Brian Peters STR 350Z
Old Apr 25, 2014 | 04:09 PM
  #181
Z1NONLY's Avatar
Z1NONLY
Originally Posted by Glenn350zHR
these are the ET15s. This is just the prealignment corner balance pics. I have to finish up the fronts this weekend and sometime next week ill have actual specs for you. These are not SBC or black they are actual gunmetal. I did roll the fenders right after I test fit the wheels earlier this month. I don't think you can avoid not to with this setup
Thanks.
I'm looking forward to the final alignment vs wheel-well-fit, and don't mind rolling the fenders on the rear if needed.
Old Apr 27, 2014 | 11:41 PM
  #182
terrasmak's Avatar
Looking at your installed at full droop pic, it seems like the helper is fully compressed. If so, you could have just run an inch longer spring.
Old Apr 28, 2014 | 01:07 PM
  #183
SnoXRacer183's Avatar
SnoXRacer183
I was wondering the same thing. Looks like there is nearly 2" of room on the threaded perch yet for a longer spring as well, plus some adjustment
Old Apr 29, 2014 | 05:06 AM
  #184
Glenn350zHR's Avatar
Glenn350zHR
fully compressed the helper only adds 1/2" but its not fully compressed at full droop trust me. i have 7in springs i tried. they would just fall out of the bucket if you werent holding it. 7in also doesnt give you much room to lower the car much.
Old May 1, 2014 | 10:52 AM
  #185
Shane86's Avatar
Shane86
Just as an FYI for anyone ordering a rear spring setup from BC Racing, the parts you need are:
High/Low Kit - $85
Spring Bucket Adapters - $85
I ordered just the high/low kit thinking it had what i needed, but had to call back and order the spring bucket adapters. If you need wrenches too, a set will run you $25.
Old May 2, 2014 | 08:51 AM
  #186
Glenn350zHR
car went on its maiden test voyage to the office in STU trim today.
I have an appointment on wednesday next week for some suspension tuning. I have the car setup right now by eye. Toe seems to be close to zero in front rears have slight toe in(from lowering the car). Definitely have more static camber in the rear right now just from lowering the car about an inch. I have the kinetic ball joints as far as i could go negative (still not as much camber as in the rear). We will be fabricating some offset bushing wednesday to get more camber. with the 285s and rolled fenders i do not seem to have any rubbing and I was slaloming down the street at a good clip. Also the 1000lb springs with the revalved shocks I was surprised that the ride quality seem fairly compliant on regular roads.
Old May 2, 2014 | 09:59 AM
  #187
SnoXRacer183
Did you grind down the threaded "nub" on the arms? That will gain you a significant amount of camber, and is probably easier than offset bushings
Old May 3, 2014 | 12:59 PM
  #188
Z1NONLY's Avatar
Z1NONLY
Anyone have recommendations on a legal aftermarket clutch and flywheel combo?
I see three different names on rockauto but I know nothing about them.
I'm hoping I don't have to buy from a stealership to get STU-legal parts.
Old May 3, 2014 | 04:01 PM
  #189
jpasterjak's Avatar
jpasterjak
For Street Touring you're pretty much limited to OEM-equivalent pieces. We used an Exedy clutch and resurfaced the stock flywheel. I can't imagine any of the Rock Auto options (the ones with the stock-type spring setup) being dramatically different.
J.G. Pasterjak
Production Manager/Art Director
Grassroots Motorsport magazine
Classic Motorsports magazine
Old May 3, 2014 | 04:35 PM
  #190
Z1NONLY's Avatar
Z1NONLY
Thanks.
Thinking of getting the "LuK" dual mass unit. Looks like stock? I hope it holds up as well as stock.
Old May 19, 2014 | 07:36 AM
  #191
Shane86's Avatar
Shane86
After having to replace my entire rear subframe due to the previous owner of my car apparently being a flushtard.. It's back on the ground and moveable again.
Anyone have a good baseline for ride heights? Alignment Specs?
Old May 23, 2014 | 04:20 AM
  #192
Z1NONLY's Avatar
Z1NONLY
My alignment is kind of mild:
-2.5 front camber, -2 rear camber, 1/8" toe out up front. 1/8" toe in in the back. My current springs lower the car just over 1/2".
Old May 23, 2014 | 04:27 AM
  #193
Z1NONLY's Avatar
Z1NONLY
I have a question for those tracking 1k springs:
I am running 345# F and 410# rear ATM and my car's balance feels great. It seems counter intuitive to invert the front/rear relationship if I expect to maintain the balance I really like now. (by going with 1k F and 800 R)
I understand how bypassing the rear sway will help my Quaife work better, but that also further softens the rear's roll stiffness relative to the front's, and theoretically alters the front/rear balance farther away from what I currently enjoy.
It's not the idea of generally stiffening the springs that I'm asking about. It's changing the balance (front to rear) that seems odd to me.
Old May 23, 2014 | 07:35 AM
  #194
l30thelion's Avatar
l30thelion
Thinking of upgrading, need some advice.
I currently run Truechoice Koni Phase IVs w/ spring rates of 500/425. Was thinking of making the switch to the ProParts USA setup (want some of that magic).
I'm wondering if they are built/tested specifically for the demands of autox and maybe not ideal for the track duty (TT)?
My Z's competition weight (w/ driver) would be in the 3000-3100lbs range, running 275 R6s, 4.08 gears, and OS Giken LSD.....would it make sense to run the ProParts setup w/ 1000/850 rates for my track only car? Benefits vs lower rates?
Thanks
Old May 24, 2014 | 04:59 PM
  #195
Slaloms's Avatar
Slaloms
I'd bet money you're cornering on your bumpstops, thus the balance you're feeling at the limit is a function of them vs your actual spring rates.
Old May 24, 2014 | 05:17 PM
  #196
Z1NONLY's Avatar
Z1NONLY
Edit* How much of a spring rate "spread" can a set of custom-valved SA Koni's tolerate? (Just in case I want to change the springs later and experiment)
Old May 27, 2014 | 08:46 AM
  #197
Z1NONLY's Avatar
Z1NONLY
I'm considering going with a fixed height in the rear and just using front spring perches to alter the rake. Is this a viable option and if so, about how low should I take the rear down when I get springs? ( I was thinking somewhere between 3/4 inch and 1 inch lower than stock)
Old May 27, 2014 | 09:39 AM
  #198
03threefiftyz's Avatar
03threefiftyz
You want adjustable perches out back. Use of rear ride height is pretty key in dialing the car in....
Old May 27, 2014 | 11:50 AM
  #199
Glenn350zHR
you will never be able to corner balance the car this way. spend the 160$ for the rear adjustable perches and adapters.
Old May 27, 2014 | 04:36 PM
  #200
Z1NONLY's Avatar
Z1NONLY
Well that settles that.
I found a subframe at ZDayZ, so that's next. I should have the A-arms on by then too. My car should be ST legal in the next month or so. -Then I can get to work on actually making it faster.
The shocks have some turn-around time involved, so I'm trying to make up my mind in the next week or two and send them out.
