LSD lockup - restacking clutches on a Tomei 1.5
I just finished repacking my tomei 1.5 lsd and learned a few things. First is that the above is not correct sadly. The disks are stamped with concentric circles that are not aligned to the center. It took me quite a while to figure it out tracing the grooves with picks. They do not spiral, so you do not need to worry about getting them the correct information.
I had been running 8 contacts faces for 40k miles and was releaved to find very very minimal wear to the disks. I did want to go significantly softer so I restacked it with 5 friction faces and removed the spacer shim(I only had one). I left all 24 friction plates in. I do wish someone had a suggestion on bolting the lsd case back together with less frustration. Getting the two halves together without pinching one of the little clutch plate ears is a struggle.
I also found that my stub axle seals had a bit of wear and the lip was getting thin (214k miles) So I went ahead and put new seals in. I should have it back in in the next week or so and will update on how it feels.
Completely agree about bolting it back together, such a pain.
I will be taking mine apart in the next two or three weeks as soon as I have a moment. Looking forward to hearing how yours feels after the restack and spacer removal.
I was finally able to test out my recent changes and wow what a difference. I doubled up every plate, leaving only 5 friction faces on each side. I also removed the shim washer. I now have zero chirping even at slow parking lot speeds. Still spins both tires equally through 3rd right now. I will have to wait for some actual track time to comment on track behavior.
That said, excellent to hear you're seeing good results with 5 active surfaces per side. I'm at 6, but may take your lead and do the same as you.
