Keyless bullsh*t !?
Old Aug 20, 2009 | 07:40 PM
cheneymatthews's Avatar
cheneymatthews
Question Keyless bullsh*t !?
Fellas. I've searched all over and it doesn't seem like anyone has had it this bad.
So my keyless entry fob stopped working today. I replaced the battery.. still no dice. I reprogrammed it using the DIY, tried about 10times to no avail. For every attempt, I can get the hazards to flash after inserting the key 6 times, then I turn it to ACC, push a key on the fob.... wait for a resounding flash of the hazards and NOTHING ever happens?! So I grabbed my backup keyless fob, tried using it... NOTHING!!! Put in a new battery to the backup fob... NOTHING!! Tried reprogramming the backup fob... NOTHING!!! Perused the internet for the last 4 hours searching for someone else who has tried two separate fobs and a slurry of programming attempts without any result!!?!
Below is the tactic I used?! Is there a module, fuse, antennae, or something that could be refusing my fobs and reprogramming?!
PLEASE HELP ME?!
1. Close and lock all doors with the driver’s side power lock/unlock switch.
2. Insert key in ignition and remove it from the ignition key cylinder a minimum of six times within 10 seconds. Your hazard lamps will flash if you have performed this step successfully. (Withdraw key completely from ignition cylinder each time). If this procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to ACC position.
4. Within 5 seconds, push any button on the keyless remote. Your hazard lamps should flash. (Do not press the button more than one time in the above step). If the button is pressed more than one time, the programming procedure will not be successful.
5. If there are any remaining remotes (including the old ones), unlock then lock all doors using the driver’s side power lock/unlock switch. Within 5 seconds, push ANY button on the next remote. Your hazard lamps should flash. Repeat this step for each keyless remote (including any existing keyless remotes).
6. Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver’s side power lock/unlock switch and open the driver side door.
Old Aug 21, 2009 | 01:37 PM
island03z's Avatar
island03z
I'd agree with what you said and try checking all your fuses first...could be something that simple
Old Aug 22, 2009 | 05:59 AM
kyle22's Avatar
kyle22
1. Insert key into and remove it from ignition more than 6 times with in 10 seconds. (hazards will flash)
2. Insert key and turn to ACC position.
3. Push any button on remote once. Hazzards will flash.
4. Open and close door.
5. Done. Check operation of other buttons
try this it just worked for me and i just used my original key fob with a new battery
in your first step do not lock yourself in the car just open the door sit and close then follow the above steps.
i hope this helps.
Old Aug 22, 2009 | 06:30 AM
cheneymatthews
thanks for the info Kyle, I'll try that technique of NOT actually locking the doors and hopefully it will work. ((fingers crossed))
Old Aug 22, 2009 | 08:30 AM
kyle22's Avatar
kyle22
good luck man
Old Aug 24, 2009 | 10:26 AM
cheneymatthews
So it worked for the last 2 days... then all of the sudden stopped again today?!
No clue... ordered a new fob... hopefully 1 of these 3 will eventually work. If it doesn't I'll take it in and update anyone who may have this problem in the future...
Old Aug 26, 2009 | 07:13 PM
cheneymatthews
My new fob came in today.. programmed it like I did all the others and it worked like a dream.
So I in essence had two fobs where one had failed and the other was failing. If anyone has this issue, maybe also look into your flip-key mod. I think that my fob was failing because the flip-key housing is crap.. well, the one that I got.
Moral of the story. Have multiple fobs, if you did the flip-key mod make sure you get a good one.
c.
Z_rican
Jun 29, 2006 07:03 AM
Kabs
Jan 20, 2006 04:31 PM
KeepRT
Apr 20, 2003 10:59 AM
padam07
Sep 25, 2002 07:18 PM
