Street/Track to mostly track build
Old May 16, 2019 | 06:32 PM
  #61
coletrickle74's Avatar
coletrickle74
Holy *****. I should of took the stock exhaust off years ago. There is so much room back there now. I did a bumper tuck while I was back there. Might add some washers but I'll see how the screws hold up
My setup is some no-name resonated test pipes, stock Y pipe, and ISR single. Sounds pretty nice and has a deep tone. I was always afraid to mess with the exhaust because a lot of them sound like ****.
Old May 26, 2019 | 04:19 PM
  #62
coletrickle74
Finished up mounting the harness. Ended up using the original driver side lap belt mount. Drilled and mounted the passenger side in an identical spot on the trans tunnel.
For the sub belts, mounted a 1/4 piece of steel to the seat base under the carpet. Wrapped the harness around it just like the shoulder straps. Got everything adjusted, including the Hans. Just about ready for Road America in a couple weeks.
Old Jun 3, 2019 | 11:57 AM
  #63
coletrickle74
Noticed my rear tires are sometimes rubbing the fender lip.
Going to try the $40 Amazon fender tool and hope it lasts enough to do 2 sides. Other than that, ready for Road America this weekend.
Old Jun 5, 2019 | 08:04 AM
  #64
Blurvision's Avatar
Blurvision
You should run eye bolts and clips on your sub belts. Do not loop the belts around non round metal. They will cut through over time. That plate should be the same on the back side and welded.
Old Jun 5, 2019 | 09:34 AM
  #65
coletrickle74
Agreed on the eye bolts under the seat. Kinda ran out of time so this was my fast solution to get me by for a few sessions.
Old Jun 7, 2019 | 05:48 AM
  #66
coletrickle74
Fenders rolled and she's loaded up. 90% sure I broke the tool as I was finishing up the last pass. 40 bucks well spent
Old Jun 10, 2019 | 07:23 AM
  #67
coletrickle74
Pretty happy with everything. I went 4 seconds faster with the new suspension set up. The car feels a lot better. The seat and harness made a world of difference as well.
I did manage to get the front brakes smoking hot so, I'm looking into making some cooling ducts before the next session.
Trans temps were still a little high but not as bad as before and it didn't throw me into limp mode at all. I currently have the fan wired up to the radiator fans, I might switch to a manual toggle switch.
I also picked up a slight driveline or wheel ticking. It goes with the RPMs so it should be pretty easy to find. The ISR exhaust was close to the driveshaft, hoping I didn't tear it up.
Old Jun 12, 2019 | 04:50 AM
  #68
BQPham's Avatar
BQPham
[QUOTE=coletrickle74;10993702]Finished up mounting the harness. Ended up using the original driver side lap belt mount. Drilled and mounted the passenger side in an identical spot on the trans tunnel.
/QUOTE]
Glad to see you got em in, did you weld the plate for the inner side sub belt that went in the trans tunnel? Or how did you mount it after drilling?
Old Jun 12, 2019 | 06:21 AM
  #69
coletrickle74
I just put a big washer on the eye side and did a plate and lock nut on the inside.
Old Jul 24, 2019 | 05:26 PM
  #70
coletrickle74
Wrap is almost done and I started a DIY brake cooling project. Turning out pretty good so far.
Old Aug 6, 2019 | 06:33 AM
  #71
coletrickle74
Just finished a track day and the ducts seemed to work just fine. Nothing came loose and the brakes didn't end up smoking after a session.
Probably won't update this anymore. Its been pretty damn dead anyways.
Old Aug 6, 2019 | 07:48 AM
  #72
JBJ's Avatar
JBJ
Where did you get the flange that you attached to the backing plate? That looks pretty good. Thanks.
Old Aug 6, 2019 | 07:58 AM
  #73
rcdawgs's Avatar
rcdawgs
Great info in the thread, sucks it's not more active.
Like this cooling setup. Where are those tubes running to pickup airflow? They just open underneath?
Old Aug 6, 2019 | 09:21 AM
  #74
coletrickle74
Kinda pricey but they are pretty nice.
https://www.summitracing.com/parts/aaf-all42160/
Old Aug 6, 2019 | 09:29 AM
  #75
coletrickle74
I cut holes in the bumper and mounted some intake ducts to the front of it.
Old Aug 6, 2019 | 10:40 AM
  #76
rustyschopshop's Avatar
rustyschopshop
that really looks like a very nice setup. Not sure how i missed the last couple updates but great work.
Old Aug 6, 2019 | 11:06 AM
  #77
JBJ's Avatar
JBJ
Thanks man. I appreciate it.
Old Aug 7, 2019 | 07:02 AM
  #78
coletrickle74
Seemed like a few people were interested. So here is a pic of the duct before final mounting and wrap.
Old Aug 7, 2019 | 07:20 PM
  #79
rustyschopshop
simple and very effective
Old Mar 5, 2020 | 06:42 AM
  #80
coletrickle74
APR GTC 300 mounted and installed. I didn't want to chassis mount it just yet, so I reinforced the hatch the best I could. We'll see how it holds up.
Rousch sides, pretty straight forward. Made some brackets to attach it instead of relying on push just push in clips.
Front splitter is 3mm dibond. It has 8 mounting points (not all pictured) and is riveted to the bumper. Should be sturdy enough. Canards on the way. (I debated on making my own then decided it was too complex haha)
