Ideas for Canards
Old Apr 20, 2015 | 12:58 PM
Fixxxercask's Avatar
Fixxxercask
Default Ideas for Canards
I need to get more front down force any way possible. I am looking into doing canards along with a few other things. There are tons of variations out there, but how do you get them to shape to your bumper? Or do you just buy ones that will fit your bumper? I am considering just making my own. For those of you that have them, what route did you go?
Old Apr 20, 2015 | 01:00 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
Use clay and an old bumper for practice.
Old Apr 20, 2015 | 02:51 PM
03threefiftyz's Avatar
03threefiftyz
**** that, just buy a sheet of 48x24 1/8th ABS off ebay for 20 bucks and you can make 10 iterations without running out of material. Nice thing is it is plastic, just hit it with a heat gun to mold to the bumper.
/Problem solved.
Old Apr 20, 2015 | 05:21 PM
terrasmak's Avatar
Thin cardboard, make design, transfer to balsa or thin ply, fiberglass over and mount.
That is what will be happening on my garage.
Old Apr 20, 2015 | 05:41 PM
mr. sparco's Avatar
mr. sparco
Traced a few DTM race car canards, followed the outline and install location. Used plastic sheets for the shape then used dry composites to form the shape. Took quite some time. Fibreglast has a few instructional videos with supplies.
You can also create a buck piece then make a negative mold with silicone rubber and fill with casting resin. I have an over fender kit in progress using this technique.
Edit: close up pic.
Old Apr 20, 2015 | 09:33 PM
terrasmak's Avatar
Mr Sparcp, please clue me in in the dry composite you used.
I'm going to rebuild the v2 canards on my car, I believe they are lacking
Old Apr 21, 2015 | 04:13 AM
Fixxxercask
Thanks for the info guys! All good ideas.
Old Apr 21, 2015 | 09:11 PM
mr. sparco's Avatar
mr. sparco
You can use dry carbon fiber or dry fiberglass. Dry carbon is a bit more difficult to use as it requires an oven to cure. Dry fiberglass is what's used in the medical industry, such as a broken bone cast. It is water activated and very strong. The canards I made was a hybrid of 2-3 layers dry fg and 1 layer of dry carbon.
Old Apr 22, 2015 | 04:17 AM
SmoothZ's Avatar
SmoothZ
I need my canards to be refreshed. I'm wondering if I should just have them repainted or dipped or covered.
07ZEKE
Aug 23, 2021 09:15 PM
Alexreyes
Sep 30, 2015 11:30 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
Dymsi
Sep 29, 2015 11:32 AM
Tochigi_236
Sep 27, 2015 03:40 PM
