New NASA Class for 2012: Spec Z
Old Feb 6, 2012 | 08:13 AM
  #121
Fixxxercask's Avatar
Fixxxercask
How do you guys feel about the staggered wheel set up? I personally like square especially because I can rotate my tires anywhere on the car for maximum life.
Old Feb 6, 2012 | 08:19 AM
  #122
mhoward1's Avatar
mhoward1
Originally Posted by scotts300
Thankfully. . . since the used NISMO body parts I bought (for SCCA use) are already on their way and the car has Brembos. I guess I'm 50% there.
What about using all OEM motors? My 03' has a rev-up.
Looking at the rules it appears the motor has to be OEM for the chassis. If not then the HR in an 03 would be the best.
Old Feb 6, 2012 | 08:23 AM
  #123
03threefiftyz's Avatar
03threefiftyz
I don't see why you wouldn't just have to make it requisite to the weight....
DE 3100lbs
Rev-up 3200lbs
HR 3300lbs
Regardless of which chassis its in....makes it simple.
Old Feb 6, 2012 | 08:39 AM
  #124
mhoward1's Avatar
mhoward1
DE 3100lbs
Rev-up 3200lbs
HR 3300lbs
it could go either way, but looking at the chart they list the year, engine and weight.
Guess we will need to hear what the clarification is.
Maybe they will add it together
03: 3100 + HR motor: 3300, so you would need to weigh in at 6400 lbs
Old Feb 6, 2012 | 08:42 AM
  #125
03threefiftyz
Has a National Director been selected for the class yet? Be nice if we could get them to join up and enter the discussion.
Old Feb 6, 2012 | 08:44 AM
  #126
mhoward1's Avatar
mhoward1
Not as of yesterday.
Old Feb 6, 2012 | 09:38 AM
  #127
03threefiftyz
Well then.
Old Feb 6, 2012 | 09:39 AM
  #128
mhoward1's Avatar
mhoward1
I'll let you know as soon as they appoint me...
I mean as soon as I know.
Old Feb 6, 2012 | 10:05 AM
  #129
03threefiftyz
Old Feb 6, 2012 | 10:13 AM
  #130
SE5spd's Avatar
SE5spd
lol
Old Feb 6, 2012 | 10:22 AM
  #131
dnguyent's Avatar
dnguyent
1. I agree with others who have posted, that the wheels should to be same width all around. If there is a spec tire that is 275/35/18 all around, then why have a rule on what size rim to use? Why unmount tires to rotate them...it will cost more.
2. Is it normal to have a singular spec diff? Is there that much of an advantage to use a Cusco RS vs. Nismo vs. Quaife vs. ATS vs. Wavetrac? Don't they all cost relatively the same? Are there diffs in the $800-$2000 range that eclipse others in performance? I'm just curious...
3. How does forcing us to use stock Brembo brakes make it more affordable? For those of us who do not own the Track model cars, we would have to buy stock Brembos. Unless we buy used Brembos, is a brand new stock brembo much less expensive than buying other aftermarket brands? If they left the brakes open, then we would buy whatever is most affordable. I don't think aftermarket brakes really vary in price enough that another racer would have an advantage if they spend gobs more money. Plus, if you want to run 14" or 15" brakes, that's your choice...you give up acceleration.
4. Heater core...if you remove all the tubing, then why not just allow us to remove the useless core? We have to meet weight anyway. It's like removing the speakers, but we have to leave the stereo system in.
5. Unrestricted exhaust, but the document mentions that the Nismo Cat-back is allowed. What does unrestricted mean? I thought it meant anything goes, so why mention the Nismo?
6. Same comment as above, but applied to the flywheel.
7. Why is there a max spacer size, but no limitations on wheel offsets?
8. "Any shift **** is allowed". Really? The rule book has to mention shift *****?
9. "Front and rear camber is unrestricted provided it is within the normal limits of adjustment. No modification to increase or decrease camber is allowed." This rule seems conflicting..."unrestricted" vs. "severly restricted".
Old Feb 6, 2012 | 10:36 AM
  #132
scotts300's Avatar
scotts300
That would suck, but if that's the case, then I'm definitely fielding the green Z, and installing a cage into it.
DE 3100lbs
Rev-up 3200lbs
HR 3300lbs
I hope so.
Old Feb 6, 2012 | 10:48 AM
  #133
idrive_MD's Avatar
idrive_MD
Originally Posted by dnguyent
1. I agree with others who have posted, that the wheels should to be same width all around. If there is a spec tire that is 275/35/18 all around, then why have a rule on what size rim to use? Why unmount tires to rotate them...it will cost more. While I do not disagree, I would prefer a more open allowance of wheels so long as measure in the 18x9-18x10 range (i.e. allow 18x9.5). I mean the excuse that testing was done and the 18x9 and 18x10 favored the most doesn't really stand up with me when tire pressures can do a lot to adjust for proper contact patch and sidewall resistance.
2. Is it normal to have a singular spec diff? Is there that much of an advantage to use a Cusco RS vs. Nismo vs. Quaife vs. ATS vs. Wavetrac? Don't they all cost relatively the same? Are there diffs in the $800-$2000 range that eclipse others in performance? I'm just curious...BEtween brands there can be a lot of variances between performance and maintenance requirements. WaveTrac list the export price for the Z diff at $1295, but it seems the other rwd diffs go between $1095 and $1395 depending on Make/Model.
