HOW2: Remote Key Fob Programming
Old Jun 20, 2015 | 12:40 PM
  #41
sofakiing's Avatar
sofakiing
just did this, worked like a champ.
Old Jul 22, 2015 | 04:37 PM
  #42
Cux350z's Avatar
Cux350z
hatersgonnahate
FYI since this is done by the BCM you can do this procedure even with a Haltech Standalone.
Old Jul 23, 2015 | 12:23 PM
  #43
camposrod's Avatar
camposrod
OP, you rock, thank you. I've been missing the remote to my spare key since I bought the car. Time to find the remote and get this done, finally. Thanks
Old Apr 16, 2017 | 12:10 PM
  #44
kauai1800's Avatar
kauai1800
Thanks for this clear explanation. Worked great on a $6 fob from Amazon! One thing to note, car locks itself after a minute or so if you've been using the fob to lock/unlock it.
Old Jun 29, 2017 | 08:55 PM
  #45
Agret's Avatar
Agret
kauai1800 i've been looking for an extra fob, can you link the amazon one you bought? The one I got off eBay was no good
Old Apr 25, 2018 | 11:40 AM
  #46
coop3422's Avatar
coop3422
Bumping an old thread, but I just bought a ZR that only came with 1 key and fob. Going to order a new fob so if I were to somehow loose my key or lock myself out, I can get inside. Then get a new/second key cut, and rip them apart to build a switchblade key .
Old Apr 26, 2018 | 02:03 PM
  #47
vegasanthony's Avatar
vegasanthony
Tagged
Old May 24, 2018 | 05:34 PM
  #48
Tommy Wang's Avatar
Tommy Wang
Default Me too
Originally Posted by jrisc
Tried this in my Z350 2003 Track but it did not work - instead of the lights flashing - the doors would unlock and will not enter the programing mode. Any ideas? how i can make it work. I have seen other peole in the net having the same issue but no solution was suggested.
I have the same problem as yours. Did you fine tge solution ? Thx
Old Jul 17, 2020 | 04:58 PM
  #49
Cartel's Avatar
Cartel
same here! it unlocks the doors but no flashing lights.
Old Mar 4, 2022 | 08:32 PM
  #50
anandily's Avatar
anandily
Default Key fob programming messed up my working fob
Originally Posted by dscheers
1. Close and lock all doors with the driver’s side power lock/unlock switch.
2. Insert key in ignition and remove it from the ignition key cylinder a minimum of six times within 10 seconds. Your hazard lamps will flash if you have performed this step successfully. (Withdraw key completely from ignition cylinder each time). If this procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to ACC position.
4. Within 5 seconds, push any button on the keyless remote. Your hazard lamps should flash. (Do not press the button more than one time in the above step). If the button is pressed more than one time, the programming procedure will not be successful.
5. If there are any remaining remotes (including the old ones), unlock then lock all doors using the driver’s side power lock/unlock switch. Within 5 seconds, push ANY button on the next remote. Your hazard lamps should flash. Repeat this step for each keyless remote (including any existing keyless remotes).
6. Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver’s side power lock/unlock switch and open the driver side door.
Done
hello,
I tried this method but after the my car flashed my key fob didn’t program. I tried the same process but now the car doesn’t flash no matter how many times I put the key in the ignition. Can someone help please?
mforno
Mar 24, 2022 11:14 AM
Superstardj01
Apr 1, 2019 05:26 PM
cheneymatthews
Aug 26, 2009 07:13 PM
MBear12
Jul 29, 2009 07:00 PM
CopperZ
Jan 25, 2004 07:24 PM
