DIY-install shift knob
Old Apr 2, 2008 | 07:41 AM
  #81
1_SIK_Z's Avatar
1_SIK_Z
My stock **** came off perfectly...no damage at all!!
Old Apr 16, 2008 | 03:46 AM
  #82
koolzero's Avatar
koolzero
I ruined my shift **** too taking it off.
I have a question about the black ring that is under neath the OEM shift boot. My friend had to cut my shift **** off with a hack saw which exposed a cast iron **** that was then removed. He took the shift boot off over this iron shift **** to give us more room to hold the lever steady, but doesn't remember seeing this black plastic ring. Does anyone know where I can find a replacement, or is it not that necessary? I am thinking it was destroyed if he pulled the shift boot over the **** with it still attached. I could not find part information for it on courtesy parts.
This is the piece in question:
Old Apr 16, 2008 | 06:17 AM
  #83
lionheartednyhc's Avatar
lionheartednyhc
Its not super important, cars not gunna stall w/o it. Just keeps the boot from sinking too low. No idea where to get another
Old May 11, 2008 | 09:50 PM
  #84
PhiSig's Avatar
PhiSig
Wheel Whore
Has anyone tried heating up the shift **** with a heat gun or hair dryer to warm up the glue making it easier to twist??????
Old May 14, 2008 | 07:36 PM
  #85
350ZYALATA's Avatar
350ZYALATA
Tentill4z
Mine was pretty easy to just twist off. :shrug:
Is that bad?
Old May 17, 2008 | 08:26 PM
  #86
yellowlady's Avatar
yellowlady
WTF!
this is very difficult. the shaft that you grab with the vice grips is round and plastic so it just turns in the vice grips. i don't want to crush it! can you really clamp down on something round, smooth, and plastic enough to do this job. how would the dealer do it?
Old May 18, 2008 | 11:50 AM
  #87
yellowlady's Avatar
yellowlady
i finally got it done. the key is the rubber bands on the vice grips. it allowed enough grip to hold the shaft.
Old May 29, 2008 | 01:24 AM
  #88
BaTMan_4's Avatar
BaTMan_4
...sounds so complicated, guess i will have my car sitting in plain sunlight the day my shifter gets here, see if that helps
Old May 29, 2008 | 06:39 AM
  #89
lionheartednyhc
Its easy, twist off, screw on. You want complicated, try DIY e-brake
Old May 29, 2008 | 03:13 PM
  #90
rmtt's Avatar
rmtt
Just finished with a Forged Performance shift **** on my 2003. After reading through this thread, I was kind of "gun shy", but was pleasantly surprised when I went to do it. I just used vice grips around the rubber on the shaft, and used channel-locs on the shifter itself.
Just apply slow, steady pressure, and put the shifter in 3rd or 5th gear if you are pushing away from you, or one of the others gears if you are pulling towards you.
Old May 29, 2008 | 05:21 PM
  #91
Michael A's Avatar
Michael A
I agree 100%, I just did mine in about 1 min on my 2007 Z. The shift **** unscrewed with very little force being applied to the **** itself. However I supported the rubber shaft with vice grips very sturdily ... I didnt want to mess anything up.
Old May 29, 2008 | 07:39 PM
  #92
rubenationZ's Avatar
rubenationZ
twisted mine off with little effort thank god... damn thread scared the **** out of me hahaha 2008 Z FTW
Old May 29, 2008 | 07:48 PM
  #93
rubenationZ
bastards at nissan sold me the damn nismo Ti shift **** without the damn finisher f***
Old May 30, 2008 | 03:29 PM
  #94
BaTMan_4's Avatar
BaTMan_4
Originally Posted by sbZenth
Ok here we go.
It finally worked.
For those with the rubber thing over the shaft: just roll it down to expose the shaft. What i did then was i wrapped around 25 rubber bands on both sides of the vice grips. THIS WORKS GREAT! after that, i just attached them on the shaft. I used channel-locks on the ****, double wrapped a towel around it. And then i just twisted the ****. The vice grips held on the to the shaft perfectly. Here are some pics:
How did you manage to roll down the rubber on the shaft? Mine seems to be stuck on there like there is no tomorrow and won't budge
Old May 30, 2008 | 03:44 PM
  #95
BaTMan_4's Avatar
BaTMan_4
...anybody?
Old May 30, 2008 | 04:02 PM
  #96
Michael A's Avatar
Michael A
...anybody?
I put the vice grips right onto or over the rubber boot .... tightly. I believe this is only to hold the shaft from moving or rotating. It worked perfectly for me.
Old May 30, 2008 | 04:10 PM
  #97
BaTMan_4's Avatar
BaTMan_4
did you tear some of the rubber on the shaft or did you cover your vice grip to not damage the rubber ?? thanks for the response, im about to go ballistic cuz its being a pain in the a$$
Old May 30, 2008 | 04:16 PM
  #98
Michael A's Avatar
Michael A
I put the vice grips tightly on the rubber ... and then twisted off the shift **** with a small pair of pliers. It came right off for me, the oem **** did get scratched slightly but who cares.
This photo came out terrible for some reason !!
Old Jun 1, 2008 | 06:19 AM
  #99
brix's Avatar
brix
For those who have not the OEM rubber finisher, I found a site where the do the finisher in stainless and alu. :
http://www.zeetoyz.com/350z.htm
Here a pic of my 350ZR
(this is the alu. model)
for me it just look better than the cheap black toilet finisher made by Nismo.
Old Aug 11, 2008 | 12:35 PM
  #100
showtypeZ's Avatar
showtypeZ
Thank God for an 06 Z....I changed my shift **** while going through McDonald's Drive Thru. Mine just twisted right off and than I twisted the new one on. No damage done to OEM shift **** or Tranny.
