How to Build a Competitive Autocross 350z.
Old Jan 10, 2014 | 11:47 AM
  #41
Glenn350zHR's Avatar
Glenn350zHR
Koni Yellows - APtuned.com seem to be the cheapest around at 800$ plus shipping (i emailed them for availability 55$ for shipping to me)
Koni spring sleeve kit for the front only (correct kit part# 30 0000 000 5 verified with Koni)- 43.76$ from Summit
Eibach 500lb 2.5x8 springs front- 131.94$ from Summit
Eibach 400lb 2.5x8 springs rear - 131.94$ from Summit
Megan Racing rear sleeves - 130$ (on back order for about 6weeks)
Megan Racing rear spring seat - 24$ (on back order for about 6weeks)
1316.64$ to my door
anything I am missing here Mike?
Old Jan 10, 2014 | 11:55 AM
  #42
03threefiftyz's Avatar
03threefiftyz
Try calling BC for the rear perches, I bet they are cheaper and in stock. Make sure the front sleeves are sold in a pair. You should look around on the interwebz for used springs. You can generally find pretty lightly used springs for way under new value. 75-90 is going rate for a used pair of Eibach/Hyperco.
Old Jan 10, 2014 | 01:46 PM
  #43
Glenn350zHR
ya the front sleeves are 21$ a piece. and I priced the springs as a set. 65$ per spring shipped . I tried calling BC but apparently they are still on holiday time and are not there. Ill try them back next week
Old Jan 10, 2014 | 03:15 PM
  #44
Glenn350zHR
on a side note i just noticed that Truechoice builds exactly this koni coilover setup for the Z and they have a number of different koni setups available.
Old Jan 10, 2014 | 03:37 PM
  #45
03threefiftyz
I didn't have a great experience with truechoice, but my guess is you can do it cheaper piecing it together elsewhere...
Old Jan 10, 2014 | 05:56 PM
  #46
Glenn350zHR
Probably. Usually means it costs a lot when you don't list prices on your website lol
Old Jan 11, 2014 | 07:55 AM
  #47
03threefiftyz
There will probably be a lack of updates for a while. I apologize. Working a lot of hours during the week and trying to get the car back together for the first National in Georgia on the weekends. Have a hell of a list to get the car running again. It has not been been run since the second weekend of September.
Old Jan 11, 2014 | 07:56 AM
  #48
03threefiftyz
If you have a question about a topic not covered or one that you think needs more clarification, just PM me or post it here. I'll do my best to answer it in a timely manner.
Old Feb 12, 2014 | 05:45 AM
  #49
DaveSB's Avatar
DaveSB
bump for updates
Old Feb 12, 2014 | 01:18 PM
  #50
03threefiftyz
You simmer down over there...
...might be a bit for the next update. I'm lazy and I don't like you guys .
Old Feb 20, 2014 | 06:00 PM
  #51
AznSky's Avatar
AznSky
Mike not sure if you remember me or not, but I'm driving an FRS now in STX and saw that you will also be at Wilmington in April. See you there!
Miss having a Z....
Old Feb 20, 2014 | 06:19 PM
  #52
03threefiftyz
Sure will...drag some locals down in BSP so I can win tires. kthxbye .
Old Aug 4, 2014 | 07:37 PM
  #53
joshua350z6841's Avatar
joshua350z6841
great read thanks for the write up
Old Aug 5, 2014 | 02:11 AM
  #54
03threefiftyz
Eventually I will finish this. I am also 95% sure I am going to take the car to F-prepared next year, so I will keep a running build/photo thread for that as well.
Old Aug 5, 2014 | 04:50 AM
  #55
joshua350z6841
sounds good i run ssm lol so keep on building. how far do u travel for events an in Chicago
area would love to see u guys run some time.
Old Aug 5, 2014 | 04:53 AM
  #56
03threefiftyz
The national championship and Pro Finale is in Lincoln, NE in a month...
Old Aug 23, 2014 | 11:17 AM
  #57
joshua350z6841
that is a 7 hour drive. how far do u guys travel for these events. also i know everyone keeps talking about the diff being the best upgrade. with them all fighting inside wheel spin. is these common with all stock diffs to do this. if so i have never had this problem from 245 street tires to 285 rs3 to my 295 a6. starting to wounder if it has a aftermarket diff in it.
Old Sep 3, 2014 | 06:55 PM
  #58
03threefiftyz
It's a little under 20 hours towing each way...
Old Sep 7, 2014 | 07:08 PM
  #59
joshua350z6841
dose anyone on here have adjustable caster. i have mine at 9 in the front. i was going of what others were telling me for setup. but i feel it is to high for auto x. i keep reading info like this "Increased caster effectively reduces the responsiveness, but also helps camber gain as mentioned. Good for street and high speed track, but poor for autocross. "
an congrats to the guys at nationals.
Old Sep 8, 2014 | 07:13 AM
  #60
03threefiftyz
I plan to update/finish this in the next couple months.
