Stock or Brembo (Rear)??? with ST40 Front
Old Mar 12, 2013 | 10:02 AM
swat518's Avatar
swat518
Default Stock or Brembo (Rear)??? with ST40 Front
Hi Zers. My stock non brembo brakes were so weak when I autox in the past year. So I bought an used Stoptech ST-40 in Jan, not yet install, still waiting for the rebuild kits. From what I researched, the BBK actually will not give you a significant improvement on the braking distance, it will only reduce a bit if the master cylinder and brake booster aren’t upgraded. It is more efficient on the heat dissipation. Not sure if that is correct, so need your help on my questions below:
- I was wondering what would be the differences if I run stock non-brembo vs stock brembo on the rear? (same pads, probably will be DTC-60/HPS. ST-40 front with DTC-60. No upgrade on the master cylinder and booster)
- Compared with my friend’s 370Z with stock Akebono, it’s like 2 times better than mine (stock brake). Assuming master cylinder and booster are good, will brake fluid and BBK be seriously impact the braking performance? (I haven’t flush the brake fluid since I bought the Z one year ago, and I don’t think previous owner did)
Thanks in advance!
Old Mar 12, 2013 | 10:27 AM
03threefiftyz's Avatar
03threefiftyz
The main issue that I had and one other top national guy had with the non brembos all around was the abs intrusion. Regardless of pad you couldn't keep it from firing. I use St40 on front and Brembo rears with 2 piece rotors. Only had one test day on that set-up so far, but I really like it. The st40's alone on front were also pretty damn good. I just wanted to switch it up. I trophied in BSP at nationals last year with non brembos on back. They won't hold you back for a while.
Old Mar 12, 2013 | 10:52 AM
swat518's Avatar
swat518
Did you upgrade any other braking system other than BBK? Still unsure after switching the ST40 with ss line and flush the fluid with ATE blue, whether it would impress me…
Old Mar 12, 2013 | 11:12 AM
Voboy's Avatar
Voboy
what tires are you using and what tires is your friends 370z using?
Old Mar 12, 2013 | 12:05 PM
swat518's Avatar
swat518
370Z used stock Bridgestone Potenza RE050A
Im running Nitto NT555
Old Mar 12, 2013 | 12:14 PM
03threefiftyz
NT555's are pure garbage. Worst tire I have used on any vehicle. That said, I only upgraded the lines, calipers, rotors, pads, and fluid. The master cylinder, etc is the same.
Old Mar 12, 2013 | 01:17 PM
Todd TCE's Avatar
Todd TCE
TCE Performance Products
Interesting that I've seen reference to this on some posts. Changing a mc bore size won't change stopping distances nor will it change total achievable rotor torque. The only thing you'll get with a change in bore size is displacement and output pressure.
With a larger bore you'll push harder to achieve a given pressure.
With a smaller bore you won't push as hard to get to that pressure.
Rotor torque (and ultimately tire torque at lock up) remains a static value regardless. How you get to that value is all that changes- in short how hard you push the pedal to achieve it. You can push with 70lbs and get 800psi and tire lock or push at 55lbs and get 800psi and lock up.
Old Mar 12, 2013 | 04:09 PM
terrasmak's Avatar
#1 reason I get all my brake parts thru Todd @TCE , he knows his stuff. I think every time i call, i gain knowledge from him. Even for just a simple pad order.
Old Mar 12, 2013 | 04:10 PM
SE5spd's Avatar
SE5spd
non brembo are garbage? eh I do just fine with non brembos and upgraded pads/fluid lol
Old Mar 12, 2013 | 04:25 PM
03threefiftyz
Neither Brian Peters(who now has a 350z and could wear a different national championship jacket each day of the week) or myself could get them to work without ABS interference. I rebuilt the calipers, a bunch of different pads and rotors, etc. Just couldn't get them to work, and now Brian is having the same problems.
Bear in mind that both of us were using 03-05 brakes...
Old Mar 12, 2013 | 05:21 PM
thekinn's Avatar
thekinn
Contact StopTech and ask for their opinion on matching up a rear caliper/piston config with your version of the ST-40 Front. St-40's come in different varieties of piston sizes.
