DIY: Rear Bumper Removal (with pictures)
Old Oct 11, 2006 | 02:29 PM
Mathys's Avatar
Mathys
Ok, update on the DIY:
You DON"T have to take off that crazy annoying plastic clip you need to turn 90 degrees!!!!
I took my bumper off two weeks ago and I tried for 30 minutes to get the clips out without success. I asked some people from a bodyshop nearby and they said that the clip is the same as one you would find inside the trim of a cars door. Which means you can just pull it right off.
So I continued to take everything else off, skipping part 3#. The bumper came right off as you can just pull the bumper backwards and the clip will unhook very easily.
So trust me on this one. Skip part #3 and you'll have your bumper off in less than 20 minutes!!!!!!!
Old Oct 21, 2006 | 03:50 PM
efx's Avatar
efx
Question:
Is this the only way I can get to the brake light wiring? Im trying to install this LED plate frame and Im confused as hell as to wire it. Need feedback pls. Thanks!
Old Oct 22, 2006 | 04:55 PM
archspeed's Avatar
archspeed
Gawddang, I freakin hope you're right! I had to abandon my rear bumper removal because of those crappy plastic piece. I nearly sworn off on all future Nissan products
I'll try this again next weekend, thanks!
Old Oct 23, 2006 | 04:51 AM
manny007's Avatar
manny007
I broke off one of them when I took mine off but did not put them back on my do-luck rear
Old Oct 23, 2006 | 06:14 PM
Anyone2u's Avatar
Anyone2u
Charter Member #82
I skipped putting mine back on as well when I installed the my new rear bumper (Central 20) and it held very solid. Seems my installations (after removals) always have a couple of extra fasteners/bolts left over!
Old Oct 29, 2006 | 02:27 PM
Mathys's Avatar
Mathys
Believe me, I was thinking the same thing!!!! Just forget about the clips and continue as described in the write-up. Bumper WILL come off without a problem
Old Jul 28, 2007 | 12:20 PM
pinktuscani03's Avatar
pinktuscani03
great write up..can't wait to do this next weekend.!
Old Nov 24, 2007 | 07:53 AM
vinniePOOH's Avatar
vinniePOOH
Thumbs up
good instruction!!
Old Feb 23, 2008 | 11:43 AM
luvaboi217's Avatar
luvaboi217
To the OP, GREAT DIY thread, very easy instructions, informative pictures.
Sorry for bumping an old thread but i used this DIY to remove my rear bumper this weekend, and it worked great.
Only thing i would add, is for folks with the mudguard, dont forget to remove it to get to a 10mm bolt below it. It was obvious to me while undoingg it, but looking back at the DIY, for some folks, they might miss it.
And dont forget to have a socket extension handy.
Again, thanks a ton OP.
Old Mar 26, 2008 | 11:55 AM
JasonZ-YA's Avatar
JasonZ-YA
great write up..will be doing it this weekend...i got a replacement bumper since mine was all scratched to heck and im gonna install a hitch as well to pull my autoX trailer..
- j
Old Apr 25, 2008 | 09:05 AM
pimpin714style's Avatar
pimpin714style
i needed this write up , thanks.
Old Jun 20, 2008 | 06:38 PM
XIceDragonX's Avatar
XIceDragonX
This should be a sticky, as it also covers replacing the lights in the rear, from tails to turns and license plates.
Old Jun 27, 2008 | 02:13 PM
SlowZster's Avatar
SlowZster
wow, got now bumper going on this sunday, thanks for this thread! Should make this install a snap!
Old Jun 28, 2008 | 07:47 AM
Netko350Z's Avatar
Netko350Z
Funny thing is I removed my bumper and I forgot to reinstall this bolt...
Old Jul 8, 2008 | 08:28 AM
SlowZster's Avatar
SlowZster
that plastic fastener thing that you mentioned can get pulled off instead of using the 7mm, can't. At least on the 06 if it's different. Snapped off both of them doing the un-install. Maybe I'm just retarded though...
Old Jul 12, 2008 | 12:29 PM
Tomci08's Avatar
Tomci08
Does anyoneknow if i can get to the reverse lights without unbolting the bolt on each side of the bottom of the bumper? My Nismo sides cover up the bottom most bolts, and i just need to get in to replace my drviers side reverse light, not just the bolts, but the whole light. THanks
Tom
Old Jan 23, 2009 | 09:04 PM
2viet's Avatar
2viet
out of subject but what spoiler is that? reminds me of the g35 spoiler.
Old Mar 10, 2009 | 08:29 PM
  #38
usmanasif's Avatar
usmanasif
OP, excellent thread
IMPORTANT: There is no such thing as an "automatically unlocking" white clip. OP is exactly right, they do need to be turned 90 degrees to unlock. I removed my rear bumper last night and after removing all other screws and clips, tugged and pulled at those clips to no avail. When you do remove them, you will see why; unless the clip is aligned with the rectangular hole, there is no way it is coming out. Mathys, I think you got lucky there; perhaps they had both moved to an almost unlocked position from normal driving.
That said, they are hard to remove but not impossibly so. I missed OP's post about using a 10mm socket and did it an alternate way. Took a pair of pliers and stuck my whole hand into the hole left by the taillight (just enough room even for my giant hands). Then with the pliers facing up, I had just enough leverage to turn the clips. Good thing they don't require a lot of force. But yes, DO use a 10mm socket to turn them and you will have them out in a few seconds.
Old May 8, 2009 | 02:50 PM
  #39
kamikaZ's Avatar
kamikaZ
3FIFTYZ
Fix the pics? =)
Old Sep 16, 2009 | 11:22 PM
  #40
finalforce's Avatar
finalforce
This needs a bump. I am planning on removing my rear bumper shortly and only could access this through search. Very good write up= A+.
