The 2TH PWR Track Car conversion
Old May 25, 2017 | 01:31 PM
  #921
Fixxxercask's Avatar
Fixxxercask
Its to "re-seat" the pads. After coming onto a straight from a corner you can experience pad knock back and in the next brake zone the pedal will feel longer and will require a longer travel to get the desired brake pressure. This is sometimes mistaken as brake fade. To alleviate the problem you do a very light tap on the brake pedal in the straight to "re-seat" the pads so when you finally hit the brake the pedal at the end of the straight, it is much more firm and has the desired feel usually instilling more confidence and making it easier to heel/toe.
Old May 25, 2017 | 01:48 PM
  #922
GodISmE's Avatar
GodISmE
I have this problem now with my Brembos and I don't know if it's pad knockback or overheating! More experience needed I guess.
Old May 25, 2017 | 03:36 PM
  #923
2TH PWR's Avatar
2TH PWR
make sure you also have high temp pads.
and then like I said, review your foot work.
I find a lot of people who complain of rapid fade are lingering on the brake pedal for a long time transferring heat from the rotor to the pads and calipers.
It's the whole over emphasis of gently squeezing onto the brake and gently coming off.
It's too long and its inefficient and it over heats everything.
So make sure you aren't dragging your foot on the brake pedal before investigating anything else mechanical.
Old May 25, 2017 | 11:26 PM
  #924
GodISmE's Avatar
GodISmE
I brake hard and do a bit of trailbraking into the corner but definetely no dragging. I do heel and toe too.
Are DS2500 pads enough or do I need at least something like DS3000? I have plain Stoptech rotors with diy air ducts at the front.
Old May 30, 2017 | 05:56 PM
  #925
2TH PWR's Avatar
2TH PWR
Old Jun 3, 2017 | 04:12 PM
  #926
2TH PWR's Avatar
2TH PWR
Old Jun 6, 2017 | 06:41 PM
  #927
2TH PWR's Avatar
2TH PWR
Old Jun 15, 2017 | 04:46 PM
  #928
2TH PWR's Avatar
2TH PWR
Old Jun 19, 2017 | 02:29 PM
  #929
2TH PWR's Avatar
2TH PWR
Old Jun 20, 2017 | 06:01 AM
  #930
vex008's Avatar
vex008
good walk around video. as well as all the others.
Old Jun 28, 2017 | 04:50 PM
  #931
2TH PWR's Avatar
2TH PWR
the struggles were real. stay tuned for the recap video.
Old Jun 30, 2017 | 06:31 AM
  #932
2TH PWR's Avatar
2TH PWR
Old Jul 4, 2017 | 05:16 PM
  #933
2TH PWR's Avatar
2TH PWR
Old Jul 10, 2017 | 10:22 AM
  #934
2TH PWR's Avatar
2TH PWR
Old Jul 19, 2017 | 04:36 AM
  #935
2TH PWR's Avatar
2TH PWR
Another well produced vlog is live... this time I makea list of mods I would make if I were to start all over with a stock 350Z to get it ready for the track.
Old Jul 19, 2017 | 06:37 AM
  #936
Dblock55's Avatar
Dblock55
Keep it up mike, love watching these as i get my car ready!
BTW whats your car sitting at weight wise? My car is gutted down like yours, just havent had time to weigh it in... wondering what i should be expecting.
Old Jul 20, 2017 | 08:23 PM
  #937
2TH PWR's Avatar
2TH PWR
My car has the oem battery in it to make it heavier on purpose.
over 2800 empty, no fuel no driver.
almost 3100 loaded with me and full of fuel
Old Jul 21, 2017 | 06:03 AM
  #938
Dblock55's Avatar
Dblock55
interesting, thought you could get below 3000 fully loaded up... guess I was wrong. How much fuel is in there when ur "loaded up"?
Old Jul 21, 2017 | 05:57 PM
  #939
2TH PWR's Avatar
2TH PWR
that's a full tank. which is like 120 lbs. I'm like 175 lbs in my gear.
Old Jul 21, 2017 | 06:32 PM
  #940
Dblock55's Avatar
Dblock55
thanks for the info... saw in your video you're running a carbon hatch... are your doors still oem?
