Step-By-Step Instructions:Removing Rear Brake Light / Access To Turn Signal
you don't have to remove the rear bumper just to gain access to the turn signals bulbs, unless you're talking about taking the entire turn signal housing down and painting it a different color.
I just finished installing stealth silver turn signal bulbs. Thanks for the helpful write-up. As you said, the one trick is removing the tail lights without breaking off the two tabs (especially the one at the front corner). I found it helpful to slide a strap behind, and pull straight out as shown below.
Also before and after shots of the turn signal bulbs in case anyone's interersted.
I have some condensation in my actual taillight. I haven't really looked into it myself but is there an easy way to get into there? I'll try tomorrow and might discover how easy it was but I might as well ask before I jump into anything... thanks for the help.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Thanks vo7848.
