VDC failsafe mode, *with speed limiting*?
Old May 31, 2013 | 06:15 PM
2TH PWR's Avatar
2TH PWR
Default VDC failsafe mode, *with speed limiting*?
I've read the threads. Searched. Just want to make sure I'm not going to run into any unforseen problems before I jump in.
SO we have all been there. All day at the track with VDC button off.
VDC off and SLIP lights come on. I also get the (!) brake button and lose ABS.
Which is a huge pain in the *** because I find the rear locks up on a whim of even maybe thinking about braking. (apparently it goes to 50/50 bias)
But the thing I have not read anywhere else is, my speed is limited to 160km/h when this happens!
So I just wanted to make sure installing the VDC cut off switch with save my ABS for now until I can get a system to fix the bias properly sorted out.
And I won't be limited to 160 kmh/ 100 mph if i cut the wire...
Here is a video of this happening to me all of a sudden last year on a time attack run... disregard the subtitles as i didn't understand at the time what was happening. Wasn't a fuel problem at all. The engine is just cutting at 160 and it has done this multiple times if I look back at data and video.
Sorry for still being a newb but the help is appreciated.
The fix I have done so far is pulling the battery, and then hooking it back up and driving slowly through the paddock. This clears it. Including the speed governing.
Old May 31, 2013 | 09:12 PM
terrasmak's Avatar
Never seen fuel cut from my ABS light, even at Autoclub Speedway. No problem hitting 140ish MPH with the light on. Tire stagger kills ABS function, I'm just going to remove the ABS pump soon.
Old Jun 1, 2013 | 10:42 AM
Z33_Taxi's Avatar
Z33_Taxi
Did you end up doing this yet?
I'm Phil on FB, the one that was discussing this with you
Old Jun 1, 2013 | 01:19 PM
SE5spd's Avatar
SE5spd
Glad I have base model for track use
Old Jun 1, 2013 | 03:22 PM
terrasmak's Avatar
You will still have ABS problems running a square setup
Not yet, got a couple other projects first.
Old Jun 2, 2013 | 01:40 AM
2TH PWR's Avatar
2TH PWR
I just wanted to make sure that by installing the VDC switch I was going to eliminate the problems with ABS and the speed governing which are my real concerns.
Old Jun 2, 2013 | 03:59 AM
XChacalX's Avatar
XChacalX
the switch on the VDC wont interfere with the ABS which seem to give you a speed limiter ...
if the ABS is being triggered during your race after you put that switch on, then you might want to look more into an ABS delete since im pretty sure your ABS module is too far off to be able controlling your Z now . (square setup/stickier tire/more aggressive brake pads....)
Old Jun 3, 2013 | 07:53 AM
betamotorsports's Avatar
betamotorsports
Never had an ABS problem in my base 2006 with either a square 245, 255, or 285 setup. Set the NASA TTC lap record at Cal Speedway with the 245 Hoosier A6s and braking into turn 3 goes from about 150 to 60.
Old Jun 18, 2013 | 10:08 AM
2TH PWR's Avatar
2TH PWR
I got code P1121. How would this be remedied?
Old Jun 18, 2013 | 10:09 AM
2TH PWR's Avatar
2TH PWR
Sorry 1211
Old Jun 19, 2013 | 05:22 PM
Z33_Taxi's Avatar
Z33_Taxi
Have you checked the steering angle sensor?
Old Jun 19, 2013 | 05:51 PM
2TH PWR's Avatar
2TH PWR
i do have a P1564 code as well.
I think im going to limp into my second event on saturday/ sunday then get some professional help
MAsSIVrOOM
Oct 20, 2023 10:50 AM
aarrgghh
May 1, 2022 11:04 AM
Vigman
Nov 17, 2015 04:34 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