Old Mar 12, 2013 | 05:23 PM
swat518's Avatar
swat518
Glad to see the pro's response (I mean on a technical perspective)! Need time to digest~
Old Mar 13, 2013 | 07:13 AM
betamotorsports's Avatar
betamotorsports
MC bore sizes will affect braking balance if you're running different bore sizing front and rear. The '06 and later base brakes with DTC70 pads and air ducted to the fronts worked fine for me on every track I ran. No need for the ducting at an autox.
DTC60/70 are not a good pad for autox use. They will not get hot enough to start working as well as they can.
Old Mar 13, 2013 | 08:21 PM
keichi59's Avatar
keichi59
+1
All ST-40 fronts for 03-05 non-brembo and 03-08 brembo were the same. 06+ non-brembos were different.
I've asked stoptech this very question. According to stoptech, the brembos and early model non-brembos have significantly lower brake torque output than the later model non-brembos. The stoptech kits were designed to maintain the stock front to rear bias. So the answer to your question depends on which ST-40 kit you have and which OEM rears you have.
I have an 06 with the correctly matched front ST-40 kit. I ended up staying with the non-brembo rears to avoid making the brakes overly front biased.
Old Mar 14, 2013 | 02:44 AM
mhoward1's Avatar
mhoward1
Can you break down the issue?
If its stopping distance the I would look at tires, weight balance, and pressure balance.
If its fade then I would look at fluids and pads before caliper upgrades.
If its initial bite feel and moderation. feel then pad brands and compounds.
If its pedal pressure feel the maybe bias and the maybe MC changes.
Luckily we have some brake experts like above that can take specific issues and then come out with a plan of action.
Old Mar 14, 2013 | 04:58 AM
swat518's Avatar
swat518
Originally Posted by keichi59
+1
Mine is 03 Z base. I bought an used one, so not sure about the part number, but the piston size per caliper are 36” & 42”. The Rear is 03 base OEM single piston.
Old Mar 14, 2013 | 05:09 AM
swat518's Avatar
swat518
I read the technical notes from Stoptech, and also as keichi59 stated, Stoptech designs the BBK based on the OEM MC & bias. But in reality, I haven’t had experience and cannot say a word.
I bought HPS for the rear OEM caliper and DTC-60 for ST-40 (but DTC-60 is on backorder…). I will basically run autox this year, but will have HPDE1 on May. Obviously, I won’t drive crazy in my 1st HPDE, so do you suggest to use HPS front as well?
Old Mar 14, 2013 | 05:50 AM
swat518's Avatar
swat518
I cannot really break down the issue, since I just started to focus on my brake. I am not experienced enough to tell if the issue came from fade, initial bite or etc. but I am trying to learn and feel this year.
What I experienced was:
When I floored the brake before the corner, I felt the car is heavy, and not enough clamping force on the rotors. The wheels were never lock up. what I thought of the issues are from fluids and pads. (I will flush fluid to ATE in few wks, and pads probably to HPS, definitely will bedin). I cannot tell what would be the feeling caused by the improper bias. In addition, one wired thing I was trying to figure out was after hard braking, I heard electrical buzz coming from the engine bay last probably 2 sec, but ABS didn’t interfere???
What I was told by instructors who drove my car:
Two comments that I remember: The front didn’t dive too much to transfer the weight(I don’t know that’s because of the brake or anti-dive design). AND the brake is way too much weak than his 370Z…
Old Mar 14, 2013 | 08:02 PM
keichi59's Avatar
keichi59
I'm assuming you mean 36mm and 42mm. Sounds like you have the 03-05 kit. 06-08 non-brembo ST-40 kit has 40mm and 44mm pistons. You should be able to switch to the brembo rear without compromising the bias. But it sounds to me like that's not really your issue.
btw, i would not use the HPS as a track pad. they fall off really quickly once they start to fade.
issyz
Jul 2, 2017 03:04 PM
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
Beater350z
Sep 9, 2015 03:36 PM
