How to Build a Competitive Autocross 350z.
Old Nov 12, 2013 | 07:06 AM
Scabd's Avatar
Scabd
Well thank you very much. Glad I ran local only I guess, and not sure why no one called me out on it.
Old Nov 18, 2013 | 09:08 AM
Glenn350zHR's Avatar
Glenn350zHR
what do u think of the OS Giken LSD? I was chatting with Nick Barbato over the weekend regarding me setting up my HR for STU and he mentioned OS Giken. i did read a good review yesterday on it by someone on the forum. I have currently no experience in AutoX other than copiloting with Nick in his S2000 on hoosiers which was awesome!!
any pointers with my current setup and plans are appreciated
2008 Touring Coupe
k&N drop ins
Z1 HFCs
Motordyne resonated ypipe
Nismo exhaust
Plans for 2014 in order of importance
-Osiris Tune (recommendations on tuners is appreciated CT/NY/NJ/MA/RI, anyone work with RDZ motorsports in CT?)
-OS Giken LSD (80% sold on this diff but still doing my homework)
-Stoptech pads for nonbrembo,stainless lines and fluid (recommendations on pads and fluids welcome)
-ENKEI RPF1s 18x10.5 all around with 285 Hankook RS3s
-coilovers or spring shock combo and alignment(really like KW V3s coilovers on previous vehicles ive owned but open to recommendations, maybe swift springs? 1000/900? and konis? complete noob on this for the Z)
-that will probably be it for 2014 assuming business is good and i can cough up the funds. any other little things im missing?
Old Nov 23, 2013 | 11:42 PM
SE5spd's Avatar
SE5spd
Osg ftw
Old Dec 7, 2013 | 02:33 AM
Skids_Z33's Avatar
Skids_Z33
Updates on this? It has been very helpful on my purchases so far.
Old Dec 7, 2013 | 03:48 AM
03threefiftyz's Avatar
03threefiftyz
If I get some time this weekend, I'll finish an update I've been working on.
Old Dec 8, 2013 | 01:06 PM
03threefiftyz
Updated suspension and motor. Starting to burn out, but going to start on the next phase now.
Old Dec 12, 2013 | 07:57 AM
Glenn350zHR
Old Dec 21, 2013 | 02:30 PM
03threefiftyz
I've started working on the next installment, but don't expect it to be put up here until at least next weekend. Unfortunately, I only have Weds of this week, unlike a bunch of you other slackers .
Old Dec 23, 2013 | 06:05 PM
Glenn350zHR
oh Ill be working myself all week. need to pay for all the mods I want before spring and the gf wants to go on a cruise in February.
Old Dec 26, 2013 | 07:01 PM
GreyZ's Avatar
GreyZ
This is a huge source of first hand knowledge and rule understanding.. Thanks OP
Old Jan 8, 2014 | 01:55 PM
Glenn350zHR
what do think of picking up a used set of hotchkis bars and Stance SSD coilovers with 10kmiles all for about 1000$ from a local seller. versus just buying a new set of koni yellows, sleeves, 500/450 springs, and just the front hotchkis bar for about 1400-1500$. any other experienced racers feel free to chime in. I should mention i am a novice when it comes to autox/track racing. I do plan on sticking to street tires for awhile Hankook RS3s.
my dilemma is managing the cost (i have to make sure the mortgage is paid, i have other expensives hobbies, etc, and keep the girlfriend happy) of the build for daily use, STU and some track days. Other mods I still need to do is a Tune, ive decided on doing a Quaife 1.5way diff both for cost and streetability, and ill need a set of wheels and tires, and a few other miscellaneous small things just to get going.
Old Jan 8, 2014 | 02:32 PM
03threefiftyz
Like I said on facetube, I would probably do the koni's....
Old Jan 8, 2014 | 06:59 PM
Glenn350zHR
Ya I don't know what this guy is doing with the stance coil overs anyway. I did call around on the Koni setup a few hours ago. I guess Koni has front sleeves but I will have to contact BC for rears. Swift didn't have a direct answer for me on what size coil over spring I need. I believe i need 2.5in but I was unsure of the length. Should I do 500/400? Or stiffer in the rear. I'll only be running a front bar
Old Jan 9, 2014 | 01:37 AM
03threefiftyz
Once you go over 500 the OTS Koni's have to be revalved. Koni sells the two front perches for ~75 a piece. 8"x2.5" should be fine, but you may need helpers. I can't say for certain, I never ran a spring that soft...
Old Jan 9, 2014 | 01:38 AM
03threefiftyz
It may also be of benefit for you to poke around and see if you can find a lightly set of V3's in the same price range. It would be "easier" w/o having to piece stuff together for a Koni set-up.
Old Jan 9, 2014 | 12:58 PM
Glenn350zHR
That was my original plan. I would still want to upgrade the springs as the KW V3s have progressive springs that have a wide range. It seems like the Koni Yellow is the way to go on a budget. I found a site selling them for 800$. And cornerthreegarage.com sells the swift springs for 336.60 for a set. Not a bad deal. Just need to figure out spring sizing and sleeves. KW has the front sleeves but not the rears.
Old Jan 9, 2014 | 02:18 PM
03threefiftyz
Which swift springs, if you get a kit designed for the 350z, you don't need the perches. KW V3's come with every thing you need, but I think it comes with a 5" ID rear, which limits upgrade options.
Old Jan 10, 2014 | 06:42 AM
  #38
Glenn350zHR
the metric coilover springs im assuming are the ones I will need in order to get a 500/450 coilover setup. the spec R spring kit designed for the Z are like 410/480 and lower the car 1.2/1.0.
Old Jan 10, 2014 | 06:54 AM
  #39
03threefiftyz
No, you need to just buy 2.5"x8" 500/400 (450 wouldn't be my choice) springs from hyperco or eibach. I am not crazy about the a 70 pound stiffer rear. You are going to have to run a stock rear bar and probably full stiff on the front bar to make that work...
Old Jan 10, 2014 | 11:09 AM
  #40
Glenn350zHR
doing some homework now
