DIY-install shift knob
Old Mar 9, 2007 | 09:31 PM
  #41
usmanasif's Avatar
usmanasif
Here's what the '06 FSM suggests:
Old Mar 28, 2007 | 08:25 PM
  #42
stu8319's Avatar
stu8319
Ok so if I bought my car and it previously had a shift **** installed, then the stocker put back on, when I install a new one I don't have to do all this again right? I mean the adhesive is gone now correct?
Old May 7, 2007 | 01:06 PM
  #43
Bob Martin's Avatar
Bob Martin
Damn..I just tried this and I couldnt get the shock **** to move one bit! taking a break b4 I go in for round two. Wish me luck
Old May 8, 2007 | 03:11 PM
  #44
MustGoFastR's Avatar
MustGoFastR
I was all freaked before I tried to pul mine by reading all the horor stories and with a good set of vice grips on the shaft, it wasn't bad at all. Had to twist real hard and it was very tight twisting for several revolutions, but it came off.
Old May 15, 2007 | 05:50 PM
  #45
Checkmate58's Avatar
Checkmate58
It was hot as hell the other day. I decided to just turn the ****. It came off with hardly any trouble. I have an 06 though.
--Sam
Old May 31, 2007 | 05:20 AM
  #46
NA&CH's Avatar
NA&CH
wow just bought my ARC, now I dont want to install
I try this weekend...
Thanks for the post
Chris
(03 btw)
Old May 31, 2007 | 06:28 AM
  #47
SSP-350z's Avatar
SSP-350z
I just changed my 03 stocky to a Evo-R Ti ****. It was not too bad. Granted I had another person help me. It was really hard to turn for the first 2-3 revolutions but after that it came right off. Just like the others said a good set of vice grips and a huge set of plyers will make ur job easier. Also remember to wrap a towl around your stock **** if u want to save the finish.
Old Jun 1, 2007 | 10:47 AM
  #48
PHARM Z's Avatar
PHARM Z
Use a strap wrench from Loewes for the ****. It works great and it saves your ****.
Old Jun 3, 2007 | 05:49 AM
  #49
350ZV3's Avatar
350ZV3
Strap wrench is a must. Taking off **** was not a problem. Geat post
Old Jun 4, 2007 | 12:12 PM
  #50
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Or just use one hand to twist it off and the other to hold the vice grips.
Old Jun 4, 2007 | 01:46 PM
  #51
mikeg8r's Avatar
mikeg8r
You get better leverage with a wrench. It looks likes the OEM **** is affixed with lok-tite blue.
Old Jun 4, 2007 | 01:57 PM
  #52
redman333's Avatar
redman333
I did mine after my car sat out in the sun for the day and it came right off. Didn't have to pull my shift boot up or anything.
Old Jun 15, 2007 | 07:18 AM
  #53
RedBullRR's Avatar
RedBullRR
Anyone want to trade a Stock **** with a Nismo GT?
Old Jun 15, 2007 | 08:53 AM
  #54
TenTilFour's Avatar
TenTilFour
I was under the impression that just turning the shift **** with a great amount of force could damage the linkage...
Old Jun 16, 2007 | 03:50 AM
  #55
yobri's Avatar
yobri
It could. That is why sufficient support should be placed on a lower segment of the rod so that only the **** turns and then eventually comes off.
Old Jun 20, 2007 | 05:38 PM
  #56
TenTilFour's Avatar
TenTilFour
So do I place the vice gribs on the rubber that covers the shaft underneath the console? I lifted it up and pushed the cotton aside but there's rubber covering the entirety of the shaft and I don't feel like the vice grab would sufficiently grab the linkage enough.
Old Jun 21, 2007 | 12:08 AM
  #57
yobri's Avatar
yobri
Over the rubber is fine so as long as the grip is tight enough.
Old Jun 21, 2007 | 09:41 AM
  #58
TenTilFour's Avatar
TenTilFour
I tried turning it a bit today but backed off because I couldn't tell if I was twisting the bottom vice or not....that and I couldn't get a proper grip on the top **** because i used the crappy vice for that one.... I will go look for a rubber one at lowes later today and try agn.
Old Jun 21, 2007 | 09:44 AM
  #59
bb1314's Avatar
bb1314
da Terminator!
Originally Posted by MC
what year Z do you have? if you own a 2003 (like me) you might need to get the dealer to do it. it was a big ordeal to get it off. they ended up tearing up the **** to get it off.
but ive heard some people with later model years being able to twist it off.
what you need to do is pop that shift boot piece up and vise grip the base of the shifter. with it secure where the shift pole doenst move and twist the shifter off
+1. That's exactly what I did to this past weekend. I own an 03. It's actually pretty easy. Took me about 30 mins (15 mins was to drive to Pepboys to get the vise grip).
Old Sep 8, 2007 | 10:59 AM
  #60
joe645733's Avatar
joe645733
so u cant just twist it off without opening the console?
seems like some ppl are doing that but on wikipedia it says it can **** ur trans up doing it that way
