What Fails on a track day Z?
Old Oct 15, 2012 | 11:24 AM
Blurvision's Avatar
Blurvision
Default What Fails on a track day Z?
Hello everyone. First post! Been lurking for a few months now.
Looking to build another track car, 350z keeps sticking out to me. I am looking for some info, as this will be a primary track car, double driven at events.
To avoid the usual answers. 5 years track exp, regularly competing in local TT and hpde days. Built an MR2 and Miata already, looking for something 100% track dedicated but RELIABLE.
The short term plan is to just ENJOY the car for a season or two, in stock form with safety gear. Learn what the Z is all about.
So the question is! What fails on Z that is tracked heavily?
I just saw a post above about heat wrapping the clutch line, easy fix!
Oil cooler.
Breaks, I realize the car is heavy.
Any specific bushings or failure prone areas to reinforce or look out for?
What will end my day early that can be prevented with some knowledge that im lacking right now.
thank you.
See you on track!
Old Oct 15, 2012 | 11:45 AM
Z1NONLY's Avatar
Z1NONLY
My lower control arm inner bushings went, and my ABS control module has gone bad twice in 7+ years of tracking.
Driver's rear wheel bearing went out and was replaced under warranty.
Cracked my door with my knee on a left hand turn.
My floor broke too, but I don't think that's common..
https://my350z.com/forum/maintenance...and-floor.html
Old Oct 15, 2012 | 12:00 PM
Blurvision's Avatar
Blurvision
Thanks for sharing, I see the DIY now.
https://my350z.com/forum/brakes-and-...translink.html
The seat floor is scary stuff!!
Old Oct 15, 2012 | 01:48 PM
03threefiftyz's Avatar
03threefiftyz
Let's see...this season alone I have broken:
-Wheel Bearing
-Rear camber arm (broke and bent the other links badly as well)
-Both front LCA's (damaged after the bushings failed)
-Studs
-Clutch line (freak occurrence I believe).
-Seat slider (driver weight probably played into it )
-1 exploded moton shock
-2 spark plugs
-1 motor (breathing its last life now)
Car ran for maybe 200 miles this year.
Old Oct 16, 2012 | 06:18 AM
Blurvision's Avatar
Blurvision
Thanks, are the camber arms something common?
Old Oct 16, 2012 | 02:18 PM
ldstang50's Avatar
ldstang50
For me:
Diff (torsen now a fully open diff)
abs motor
speedometer (which also controls odometer/trip)
radiator has small crack
All this occured this year after 4yrs of hard driving
Old Oct 16, 2012 | 04:42 PM
Z1NONLY's Avatar
Z1NONLY
Originally Posted by ldstang50
For me:
Broken Torsen diff?
Old Oct 16, 2012 | 04:53 PM
jblz's Avatar
jblz
1) Slave cylinder (if on an 07-08). This is a must. Upgrade to a heavy duty...
http://www.zspeedperformance.com/ZSp...ZSPHDSLAVE.htm
2) My ABS module also went out as soon as I started heavy track duty.
3) I also recently lost a wheel bearing (which I've heard can be common). So having an extra sitting around can't hurt given they are fairly cheap.
Welcome to the forum.
Old Oct 16, 2012 | 05:17 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
wheel bearings
camber arms
but i blame the driver for those... rotating while transitioning from pavement to dirt ("going off-track")
i'd rather those give than something more expensive in those situations
Old Oct 16, 2012 | 05:18 PM
terrasmak's Avatar
Wheel bearings, especially if you have a nice off.
Both the front lower control arm bushings
Old Oct 16, 2012 | 05:35 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
wheel bearings and brakes big time studs if you dont torque your wheels properly, strangly i had my abs pump 5 years with a good bit of nasa enduros and heats but never had my abs pump fail. Had my diff go bad but that was my fault for building it too tight and lack of oil cooler even my stock one got real hot so i added a cooler anyways. Happy on track trails good luck.
Old Oct 16, 2012 | 07:55 PM
Lr308's Avatar
Lr308
My lap times are a failure. Viscous diff sucks
Old Oct 16, 2012 | 09:00 PM
jblz's Avatar
jblz
-Wheel Bearing
Originally Posted by SparkleCityHop
wheel bearings
Wheel bearings
Originally Posted by Jarred@Z1
wheel bearings
Maybe a wheel bearing or two?
(thankfully they're not too expensive)
Old Oct 17, 2012 | 02:40 AM
350Zdj's Avatar
350Zdj
Well I tore up my compression rod, ball joint, in/out LCA bushings, jelly-soft transmission mount, blown rear tein shocks, messed up piston rings, cracked radiator. I've been only using street tyres so bearings are fine.
Old Oct 17, 2012 | 04:20 AM
snobes's Avatar
snobes
well after a nearly a full season of wheel to wheel all ive done is an exhaust gasket.
been a good year
but yeah make sure u have good pads, fresh brake fluid and just give the bushings a quick check after a track day
Old Oct 17, 2012 | 07:18 AM
kid_with_350z's Avatar
kid_with_350z
Make sure you have good camber arms, Front Lower control arms, brake pads + rotor, clutch and you should be good
Old Oct 17, 2012 | 12:25 PM
Blurvision's Avatar
Blurvision
Great info!
Old Oct 17, 2012 | 04:17 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
rear camber arms
diff bushings
ball joints
Old Oct 18, 2012 | 06:23 AM
N80's Avatar
N80
Been doing HPDE for about a year now (7 events). I've only had two mechanical issues. The first was the clutch slave cylinder. It was replaced under a recall for free. No problems since then. Last weekend I warped a front rotor after the last session. At least I think it is warped. Lots of vibration under braking....went away when I put some older rotors back on it....will get them turned tomorrow.
The paint on the front of the car is failing. Tons of chips.
As they say, nothing you do on the track is going to improve the resale value of your car.
Old Oct 18, 2012 | 06:52 AM
Chadbee@Forged's Avatar
Chadbee@Forged
Vendor - Former Vendor
I have done about 10 days on track in the past 4 months in my Z. 2004 model with 36k miles and all season 245 square set up with Carbotech XP10/XP8 + Motul fluid. I did this to my stock clutch....
-____-
........I now have a Competition Clutch Stage 2 and Ultra Light Flywheel, which is an awesome set up.
