Need help with getting Tach signal for Traqmate
Old Nov 28, 2011 | 01:56 PM
laze1's Avatar
laze1
Default Need help with getting Tach signal for Traqmate
as stated above, I have a Traqmate in my 350z...but I am having trouble getting a valid Tach signal to feed to TraqDash. I used the OEM "timing loop" wire that is used for setting engine timing to feed the appropriate cable sold by TraqMate. However My Traqmate doesn't see a usable signal.
What wire do you guys use?
Old Nov 28, 2011 | 05:15 PM
laze1's Avatar
laze1
I answered my on question
http://www.msdignition.com/product.a...721&terms=8918
I will let you guys know have it works
BTW: it is $45 @ Summit
Old Nov 29, 2011 | 02:56 AM
snobes's Avatar
snobes
i dont have a Traqmate but this is what i used to create a normal tacho signal.
http://www.autometer.com/cat_accesso...il.aspx?vid=99
Old Nov 29, 2011 | 03:58 AM
laze1's Avatar
laze1
Yes, I say that unit...but I really didn't want to start cutting all my coil wires The MSD is inductive so no wires are cut
What wires did you use to feed the Autometer device?
BTW Thnx for the info!
Old Nov 29, 2011 | 04:33 AM
snobes's Avatar
snobes
just had to cut one wire. The power feed wire to the coils, was easy to access in the main part of the loom at the base of the windscreen. my 350s are RHD but for me it was the passenger side.
Old Nov 29, 2011 | 06:03 AM
laze1's Avatar
laze1
Thnx!
I have relocated my battery to the rear, so all those wires/cables runs are easy to get at now.
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
hardwood66
Sep 8, 2015 04:31 AM
Daniel_dh
Sep 7, 2015 12:56 PM
