2mm left on Toyo r888 - good enough for 2 track days?
Old Sep 26, 2016 | 04:31 AM
GodISmE's Avatar
GodISmE
Default 2mm left on Toyo r888 - good enough for 2 track days?
Guys, I'm hitting the Nordschleife soon and I've only got 2mm of tread left on the front tires (255/35/18 Toyo r888). How long will they last for without a big drop in performance? Will I be able to do two track days (8 runs) on the Ring or should I get new ones?
Old Sep 26, 2016 | 04:50 AM
dkmura's Avatar
dkmura
General & DIY Moderator
It's been several years since I last raced on the USDM version of the R888, so take this advice with a grain of salt. If the tire is left with only 2 mm of rubber, the performance of the fronts are likely played out. And if you happen to lock one under braking, a flat spot will likely go right through to the cord. Don't you carry spares for a weekend event like this anyway?
Old Sep 26, 2016 | 04:59 AM
GodISmE's Avatar
GodISmE
I only have a set of P Zero street tires in case it would rain. I don't have spare semi-slicks.
PS. Found a nice thread that explains what happens with r888 after 4/32" of the thread is gone. I'm close and I don't think 0.4 mm is enough for two track days
http://forums.pelicanparts.com/porsc...shave-not.html
nomar_ss_5
Oct 5, 2016 02:14 PM
savedbygrace
Sep 26, 2016 06:57 AM
Z33E
Sep 25, 2016 08:08 AM
