New/Better Wheel Option for Spec Z
Old Dec 3, 2013 | 12:16 PM
B Esquire's Avatar
B Esquire
Default New/Better Wheel Option for Spec Z
Hey Spec Z people! I am working with a wheel manufacturer to get a perfect fitment wheel available for Spec Z. I built a car recently for a customer and had to buy special custom ordered hub centric 20mm spacers to get the current Enkei RPF1's to fit right. The off the shelf spacers normally sold with them are hub centric to the car but not to the wheel which kinda defeats the purpose. I hate running spacers or lame plastic rings so I wanted a better option.
Anyway, since I see no reason to run 10's in the rear, at least not enough to kill the convenience and cost effectiveness of running a completely square setup and being able to rotate tires front to back, the wheel would be...
18x9" Hubcentric, +15 offest (no spacers!), wide bolt whole bore for quick changes in enduro's, and cost would be on par with what we are paying for Enkei's.
So who would be interested?
Old Dec 4, 2013 | 04:57 AM
Waco Racer's Avatar
Waco Racer
How much do they weigh?
Old Dec 4, 2013 | 07:33 AM
2000atlanticgt's Avatar
2000atlanticgt
I wonder why most don't run Enkei RP03 18x9, +18, no spacers required, you do need the huncentric rings though. 18.3lbs/ea. I run them on my car a really like them.
Old Dec 4, 2013 | 10:27 AM
B Esquire's Avatar
B Esquire
Can't say on the weight until we get the exact specs on the wheel but it will be competitive with the Enkei.
Hub rings are not an option in my opinion for a proper racecar application.
It also sounds like 9.5" might be allowed up front next year, in which case we would go that route for a perfect fit square setup.
Old Dec 4, 2013 | 03:16 PM
reserved's Avatar
reserved
Honestly, that would be such a no-brainer!!!! Just make 18x9.5 RPF-1's legal for F&R. That would be the most functional and inexpensive route for everybody.
Old Dec 6, 2013 | 08:50 AM
B Esquire's Avatar
B Esquire
Except you would still need hub rings... lame.
Old Dec 6, 2013 | 12:47 PM
reserved's Avatar
reserved
Why? Am I missing something?
Old Dec 6, 2013 | 03:46 PM
azuress's Avatar
azuress
Default Need wheels for Spec Z
I am building a Spec Z car in Carolina and am looking for wheels. The Spec Z rules specify:
The 275/35R18 BFGoodrich g-Force™ R1™ tire is the specified tire for the series.
I was surprised to see such a wide tire specified for a 9" front rim. I would expect a little stiffer 275 on a 10", but wonder how much difference 9" v. 10" makes where both are running a 275.
Old Dec 7, 2013 | 10:29 AM
B Esquire's Avatar
B Esquire
Because the RPF1's are NOT hubcentric, meaning they center themselves on the studs instead of the hub like they should. This will cause broken studs in the long term. The cheap solution is to buy the hub rigs that make up that gap. The down side to hub rings is they can fall off, get stuck, etc. The right way to do it for a racecar is to have your wheels fit properly with no spacers or rings, which is what I am currently working on for the spec Z racers.
Old Dec 7, 2013 | 10:57 AM
reserved's Avatar
reserved
Interesting! I think there are a lot of us out there tracking RPF1's. I've not heard of anyone breaking an ARP stud, not to say it hasn't happened. Mine are a few years old now. Maybe time to replace them!!!!!!!
Old Dec 8, 2013 | 03:27 AM
terrasmak's Avatar
Plastic hub rings, destroyed 2 sets in 6 years. Not bad for $7 a set at my Local discount tire.
Old Dec 8, 2013 | 06:27 AM
sig11's Avatar
sig11
I got a set of aluminum hub rings with my Volks. They can be a pain in the *** to remove from the hub but haven't had any problems otherwise.
Old Dec 8, 2013 | 08:48 PM
B Esquire's Avatar
B Esquire
Yeah it depends a lot on type of tire and abuse. We broke multiple ARP studs in Grand Am, it will happen eventually.
Old Jan 13, 2014 | 08:05 AM
B Esquire's Avatar
B Esquire
Ok, since NASA has released the 2014 rules stating 10" wheels will be allowed up front, that is what I want to spec out for this Spec Z perfect fitment wheel.
Again it will be 18x10", no hub rings or spacers required. Who is interested? Send me a PM with your email so I can send out more details and we can see about getting a group buy going!
Old Jan 28, 2014 | 08:21 PM
dtracing's Avatar
dtracing