3. How does forcing us to use stock Brembo brakes make it more affordable? For those of us who do not own the Track model cars, we would have to buy stock Brembos. Unless we buy used Brembos, is a brand new stock brembo much less expensive than buying other aftermarket brands? If they left the brakes open, then we would buy whatever is most affordable. I don't think aftermarket brakes really vary in price enough that another racer would have an advantage if they spend gobs more money. Plus, if you want to run 14" or 15" brakes, that's your choice...you give up acceleration. They are not forcing you to use the brembos, it is an allowable upgrade if you have a car without them. The options are better with the brembos, but there are still strong options out there with the non-brembo setups and they are lighter as well.
4. Heater core...if you remove all the tubing, then why not just allow us to remove the useless core? We have to meet weight anyway. It's like removing the speakers, but we have to leave the stereo system in. I don't really understand this one either
5. Unrestricted exhaust, but the document mentions that the Nismo Cat-back is allowed. What does unrestricted mean? I thought it meant anything goes, so why mention the Nismo? This one caught me too, but you left something out...it is unrestricted past the rear subframe, so I guess we have to use OEM headers, y-pipes and center pipe. Or are we allowed to use the full nismo header-back system and choose a different rear section? Again another non-clear section.?
6. Same comment as above, but applied to the flywheel. I thought that was rather clear actually, no restrictions from what I read other than minimum weight of 14.5-lbs
7. Why is there a max spacer size, but no limitations on wheel offsets? Maybe out of safety
8. "Any shift **** is allowed". Really? The rule book has to mention shift *****? This one struck me as odd, I wonder if they meant short shift kits or shift levers? I know TWM-performance makes a top-notch ball and short-shift assembly.
9. "Front and rear camber is unrestricted provided it is within the normal limits of adjustment. No modification to increase or decrease camber is allowed." This rule seems conflicting..."unrestricted" vs. "severly restricted". Basically you have to use all stock arms and you have to work within the limits they will allow.
I think we all agree that some further explaination of the regs is in order. I tried to answer your question with my best interpretation possible.
Old Feb 6, 2012 | 10:52 AM
  #134
mhoward1's Avatar
mhoward1
See comments below:
I think this is to help T2/T3 racers come across.
yes, there can be quite a difference in performance and weight per brand. by Specifying a single Diff they are assured that every is equal.
They are not forcing the Brembos, only allowing them. if you want to use the standard brake you can. If they open up to aftermarket systems, what will keep someone from buying a $10K super lightweight ceramic system if they have the money? Specified brakes are standard on almost every Spec series.
I have heard this rule is being reviewed
Selling point for Nissan since they are one of the series sponsors
This is usually in there for a safety reason. large Spacers can cause issues.
Common terminology to say you can run anything within X range.
Old Feb 6, 2012 | 10:56 AM
  #135
Zazz93's Avatar
Zazz93
Originally Posted by acke15
My main concern is are the brembos legal if your car wasn't equipped with them.
I thought rule package was a little too open for a spec class, but on the brakes the only limitation they mention is the size and type of rotor. So I guess you can use Brembo's, Wilwoods, etc. provided they use the stock rotor size and material. Maybe there something else mentioned elsewhere that I missed.
17 Brake System
17.1 Brake System
a) Brake pads are unrestricted.
b) Brake rotors must be the same type, material, and dimensions as OEM. Brake rotors from
alternate companies may be used. Brake rotors may be cryogenically treated.
c) Steel braided brake lines may be used.
d) Disc brake backing plates may be removed.
e) The emergency brake level and/or cables and associated must remain functional.
f) Anti-lock braking systems (ABS) may be disabled.
Oddly enough some series want to retain the stock interior pieces down to the shifter so they are just clarifying they don't care.
Old Feb 6, 2012 | 11:00 AM
  #136
racerbob4's Avatar
racerbob4
There is a lot of time spent on this site, mostly wasted, about rules you want to have changed. The rules have been written, probably between Nissan and B F Goodrich, and accepted by NASA, so for the most part you are wasting your time talking about changes you want. The rules are the rules and you can choose to race under them or not. I am sure that these rules were well thought out over several months and they are the rules the series sponsors want in place. SCCA, World Challenge, ALMS, FIA, NASCAR and NASA all have rules for their racing so discussion between yourselves about the changes each of you want are a waste of time. Desired changes would have to be sent to the sponsoring parties and the sanction organization.
Old Feb 6, 2012 | 11:19 AM
  #137
Fixxxercask
This is why I emailed Paul St. Clair and many of us have inquired who the director will be so we can direct questions and concerns to that individual.
Old Feb 6, 2012 | 11:41 AM
  #138
cyc5181's Avatar
cyc5181
subscribed.
Old Feb 6, 2012 | 12:08 PM
  #139
laze1's Avatar
laze1
You have my Vote!
Old Feb 6, 2012 | 12:13 PM
  #140
laze1's Avatar
laze1
I just hope they remember that this is NASA, and NOT SCCA...
But I will run what ever crazy rules they put out as long as the Contingency stays this generous!
So I will begin the search for a "Heater Core" and OEM front upper control arms to re-install
