm thinking about it, but there's no real reason I can think of to do it other than my mod bug.
Is it a comfort, or size, or grip reason?
Which do you prefer? The OEM (G35) is like a school bus wheel.
Old Oct 2, 2011 | 12:17 PM
Voboy's Avatar
Voboy
After i got a bucket seat, the shoulder bolsters made using oem feel too big. The grip and feel of my personal wheel feels great to me fwiw. Another bonusnis its lighter than stock, no airbag too, and looks pretty good.
Old Oct 2, 2011 | 12:54 PM
RandomHer0's Avatar
RandomHer0
How wide is it? OEM is 350mm correct?
Old Oct 2, 2011 | 12:56 PM
GT-Rob's Avatar
GT-Rob
Im planning to swap mine for next season. My stock one is getting pretty wreaked from my gloves. I raced with my windows down in the rain once and that pretty well did it for the stock leather.
Also looking to save weight, smaller wheel is easier to work with, especially with long legs.
Just do it already :P
Old Oct 2, 2011 | 01:09 PM
ImWeeZzel's Avatar
ImWeeZzel
Looks, security, and a personal touch to my interior w/out ricing it out
Old Oct 2, 2011 | 01:17 PM
350zion's Avatar
350zion
Professional
+1 on this question...
If I do it which I've been thinking, ill definitely go with a smaller wheel..
I'm 6'2" and the smaller wheel will give me knees some room...
Old Oct 2, 2011 | 02:03 PM
terrasmak's Avatar
Been looking into changing mine too, still in the air about quick release or not.
Old Oct 2, 2011 | 02:12 PM
r_seng's Avatar
r_seng
I'm in the same debate, considering the addition of a bucket seat as well, I was thinking either quick release or tilt.
Old Oct 2, 2011 | 02:26 PM
Voboy's Avatar
Voboy
I went with 330mm.
QR/Tilt are $$$. If you guys still run sliders on the seat then you can go without them. Fixed seat mount is when they're actually useful.
Old Oct 2, 2011 | 04:43 PM
SE5spd's Avatar
SE5spd
What exactly is needed when you buy a wheel?
What other stuff do you have to buy to make it work?
Old Oct 2, 2011 | 04:56 PM
r_seng's Avatar
r_seng
Short hub if you want to run a quick release or tilt, long hub if you don't. Depending on how close you want the wheel, you can add hub spacers.
Old Oct 2, 2011 | 07:14 PM
BrandonHeat's Avatar
BrandonHeat
Going to get a setup next month. Wek Sos has combo packages most under $500 on various wheels/hubs/QRs: http://www.weaksauceparts.com/store/home.php?cat=1927
Old Oct 2, 2011 | 08:09 PM
jnathan68's Avatar
jnathan68
On mine, short hub with non-dished steering wheel was too far away and spacer probably wasn't going to be thick enough (I am 6' 2"). Oh, and also want to get or make the airbag delete mod so the airbag light isn't on all the time.
Options I have tried:
Short hub, quick release and non-dished wheel
Short hub and dished steering wheel
Never tried the long hub with a non-dished wheel. Ended up liking the short hub with the dished steering wheel (350mm). Like the look of it and yes, save weight in the process.
As far as feel, the stock wheel is nice and if you want that kind of "plush" leather feel, need to pick your aftermarket wheel carefully. Find a local shop that carries a bunch of wheels and try them.
Old Oct 2, 2011 | 09:19 PM
SE5spd's Avatar
SE5spd
every setup ive looked at was 700+ cause of the QR, so if I dont have a QR how could I get the steering wheel off?
all I need is a short or long hub and a wheel and im set??
Old Oct 2, 2011 | 09:58 PM
jnathan68's Avatar
jnathan68
Without a quick release, the steering wheel will be attached to the hub via 6 (or 7) small screws and the only way to get it off is by unscrewing it.
The positives of having a quick release - 1) Look cool and can set your steering wheel on the dash at car shows (or hang it somewhere) 2) Can remove the wheel at night and makes the car less likely to be stolen and 3) Can quickly remove steering wheel which makes it easier to exit the car (in case of fire)...mostly for track use when in a racing seat.
If you don't go with a quick release, yes, all you technically need is a hub (short or long) and a steering wheel.
Old Oct 2, 2011 | 10:35 PM
ImWeeZzel's Avatar
ImWeeZzel
700 that's expensive! My set up was in the 500 range including momo steering wheel, quick release, short hub. Check out the vendors classifieds, most of them will meet or beat each others prices and compete for your business.
Check out topspeed autosport, they hooked me up since I ordered everything from them, and shipping was really fast!
Old Oct 2, 2011 | 10:52 PM
SE5spd's Avatar
SE5spd
yeah for a lowoffset nardi, v2 QR and everything was like 700 last I checked. Ill check topspeed, I bought my wheels from them and they were def the best price, and I looked a lot!
Old Oct 3, 2011 | 07:46 AM
betamotorsports's Avatar
betamotorsports
If its a street car, leave the stock wheel and airbag in place. If its a track only car then, in most cases, the rules require the removal or disarming of the air bags. Pegasus, IO Port, Racer Parts Wholes, Speedway, BRC, etc. all sell weld on quick releases for $60.
https://www.pegasusautoracing.com/pr...p?Product=3400
https://www.pegasusautoracing.com/pr...asp?RecID=6305
$700 for a wheel and a quick release is BS.
Old Oct 3, 2011 | 07:48 AM
Voboy's Avatar
Voboy
leave a 17mm (or 19?) socket and ratchet in the car at all times
Old Oct 3, 2011 | 09:49 AM
mhoward1's Avatar
mhoward1
Originally Posted by betamotorsports
If its a street car, leave the stock wheel and airbag in place. If its a track only car then, in most cases, the rules require the removal or disarming of the air bags. .
This...
